Whirlpool ADG 6500 Dishwasher Error: LED Blinks 6 Times - Cycle, Potential Causes & Fixes
Piotrek904 7614 2
  • #1 16464630
    Piotrek904
    The dishwasher starts for a few minutes and crashes an error. The cycle is as follows:
    - pumps out residual water
    - pour a new portion of water
    - the washing pump starts and you can hear the sprinklers working for several seconds
    - the sprinkler pump stops
    - draining residual water
    - the dishwasher squeaks and displays an error (6 blinks of the LED)
    I checked the reed switch - it works
    The pumps are working
    Filters clean, water pressure after unplugging the hose is approx.
    The dishwasher looks very simple and I do not see that it has a membrane sensor or OWI. I also did not locate the water jet divider (which surprises me because it has a half load program).
    I wonder how the dishwasher knows that something is wrong (from which sensor it gets information about the error with the water supply)
    Please give me some suggestions what I can check.
    I attach photos of the inside of the dishwasher
    Whirlpool ADG 6500 Dishwasher Error: LED Blinks 6 Times - Cycle, Potential Causes & Fixes Whirlpool ADG 6500 Dishwasher Error: LED Blinks 6 Times - Cycle, Potential Causes & Fixes
  • #2 16464717
    machefi
    Home appliances specialist
    Help: 763
    Rate: 1487
    Wash pump to be replaced. The rotor sleeves are worn, the pump current has increased during operation and the electronics stops the operation of the device. These dishwashers are mean in that regard. You can still substitute the pump's starting capacitor in a gesture of despair, but it will certainly do nothing.
  • #3 16464845
    Piotrek904
    Ok, I'll check it out today.
    I understand that the pump impeller is to have 0 radial play, while the axial play is acceptable.
