BMW E60 Navi Prof Radio Issue: Intermittent Startup, BMW Logo, Screen Flash, 6417751R System
qrak1 12237 5
  • #1 16469270
    qrak1
    Rate: 31
    Hello everyone,
    for some time I have a problem with the radio in the BMW E60 Navi Prof - the radio does not start once, the BMW logo appears or the screen flashes. The problem is not permanent.
    About 2 weeks ago I put the 6417751R system back on - after this operation the problem disappeared - for 2 weeks ...
    In my opinion, the above system is responsible for everything - has anyone worked on this topic and can you get it somewhere in Poland?
    6417751R
    SH-4
    BP200
    BA07087
    BMW E60 Navi Prof Radio Issue: Intermittent Startup, BMW Logo, Screen Flash, 6417751R System22.jpg (2.07 MB)You must be logged in to download this attachment.
  • #2 16470769
    kubahpi
    Help: 46
    Rate: 166
    A colleague did a total reballing of the system, or just heated the element?
  • #3 16470925
    qrak1
    Rate: 31
    The system has been "put back" ...
  • #4 16470941
    kubahpi
    Help: 46
    Rate: 166
    First of all, I suggest reballing the flash memory on the other side of the board. It is also worth checking if the rest of the electronic components do not have a cold February, in particular on the SAF7118H system, which is on the same side of the circuit board as the system mentioned by a colleague.
  • #5 16470947
    qrak1
    Rate: 31
    Ok thanks for the info. On Monday I'm getting to work.
    Pozdr.
  • #6 18561045
    macholek.89
    Pozdr.
    hey and how did you fix the results?
