Opel Corsa C 1.2 2001 - P0560 Error, Fuel Pump Issues & Intermittent No-Start Concerns
kukusteam 19065 10
Why does my Opel Corsa C 1.2 sometimes not start because the fuel pump doesn’t run, and is the P0560 code pointing to the pump or another fault?
The fuel pump was the main fault: if voltage reaches the pump but it still does not run, the pump is likely failing or already dead, and replacing it is the right move [#16454985][#16455690][#16457128] P0560 means incorrect supply voltage in the vehicle electrical system, so it is not a direct fuel-pump error [#16455026] Because the engine also sometimes would not crank, the battery, clamps, ground and starter should be checked too, since the no-start can be a separate voltage problem [#16455458] Repeated failed start attempts can also trigger P0560 from a discharged battery [#16458092] In the thread, replacing the pump fixed the car, which confirms the pump fault as the main cause [#16458079]
  • Intermittent fuel pump operation despite receiving power
    #1 16454687
    kukusteam
    Hello, (Opel Corsa C 1.2 16v 2001 Petrol) The problem started two days ago, the car went out after driving for 10 minutes, I came back and wanted to start but I didn't turn anything, the fuel pump could not be heard .. I was checking if the pump is receiving electricity through the tube and it comes. So I unfastened the two hoses again, I turned the pump off, nothing pumps ... I dismantled the pump, connected it to the rectifier for a short time. THE PUMP WORKS, I put it in, started it and rode for one day ... on the second day in the morning I went to check if it fires up, the first time it did not start, the second or the third one did not go, after 30 min I went again and fired I drove a max of 10 km, turned off and did not want to start again, the pump could not be heard .. I checked the error using the GAZ method - BRAKE and after counting out error p0560, I have a question if it is the fault of the pump or other components?
    piotrekwoj1
    Help: 947
    Rate: 3433
    Since the voltage reaches the pump and the pump itself does not work, it's probably all clear. This error I think is not related to this vulnerability.
    Daro122
    Help: 165
    Rate: 751
    0560 Incorrect supply voltage in the vehicle's electrical system, and as for the pump, sometimes it can do such pranks before it is completely dead.
  • #4 16455405
    kukusteam
    Okay, thanks for the answers I will order a pump 150 zlotys tomorrow and on Saturday I will let you know if it will work.
    Daro122
    Help: 165
    Rate: 751
    In the first post you write that the engine does not spin and it certainly will not be the fault of the fuel pump. You have a problem with tension and I would start with loose clamps, mass, starter. A Corsa like yours once gave me a bad deal just because of the battery that was still spinning but the engine driver didn't fit it anymore.
    piotrekwoj1
    Help: 947
    Rate: 3433
    kukusteam wrote:
    I was checking if the pump was getting electricity through the tube and it was coming in. So I unhooked two hoses again, turned the pump on, nothing pumps ...
    This entry indicates a pump failure, unless the owner did the wrong measurements or has twixa and has two different faults.
    How did you connect and what tube do you have?
    Daro122
    Help: 165
    Rate: 751
    Yes peter1, one does not exclude the other.
  • #8 16455757
    kukusteam
    My fault, the car misses it, I get it wrong ... The cape looks like a screwdriver with a light bulb inside and the mass from the spring comes out ...
    piotrekwoj1
    Help: 947
    Rate: 3433
    Do the same but with the h4 bulb instead of the tube. If it lights up, replace the pump without hesitation.
  • #10 16458079
    kukusteam
    Pump replaced, thanks for the help of the car smokes and blows. :D And as for the error, what could be the reason? The pump could give such an error?
  • #11 16458092
    ociz
    Help: 1379
    Rate: 3486
    He could "give" a discharged battery if the attempts to start the engine failed.
The discussion revolves around a 2001 Opel Corsa C 1.2 experiencing a P0560 error, fuel pump issues, and intermittent no-start conditions. The user reports that the fuel pump is not operational despite receiving voltage, leading to troubleshooting steps including pump disassembly and testing. Responses suggest that the P0560 error indicates incorrect supply voltage, and the fuel pump may be failing. Recommendations include checking electrical connections, battery condition, and replacing the fuel pump. After replacing the pump, the user notes the car still exhibits issues, prompting further inquiries about potential causes of the error.
