FAAC 740E Drive Gate Connection, Wiring & Remote Control Programming Guide
chudi075 15243 4
  • #1 16589333
    chudi075
    Hi, I have a problem with connecting the drive to the gate, I will give you a photo or will someone advise you if it is a good connection and how to program the remote control?
    Added after 7 [minutes]:
    FAAC 740E Drive Gate Connection, Wiring & Remote Control Programming Guide FAAC 740E Drive Gate Connection, Wiring & Remote Control Programming Guide
  • #2 16590004
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    The instructions in the set were not there? Diagrams for each circumstance are beautifully presented.
    As for programming the remote control, the manual explains it best. Read the instructions and then ask what you do not understand, we will help.
  • #3 16590934
    kotbury
    Gantry automation specialist
    Help: 2100
    Rate: 3631
    Do you use STOP and EDGE inputs? If you do not get it strangely hooked - instead of short bridges to the minus I see cables going somewhere.
    And I do not see a minus of the power of the receiving photo (only the transmitter takes minus the power from TX - FSW, receiving from the normal mass), plus the power of the receiving photo can not be seen (unless plugged into the plus power of the sending pics somewhere outside the central). Bridge FSW - OP to TX - FSW good.
    Actually, look at the scheme of attaching pics in the instructions - as rarely in Italian - readable to pain.
  • #4 16591742
    Marek J.
    Help: 526
    Rate: 951
    Those on the tile say everything (almost).
    STOP does not light - no bridge (if not connected)
    EDGE does not light - no bridge (if not connected)
    The FSW CL does not light up - the photocell is connected badly (unless you just obscured your pics ...)
    Bridge for FSW OP correct - although the cross-section of the "bridge" is strongly exaggerated ...
    The rest, as the predecessors wrote - in the instructions. Make basic settings before programming the remote control. Check direction, strength, working time, return stroke, slowdown. Look for the right mode of operation (logic) etc ...
  • #5 16592185
    leotdipl
    Help: 51
    Rate: 153
    ... the author is probably not interested ...? In addition, no application by the author
    "possession status" of additional devices makes a little "Guess the Game" topic ;)
    It's a pity, because I'm curious about solving similar problems.
    ps.
    the topic is probably living "my own life"
