BMW e60 PDC Module Not Working: Error Code, No Power Supply, Tested Module, Hot, Substitutes
Taranti85 16158 3
  • #1 16454267
    Taranti85
    There is no module power supply in the error code. The tested module and these two things do not work, i.e. they are hot, you can tell where I can buy substitutes BMW e60 PDC Module Not Working: Error Code, No Power Supply, Tested Module, Hot, Substitutes
  • #2 16702506
    BARTRSL
    Rate: 9
    The transistors closer to this hole are 5ct and the 2 is 5bt
    • BMW e60 PDC Module Not Working: Error Code, No Power Supply, Tested Module, Hot, Substitutes 20170912_191936.jpg (4.19 MB) You must be logged in to download this attachment.
    • BMW e60 PDC Module Not Working: Error Code, No Power Supply, Tested Module, Hot, Substitutes 20170913_160119.jpg (5.01 MB) You must be logged in to download this attachment.
    • BMW e60 PDC Module Not Working: Error Code, No Power Supply, Tested Module, Hot, Substitutes 20170912_144603.jpg (74.68 KB) You must be logged in to download this attachment.
  • #3 16999252
    Taranti85
    Repaired after replacement
  • #4 18562346
    london2004
    Level 19  
    Rate: 392
    After replacing the transistor closer to the hole, voltage appeared but only 3V. What is going on?
