2007 BMW E60 - Radio Displays & Clocks Fail After Music, Engine OK, No MPM, Fuse Check
robertwojciak 16251 3
  • #1 16933253
    robertwojciak
    Rate: 30
    Hello. The car from 2007. There is no mpm module in the boot. After listening to the music both displays and clocks fell on the radio. Fuses checked. The engine starts up normally.
    I am asking for urgent help.
    Regards.
  • #2 16934010
    seba119
    Rate: 9
    I have not met so that there is no MPM module. MPM powers the radio, etc. It is located under the spare wheel. He could soften. Secondly, navigation often creates problems if the car has it, I had such a case. It was enough to disconnect the module from the navigation, which is in the trunk and everything was back to normal.
  • #3 16935812
    robertwojciak
    Rate: 30
    Google suggested that after 2006 there is no mpm module. The display has power. Maybe someone will tell you what the fuse for one of the ccc module plugs is for. Value 20 A. That's what I saw on the net. I haven't dismantled it myself because I have a problem with unplugging the airflow control panel. Ps. Clocks are controlled from the ccc module?
    Regards.
  • #4 16941469
    robertwojciak
    Rate: 30
    Fixed. The connector under the fuse had a bad contact. We're closing.
