BMW e60 Sedan: Unresponsive Central Locking Despite Signal Reception and Module Replacement
Pfemek 33015 10
Why does the BMW E60 see the key fob signal in CAS but the central locking still does not respond?
The fault was caused by incorrect coding of the CAS module, so the central locking did not react even though the key signal was received. One user found that moving a known-good CAS into the car made the central locking work, which pointed to the CAS itself rather than the key or receiver [#17504123] The suggested fix was to program/code the CAS with ISTA/P or WinKFP [#17520330] In the end, the car was repaired after the replacement CAS was coded correctly, even though the coding was not perfect [#17526015]
  • #1 17503497
    Pfemek
    Help: 83
    Rate: 342
    The key fob does not work. The remote control sends the signal, the car selects it, but the locks do not respond. It is a sedan, so the harness in the hatch comes off. I replaced the receiver module under the headliner, but to no avail. There are no errors in the CAS module. In the parameters, he sees the remote control signal when buttons are pressed. If the car is in sleep mode by pressing any button on the remote control, something clicks under the hood and the start button on the board lights up. Fuses in the glove box and in the boot checked. The central one works, of course, with an insert and a button on the board. A strange case. Apparently it happened just like the car stayed with the mechanic for a few months because the engine died. Any hints?
  • #2 17503738
    bodom
    Level 30  
    Help: 118
    Rate: 232
    There may be a VL2020 battery to be replaced in the key
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    I had the E60 2005. with the same problem. I bought it slightly damaged and it had a dead battery, but I already had one from 2003. where everything was ok - both limos. Everything the same as you write. Cas'2 in both white. After shifting the CAS from good to not working, the central one moved. So I bought a set of key + CAS and then matching to this engine controller so that it lights up and everything works. It is difficult to say what happened, because there were no errors, the key signal was transmitting, CAS saw it
  • #4 17506273
    czaki22
    Rate: 17
    power supply on the plug, this driver is also an antenna amplifier and separator, you have 2 x pllus 12, mass springs
  • #5 17513160
    Pfemek
    Help: 83
    Rate: 342
    Thanks for the info.
    I had another e60 in the meantime. I changed CAS and the lock worked. I will replace, add and it will be ok.
    Greetings...
  • Need CAS and DDE file editing for synchronization
    #6 17519566
    Pfemek
    Help: 83
    Rate: 342
    I already have a CAS with a key. Honestly, I thought maybe we could only make a CAS clone and the old remote would work but unfortunately d..pa ... :)
    I need to pair it all right now.
    In the batch from the CAS I bought, I entered the correct VIN and reset the mileage. The remote control works but I do not have a synchronized engine controller. Could someone edit CAS and DDE files so I can synchro? In the appendix eeproms with CAS original, CAS new and with DDE ory. Are these files enough?
    • CAS nowy.bin (4 KB) You must be logged in to download this attachment.
    • CAS nowy VIN ok.bin (4 KB) You must be logged in to download this attachment.
    • CAS ory.bin (4 KB) You must be logged in to download this attachment.
    • edc16c35 0 281 013 253 95640 ory.bin (8 KB) You must be logged in to download this attachment.
  • #7 17519769
    seat21
    Help: 151
    Rate: 399
    should come up
    • CAS nowy VIN ok_New.rar (1.28 KB) You must be logged in to download this attachment.
  • CAS coding mismatch on automatic transmission configuration
    #8 17519865
    Pfemek
    Help: 83
    Rate: 342
    Thanks. Tomorrow I check from the very morning ... :)
    Added after 1 [hours] 11 [minutes]:
    I checked today. Unfortunately, he doesn't smoke. But I guess I know why. I was able to do a synchro already and I have no errors in the engine or CAS. It looks like the problem is with the CAS configuration. I have info to press the clutch and fire but it is an automatic machine. In turn, I can not configure it, it does not pass the encoding and I have an error probably related to trying to encode the already encoded module. Tomorrow I will think ...
    seat21
    Help: 151
    Rate: 399
    then it remains CAS fun with ISTA P or WinKFP
  • #10 17521929
    czaki22
    Rate: 17
    check why the cas is hit with safety on disc
  • #11 17526015
    Pfemek
    Help: 83
    Rate: 342
    The car is done. As I thought, wrong coding of the new CAS. It wasn't straight, but it worked ...
The discussion revolves around a BMW E60 sedan experiencing unresponsive central locking despite the key fob sending signals and the CAS module showing no errors. The user replaced the receiver module but still faced issues. Responses suggest checking the key fob battery, power supply to the plug, and the CAS configuration. One user shared their experience of resolving a similar issue by replacing the CAS and key, while another highlighted the importance of proper coding for the new CAS. Ultimately, the problem was identified as incorrect coding of the new CAS, which was resolved, restoring functionality.
