Why does a Sony Xperia M4 Aqua keep restarting at the Sony logo, and how can it be fixed?
A Sony Xperia M4 Aqua that shows the logo and then reboots is often suffering from a CPU/processor solder fault rather than just a simple software problem; the suggested repair is a CPU reball, or CPU reflow if reballing equipment is not available [#16506621] [#16514652] One reply notes this is a common malfunction of this model and that if even one signal is missing, the phone will restart [#16508301] Another user confirms that a CPU reball restores proper operation [#16516438] If you cannot do board-level repair yourself, the remaining advice was to take it to a GSM service [#16481178]
  • #1 16477837
    troy82
    As in the subject, I have a problem with the m4 aqua phone, it just can't be started.
    The sony logo just pops up and it keeps restarting.
    Does any of your colleagues have any ideas what could be the reason?
    best regards
  • #3 16480547
    winmap
    Help: 361
    Rate: 754
    Bootloader, motherboard to be replaced so that possible.
  • #4 16481096
    Vinnic
    Help: 18
    Rate: 20
    You can try to re-load the ROM. In addition, I do not know about the M4, but in my M2 there is a reset under the card cover. Good luck.
  • #5 16481139
    troy82
    Hello and thanks in advance for the suggestions, but unfortunately none helps.
    Attempting to reset or using the off key does nothing, the phone only turns on for 2-3 seconds to the sony logo and the reset is similar when connected to a computer
    it is impossible to upload the rom because the phone is only detectable in the flashtool for a few seconds.
  • #6 16481178
    nutergsm
    Help: 1034
    Rate: 1666
    It remains to visit the GSM service.
  • #7 16506198
    troy82
    I do not think the phone is in perfect condition, I have read a lot on various forums that this is a software defect but a problem with uploading.
  • #8 16506621
    pp13dhkoty
    Rate: 28
    A very common glitch with the M4 Aqua -> CPU reball
  • #9 16507147
    troy82
    well oki reball cpu I understand a lot of cases I've already seen cold solders, but why does lego start and restart? under the computer also visible
  • #10 16508301
    pp13dhkoty
    Rate: 28
    A typical malfunction of this model - it is enough that one signal does not appear and the phone restarts.
  • #11 16510495
    tele_sim
    Help: 201
    Rate: 217
    Just warm up or new balls? Which element exactly?
  • #12 16514652
    pp13dhkoty
    Rate: 28
    Processor. It's best to do a reball. If you can't (no sieve) then the CPU reflow.
  • #13 16516438
    gazownik10
    Help: 9
    Rate: 24
    Hello! I confirm the reball cpu and it will work properly
The Sony Xperia M4 Aqua is experiencing a restart loop, where it only displays the Sony logo before rebooting. Possible causes include battery issues, corrupted software, bootloader problems, or motherboard failure. Suggestions for resolution include reloading the ROM, performing a reset, or visiting a GSM service for professional repair. A common issue noted is related to the CPU, where reballing or reflowing the processor may resolve the malfunction. Users have reported that even minor signal failures can trigger the restart loop.
