Connecting Fiat Car to Airbag CAN Module with ELM 327 1.5a: 120 Ohm Resistor Issue
gnegon 5967 5
  • #1 16459814
    gnegon
    Help: 6
    Rate: 11
    Hello, I bought an ELM 327 1.5a with the thought of connecting a Fiat car through the Airbag CAN module, but I encountered a standard problem of the 120 ohm resistor, unfortunately I cannot locate it (my board layout is different than those shown on the internet), please help me locate the problem .
    Connecting Fiat Car to Airbag CAN Module with ELM 327 1.5a: 120 Ohm Resistor Issue Connecting Fiat Car to Airbag CAN Module with ELM 327 1.5a: 120 Ohm Resistor Issue
  • #3 16460226
    gnegon
    Help: 6
    Rate: 11
    I checked the resistance between pins 6 and 14 and its bra, i.e. there is no connection between these pins ...
  • #4 16460273
    piotrekwoj1
    Help: 947
    Rate: 3433
    Do it as it says there, pull two lines to ground through 100ohm resistors with 560pF capacitors connected in series. If that doesn't help, you probably don't do anything. This is how you buy the cheapest.
    Do you have these pins connected? Do an action with inserting the pin switch because it's hard to tell which ones you have connected and which are not.
  • #5 16461235
    gnegon
    Help: 6
    Rate: 11
    This is not the cheapest version of this cable, the pins are connected and the resistance between them is 47k ohm
  • #6 16502740
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    I've never heard of having to terminate both lines to ground. This is supposed to work without any additional termination. Proper termination is already in the existing network in the car.
