BMW E60 525i 2006 - Radio downloads 7A, iDrive - black screen
K_o_N_z_I 22233 6
  • #1 16825127
    K_o_N_z_I
    Help: 13
    Rate: 55
    Hello everyone,
    car bought a week ago, the previous owner took out the fuse responsible for the radio (F34 from the fuse console in the passenger compartment), because the radio consumed electricity all the time despite turning off the ignition. Except for the backlight of the radio and its fan on, the radio and navigation cannot be used.
    I measured the current power consumption of the radio and it is 7A. All other fuses (both in the passenger compartment and the battery) measured, all functional. From the initial search for a solution, I bet on the CCC motherboard as the culprit.
    Is there anything I should check before removing the module and trying to repair the motherboard.
    Is programming necessary? If so, which interface and program should I use? I have an interface on RS232, INPA, NCS and DIS.
    I intend to undertake the repairs myself, the service on site (Australia) wishes for the repair service PLN 3,000, buying stimulants from Poland odapa, due to the significant shipping costs.
    I'm counting on your help.
    BMW E60 525i 2006 - Radio downloads 7A, iDrive - black screen BMW E60 525i 2006 - Radio downloads 7A, iDrive - black screen BMW E60 525i 2006 - Radio downloads 7A, iDrive - black screen
  • #2 16825587
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    K_o_N_z_I wrote:
    buying stimulants from Poland odapa, due to the significant cost of shipping.
    1600 PLN radio + 120 shipping.
  • #3 16825614
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    If in that money they would fix CCC, it's not so bad. Because it is an expensive audio system even in Poland.
    All for around 10 PLN.
  • #4 16825623
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    Don't overdo it - unless you mean new.
  • #5 16826548
    K_o_N_z_I
    Help: 13
    Rate: 55
    I gave up playing with shipping - too much risk and it is finally expensive fun.
    I would like to fix it myself. If someone does it, why should I not do it with your help?
    I have access to BGA and x-ray. I worked on motherboards from laptops in my time in Poland and I have experience.
    If you have access to service websites or are able to write what to check in this case and what signals I would expect it would be very helpful.
  • #6 16829034
    K_o_N_z_I
    Help: 13
    Rate: 55
    Problem solved. Subject to close.
  • #7 16829105
    Help: 1405
    Rate: 6430
    You're good.
The discussion revolves around a 2006 BMW E60 525i experiencing issues with its radio and iDrive system, specifically a black screen and excessive power consumption (7A) due to a removed fuse (F34). The user suspects a faulty CCC motherboard and seeks advice on troubleshooting steps before attempting repairs. They express a desire to fix the issue independently, leveraging their experience with electronics and access to specialized tools. Responses include suggestions about the cost of repairs in Poland and encouragement for the user to proceed with self-repair, ultimately leading to a resolution of the problem.
