[Solved] Troubleshooting BMW E61: Non-Functional Central Locking Remote Control - Terminal No. 30E Error
wary2 11544 2
  • #1 17101971
    wary2
    Help: 6
    Rate: 221
    Hi.
    As I wrote above, the remote control of the central locking in the BMW e61 before the lift does not work for me.
    I checked the hatch beam is functional.
    When I enter the module's real parameters, I can see information after pressing the button (on the remote control) (open).
    Central with key in cylinder works closes opens (also windows)
    What else can be the reason In the controller (IMO-car access system) there is one error "Terminal No. 30E"
    but I can't locate it.
    I am asking for a hint.
  • #2 17132023
    wary2
    Help: 6
    Rate: 221
    Hello topic solved, however, fell the module located under the plastic on the tailgate. Surprisingly, in the driver, as I wrote, I found information that the driver receives the signal from the remote control. and knows how to recognize him.
    Regards
  • #3 17132028
    wary2
    Help: 6
    Rate: 221
    Regards
    I have replaced the module. Regards
