Fiat Stilo 13 Pin Hook Module: Connecting Fog Lights and Utilizing Alarm Info Output
Lukasino 12633 3
  • #1 16553414
    Lukasino
    Rate: 71
    I bought a module for the Fiat Stilo and I have a question about connecting fog lights, according to the diagram I need to "let go" the power circuit through the module, and I have two rear fog lights in Stilo, the computer signals each separately, how to connect it so that my computer does not go crazy ( in Stilo, he is extremely sensitive, who knows? :) ), can this be solved with relays? I would appreciate some simple scheme.
    I still have a question about the "Alarm info" output (this diagram is not present), this is one wire (probably the "ground" signal) what is it used for in practice? I have an alarm in my car.
    • U3P.pdf (911.33 KB) You must be logged in to download this attachment.
  • #2 16553443
    piotrek22101
    Help: 695
    Rate: 1421
    Alarm info is connected to the signal cable from the tailgate or door. When the alarm is triggered, he should howl when someone unloads the trailer plug.
  • #3 16553730
    andrzej20001
    Help: 1578
    Rate: 6669
    With us there is no requirement to turn off the fog lamp in the car after attaching the trailer. You get fog signal for a trailer from one lamp, where it's more convenient.
  • #4 16554101
    Lukasino
    Rate: 71
    The requirement may not be there, but the light reflects off the trailer is nothing nice, let alone that the damage to the bulbs like a trailer covers the rear of the vehicle.
    Added after 16 [hours] 19 [minutes]:
    I came up with a system that after connecting the trailer, set the car's fog lights to 30% of power (using the DRL module and 4 relays).
    Can you peek if it will work?
