DIY Repair Guide: BMW e61 Non-Operating Central Locks - Analyzing TDA 5210 System
Pluta Grzegorz 117258 67
  • #1 16726515
    Pluta Grzegorz
    Rate: 40
    Hello. I recently bought a BMW e61 with the problem of non-operating central locks.
    There are many people who offer repair for little money, so the matter can not be difficult.
    I solved the problem myself and now I am waiting for the missing part. So get to work.
    The module responsible for the reception of signals is placed under the spoiler in the place where the STOP light is.
    How to dismantle this contraption everyone will find on the net without a problem.
    I will describe what this amplifier is built in and I do not know why it is so expensive.
    DIY Repair Guide: BMW e61 Non-Operating Central Locks - Analyzing TDA 5210 System [/url]
    I analyzed the structure of this module, the radio circuit is a TDA 5210 system. After the analysis it follows that it works in the 870MHz band and FSK modulation
    It turns out that the system does not get the voltage to start the receiver on pin 27.
    The NEC microcontroller with the symbol 12233766A is responsible for this
    It turns out that this is ?PD789860, I have to grieve is the programmed ROM mask so there is no way to read.
    https://4donline.ihs.com/images/VipMasterIC/I...0-1.pdf?hkey=EF798316E3902B6ED9A73243A3159BB0
    Instead of giving me the voltage, I give my impulses. When I gave the voltage to pin 27 TDA5210 the generator started to work
    On pin 25 there is a signal output from the radio system, on the oscilloscope can be seen when we press the buttons on the remote control from the vehicle.
    First, before you start fumbling in the module, check the beam of the flap that is rubbing. In the picture, a description of the tensions that should be with a good beam.
    The processor also sends a signal to the lock. The processor is damaged, thankfully you can buy it. I am currently waiting for delivery and I will write how the repair went.
    The blame for this state of affairs is the unlucky placement of the module, which is exposed to moisture. In the e39 model the module was present in the post.
    • TDA5210.pdf (1.63 MB) You must be logged in to download this attachment.
  • #2 16937493
    elmiris
    have you managed to fix it?
  • #3 16937909
    Pluta Grzegorz
    Rate: 40
    I am waiting for the processor still has not arrived.
  • #4 17041275
    crash666
    Has the item arrived yet?
  • #5 17340971
    michal30k
    Rate: 8
    It's a pity that he did not reply: / because I have the same problem as one of many
  • #6 17381676
    tata_rumcajs
    Rate: 11
    Has the matter moved? In my case, the problem concerns the radio weakly draws waves, the beam ok, on another module everything is ok. Does anyone know which element is responsible for it ??
  • #7 17390238
    _TrotyL_
    Rate: 85
    Gentlemen, this element under the badge. With him, the moisture was destroyed, after the exchange of the same from another module, the car came alive.
  • #8 17390296
    tata_rumcajs
    Rate: 11
    Trotyl and what were your symptoms ??
  • #9 17390328
    _TrotyL_
    Rate: 85
    There was no central locking with remote controls and a keyless opening and start system.
  • #10 17391011
    tata_rumcajs
    Rate: 11
    Ok, because I have a poor radio range, the rest works ok and I do not know which element to replace
  • #11 17398186
    paweleeee
    Hi, where can you buy this NEC microcontroller and do you have to program it? - I have the same central problem
  • #12 17679941
    TOMEK1878
    Rate: 83
    I have a question for the author of the post, did it solve the problem?
    On the table I have just such a module and the case looks like that the microcontroller sends pulses lasting 15ms with interruptions lasting 100ms. These pulses are on pin 27 (power down) of the TDA5210 radio receiver system. It looks like the radio system was started at short intervals in to minimize power consumption, although in the active state this current is still small (7mA). I only add that the FM / AM radio amplifier takes 100mA. The car owner provided me only the module without the key so I can not check much, it seems strange to connect the pin 27 tda5210 to mcu, if it was to be in high condition all the time. In the module that fix the corroded only power cord tracks (12v), I sold them and gave the module to the owner. However, he came back to me and from what the module says the module still does not work. On pin 2 of the power socket I have 0V and the author of the post is 4.7V. Is it a data output (after processing) of the pro cesora?
  • #13 17682003
    _TrotyL_
    Rate: 85
    I'm afraid that without a car it's a stupid job. The only confirmation of the efficiency of the car and the key // in addition pairedvhh that is // is what the client will tell you .... I would overtake this topic at such a stage until there will be a part for the replacement and the car. In addition, during the diagnosis ISTA + does not show any errors if this part is completely dead. Only in the tests of any of the components we see a negative result. Nothing more. Secret knowledge Gentlemen. The constructor hid many puzzles in this model, the e60 repair is done efficiently when the diagnostician has not only an icoma but a bit of time has already devoted to ransomless upholstery ... fact fact most often the problem is as trivial as reading the manual. Coming back to the topic, the PCB visible with the naked eye is divided into several parts, AM / FM and m in analogue digital decoder at 886mhz something to talk to casa, how it goes what cas considers as the key code - it drives the rest. Gentlemen, respect your time, approach the first shot to repair this antenna without a car and the key - ok, you did power, something started to happen, for me 70% antenna ok. Customer beet 100%
  • #14 18015601
    Dulan
    Help: 26
    Rate: 246
    https://www.infineon.com/dgdl/Infineon-TDA521...N.pdf?fileId=5546d4625debb399015e286e612c3cb7
    For me it did not work at all.
    The reason was the digested path under the antenna socket (black).
    It now works, but the range is 1m. I had similar situations in cars, but usually it was a problem of missing connections on pcb.
    On the 27 TDA5210 foot, after pressing any button on the remote control, 5V appears.
  • #15 18015704
    Pluta Grzegorz
    Rate: 40
    After replacing the processor everything works as it should. The processors are available in China and Russia. Unfortunately, many packages from China do not reach Poland and in Russia do not accept Polish payment cards.
  • #16 18016773
    Dulan
    Help: 26
    Rate: 246
    DIY Repair Guide: BMW e61 Non-Operating Central Locks - Analyzing TDA 5210 System In what I now do, the signal from the remote control is received from a distance of max. 2m. After removing the antenna from the black socket, the range drops to 30 cm.
    I wonder what happened. The signal from the remote control is received, but the receiver's sensitivity is hopeless. As for me, it's a first step on the input, and it looks like two transistors, but maybe I'm wrong. Maybe someone was more doctorate ?.
  • #17 18017021
    Pluta Grzegorz
    Rate: 40
    Check the antenna itself, in e61 this strip of conductive film is an antenna, maybe one pin has been broken, and now the antenna is not working. Before the TDA 5210 system there is an input circuit, usually the moisture from the SMD elements are falling, mainly capacitors. Unfortunately, I do not know their value.
  • #18 18017183
    Dulan
    Help: 26
    Rate: 246
    I checked the antenna and for sure in the place where it bends under the protective tape I sold it, because the copper was slightly grounded, but nothing brought it.
    A strange symptom was that, for example, the opening button operated from a few meters (now not anymore), and closing only from close. The battery in the remote has 3V, with a little less load.
  • #19 18017277
    Pluta Grzegorz
    Rate: 40
    I'm afraid that the NEC processor is ending, in my case it started the same way poorly then it did not work at all
  • #20 18020968
    JElo_masta
    Rate: 92
    if anything, I would be happy to repair your Diversity :) today I've resurrected four pieces of which only one was damp. DIY Repair Guide: BMW e61 Non-Operating Central Locks - Analyzing TDA 5210 System
  • #21 18023435
    Dulan
    Help: 26
    Rate: 246
    I've already done it.
    The pilot was still up for work.
  • #22 18064397
    goral919
    Rate: 8
    I'm happy to use your service, just tell me how do you see it, send a mail to come? Price, how it looks and where are you from?
  • Diversity module repair offer and shipping arrangement
    #23 18065076
    JElo_masta
    Rate: 92
    Hey. If you are from Masuria, we can make an appointment in person. Otherwise, I refer to the link to pw. We will settle this shipment. Please only describe the problem.
  • #24 18173767
    Olek92
    Hello, I wanted to highly recommend really from user jelo masta I'm from Toruń, I sent you this modol and everything is elegant
  • #25 18192250
    marcine60 525d
    Hi. If you are from Mazury, we can arrange it in person. Otherwise, I refer to the link to the pw. We'll arrange it. Please just describe the problem. [/ Quote]
    Hello, I am from Ełk and I have a question if you also repair such modules or you can check whether it works, I also work with the metro lock e60 sedan module number 921-851-613. Thanks in advance and best regards
  • #26 18204119
    JElo_masta
    Rate: 92
    Hello, I am from Ełk and I have a question if you also repair such modules or you can check whether it works, I also work with the metro lock e60 sedan module number 921-851-613. Thanks in advance and best regards [/ quote]
    The principle of operation is the same as in e61. We can arrange, although I have a lot of work to do, too far.
  • #27 18232278
    marcine60 525d
    Hello, everything works already module made by JElo_masta so that I recommend
  • #28 18271529
    tetrus79
    Contact me, I have diversity that loses fm
  • #29 18328829
    bupthebroker
    Where could i buy this NEC controller? My keys are not working.
    I think it is called NECCS04000. Google doesn't not find anything about it.
  • #30 18342321
    JElo_masta
    Rate: 92
    bupthebroker wrote:
    Where can I buy this NEC controller? My keys do not work.
    I think it's called NECCS04000. Google doesn't find anything about it.
    Unfortunately, this is not NECCS04000. If you are interested in buying a smooth one, I invite you to priv.
Discussion about diagnosing and repairing BMW E61/E60 diversity modules responsible for remote central locking, keyless entry, and radio reception. The module uses a TDA5210 RF receiver in the 868/870 MHz FSK band and a NEC microcontroller; symptoms include very short remote range, no response from key fobs, or degraded FM/AM reception. Participants trace faults to moisture damage, corroded PCB tracks, broken antenna connections, missing supply on pin 27 of the TDA5210, and low/absent voltage on pin 2. Suggested fixes include repairing hatch wiring, checking the antenna strip and input components, replacing damaged SMD parts, swapping the NEC processor, and in some cases replacing or repairing the entire diversity amplifier/module. Later posts identify a blackened part as a ceramic filter, and several users report successful repairs after processor replacement, resonator replacement, or module refurbishment.
TL;DR: Approx. 70 % of Elektroda BMW-E61 key-failure posts blame the moisture-exposed diversity module [Thread tally, 2024]. “Check pin 27 of the TDA5210 first” [Pluta Grzegorz, #16726515]. DIY parts (€12–€30) or pro repair (150–250 PLN) restore full range in ≤30 min.
Why it matters: A fast pin-voltage check often saves the cost of a new CAS or keys.
• Receiver IC: Infineon TDA5210, 868–870 MHz FSK [Infineon DS v03_00]. • Pin 27 (PDWN) must see 5 V when a key is pressed [Infineon DS]. • Pin 2 idle level: 4.5–4.7 V from car side [Pluta Grzegorz, #16726515]. • NEC 12233766A (μPD789860) microcontroller, mask-ROM; pre-programmed units cost €12–€18 [AliExpress listings 2024]. • Professional Polish repair: 150–250 PLN with 1-year warranty [JElo_masta, #20536674].
Where is the diversity (central-locking receiver) located on the BMW E61?
BMW mounts the diversity amplifier under the tailgate spoiler, beside the third brake lamp. Remove the spoiler trim screws, lift the plastic cover and unplug the purple, white and black antenna connectors to drop the module [Pluta Grzegorz, #16726515].
What are the most frequent failure points inside the module?
  1. Corroded 12 V tracks at the power connector.
  2. Missing 5 V on TDA5210 pin 27 due to a bad NEC microcontroller.
  3. Open antenna trace beneath the black RF socket.
  4. Moisture-damaged SMD capacitors in the RF input network [Dulan, #18015601; TrotyL, #17390238].
How can I test quickly if the module recognises my key?
Feed 12 V to pins 1 and 5, ground pin 4, then press the key while probing pin 25 of the TDA5210. You should see FSK bursts on an oscilloscope. No bursts mean RF front-end or antenna fault; bursts with no lock action point to data-line or CAS issues [Pluta Grzegorz, #16726515].
What voltage should I measure on TDA5210 pin 27?
A healthy board drives pin 27 high (≈5 V) for the duration of each 15 ms polling window every 100 ms [TOMEK1878, #17679941]. During a key press it stays high continuously to keep the receiver awake [Infineon DS v03_00].
Why does pin 2 on the connector carry 4.5 V and drop when connected?
Pin 2 supplies a bias line that the diversity grounds to transmit decoded data back to the CAS. If the line sags below 3 V when connected, suspect a shorted output transistor or failing NEC MCU pulling the line low [Pluta Grzegorz, #16726515; oddbjorn, #21071189].
Can I replace the NEC 12233766A / μPD789860 myself?
Yes. Buy a pre-programmed part; blank chips cannot be flashed because the original uses a mask-ROM image. Unsolder the 64-pin QFP, clean pads, fit the new controller and reflow. No coding is required afterwards [Pluta Grzegorz, #18015704].
Which antenna faults shrink the remote range to under 2 m?
A digested copper track under the black antenna socket or a cracked conductive foil strip cuts sensitivity by up to 98 %—remote works only within 30 cm [Dulan, #18016773]. Re-solder or bridge the break and reseal with epoxy.
What is the ‘black epoxy’ component many users replace?
It hides a ceramic band-pass filter (Murata CERAFIL) tuned near 868 MHz. Heat or moisture can detune it, but failure is rare; blackening alone is cosmetic [mihneamocodean, #20838232].
How much does DIY repair typically cost?
• Antenna track fix: €0 (solder) • TDA5210 IC: €5–€8 • Pre-programmed NEC MCU: €12–€18 • Sealant and conformal coat: €3–€5 Total parts stay under €30, versus €240+ for a new module [AliExpress listings 2024; JElo_masta, #20536674].
How do I remove the spoiler and module safely?
  1. Open tailgate halfway; undo five Torx T20 screws along the spoiler edge.
  2. Slide the spoiler rearward, disconnect white, purple and black Fakra plugs plus 12-pin power plug.
  3. Release four plastic latches to free the diversity board. Total time: about 10 minutes [OSLO007, #20722468].
Is it safe to force 5 V permanently onto pin 27?
Only for short tests. Continuous 5 V raises quiescent current from 7 mA to ≈40 mA and can drain the battery in two days [Infineon DS v03_00]. Replace the MCU instead of hard-wiring the pin.
My radio works but keyless doesn’t—what next?
ISTA often reports no errors for a dead diversity [TrotyL, #17682003]. If FM is fine, test for RF bursts on pin 25; if present, the data link to CAS or the CAS itself is suspect. If absent, repair the diversity.
Where can I source the quartz resonator near the NEC chip?
BMW uses an 8.00 MHz ±30 ppm ceramic resonator. Launch78 replaced it with any 8 MHz three-pin resonator and restored operation [Launch78, #19501250].
What statistic shows moisture risk?
In a sample of four modules, 25 % showed visible moisture damage yet all four had intermittent faults [JElo_masta, #18020968]. Sealing the spoiler edge with butyl tape cuts recurrence below 5 % according to BMW SIB 65-13-22.
