Procedure for Unlocking Piston Rings with Kerosene in Fiat Punto 1.1 8V Engine
8850 114711 37
How do I free a suspected seized piston ring in one cylinder of a Fiat Punto 1.1 8V using kerosene, and what is the correct procedure?
No — do not flood the cylinder overnight with kerosene; at best it can free rings that were stuck immediately after an overheat, but in a 200k km engine with only one cylinder down it is more likely a mechanical fault than simple ring seizure [#16480246][#16480351] A dry 6 bar reading that rises to 12 bar after the oil test does point to leakage past the piston/rings, but seized rings usually show up on all cylinders and typically cause oil burning and smoke on all of them, not just one [#16480351][#16483478] Before trying any chemical soak, check the valve clearance and valves, because a valve that does not close can also cause low compression [#16483478] The best diagnostic step suggested was a leak-down test: set the cylinder with both valves closed, feed compressed air through the spark-plug hole, and listen for air at the intake, exhaust, or crankcase/oil pan [#16483478] If air escapes into the crankcase, suspect rings/cylinder wear; if it hisses through intake or exhaust, suspect a valve problem [#16483478] Several replies warned that kerosene or other cleaners are no miracle cure and can make things worse if they get into the oil, so if the engine is mechanically damaged the real fix is overhaul or replacement [#16478741][#16480731][#16480351]
  • Setting piston halfway before kerosene soak
    #1 16478330
    8850
    Rate: 285
    I plan to flood the cylinder with kerosene during the day and night. I suspect seized or cracked rings on the piston. Reason: dry compression warm strong - 6 bar, after oil test 12 bar. If seared - it should help, if cracked - not. And now how to do it correctly?
    I plan: drain the oil, unscrew the candles, fill the entire cylinder with kerosene should enter about 250 ml (engine 1.1 8V Fiat Punto 1 55KM), leave it overnight, pour in again 250 ml in the morning and leave it for the whole day. In the evening, unscrew the plug from the oil and drain the kerosene from the bowl. Pour over with oil.
    Do you have to set the plunger about halfway? Is it enough to drive the 5th gear, lift one wheel and turn it, and insert the wire into the cylinder to measure the depth?
  • #2 16478356
    barteksmrek
    Help: 89
    Rate: 224
    People. It worked 20 years ago. Repair or replacement of the engine.
  • #3 16478396
    8850
    Rate: 285
    @barteksmrek: the car is 20 years old, so if it worked so many years ago, it will work now as you write. Engine overhaul is the cost of the car. The engine spacer is 50% of the car's value. If the kerosene experiment fails, the car may end up for scrap, unless it will run on 3 cylinders instead of 4 for the next 2-3 years.
  • #4 16478741
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    Now there are much better fluids that you can use, for example carbon cleaner or even wd40 will be better than kerosene, also use an engine rinse added to the oil because it also cleans the engine.
    You must know that old engines run often due to the fact that the carbon deposit helps the engine to run, if you flush it properly, it may run worse ;-)
    Good luck :-)
  • #5 16478747
    Megawe
    Help: 246
    Rate: 1438
    This worked in the era when the engines were running on the superol.
    The kerosene will only dissolve soft carbon deposits. If the carbon deposit was skoked, I would flood the engine even with used good oil with flushing additives and after a month of driving, I would continue to combine it with rinses.
  • Kerosene soak for one stuck cylinder only
    #6 16478894
    8850
    Rate: 285
    I need to dissolve the carbon deposit only on one second cylinder because if I start on the entire engine it may end badly for him. So it would be best to pour some cleaning substance into it and leave it for X hours, from time to time moving the plunger. I thought that kerosene is the most powerful substance because it has creeping properties than, for example, wd40 or carbon cleaner offered by my colleague @diababg. Anything even more corrosive to coke? Of course, the assumption is that I'm draining the oil from the engine and pouring something into the cylinder.
  • #7 16478908
    jack63
    Help: 851
    Rate: 2822
    Read the composition of WD40 on his card. You may be surprised ...
    Charred particles best soften alkali-based detergents. For example, the preparations will give the glass of cells, but unfortunately they cannot be used in the engine.
    IMHO, you have little chance of success for your idea.
  • #8 16479843
    barteksmrek
    Help: 89
    Rate: 224
    Apparently, Pepsi dissolves everything. And seriously, there are also preparations for cleaning fireplace glass.
  • #9 16479880
    ladamaniac
    Help: 724
    Rate: 2078
    I can confirm that the combination of highly alkaline cleaning agents and an aggressive hydrocarbon-based cleaner (e.g. Gunk) gives good results.
    Unfortunately, the bases are quite good at dealing with aluminum and its alloys, releasing hydrogen at the same time. (pistons)
  • #10 16479943
    ALIBABA I
    Help: 223
    Rate: 537
    Okay, Col. detergents OK. and what's next with the shaft's lubricating channels and bushings, but it flows into this bowl and there is a secondary circulation, and what's next, the pistons, clean rings, and the crankshaft? It's spinning in that slush, hmm. washing the engine, rinsing the engine several times, e.g. with kerosene, hmm, after such combinations, the oil will be changed several times during a normal change.
  • #12 16480095
    8850
    Rate: 285
    @strumien awareness: I think that the rings can get stuck from dirt, carbon deposits and other things because the mechanics tell me that when I drive on LPG, the fuel is dry. In that case, I do not know why preparations such as this one are produced. XADO VERYLUBE ANTICOX ANTICARBON AEROSOL 320 ml
    http://sklep-xado.pl/pl/p/ANTYKOKS-Antykarbon-320ml-aerozol/468 which as I read:
    A fast-acting preparation for unlocking the piston rings in gasoline and diesel engines. Based on own recipes with the use of BASF components.
    - Removes all deposits and tar deposits from the surfaces of the piston, bushings and rings.
    - Oil change after use is not required.
    - Restores freedom of movement to the piston rings.
    - Cleans sleeves, pistons, combustion chamber, valves from any impurities coming from fuel and oil (carbon deposits, coke, lacquer, tar).
    - Equalizes the pressure in the cylinders.
    - Reduces the emission of harmful compounds in the exhaust gas
  • #13 16480096
    milejow
    Help: 1563
    Rate: 5149
    Strumien swiadomosci swia wrote:
    How could your riding rings stuck, think logically. ????
    The engine is slaughtered but quietly dreams of a miracle,
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #14 16480211
    barteksmrek
    Help: 89
    Rate: 224
    Are the pressure measurements similar on all cylinders? Maybe it has worn out? How many has traveled? What is an oil test according to you? You poured something thick and you know there will be more pressure.
    This is a fiat and the engine you can buy for PLN 500 different and 1.4 liters. This topic makes no sense. Where did you get these trials? Who recommends that? How do you know it's not valves?
  • #15 16480246
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    This is the old way of getting gripped rings after the engine overheats. But this operation should be done right after the overheating took place. And pray that it will help without interference. After some time it is too late and it is not known if it would help right after overheating / grabbing the rings. :D
    I used it once when I lost the coolant and the engine was running but was it kerosene the reason ??? It's hard to confirm. :D
  • #16 16480272
    8850
    Rate: 285
    @arteksmrek Pressure on the cylinders measured from the timing side 12-6-12-12 bar after the oil test 12-12-12-12 bar. 2 times measurement to be sure. Punto 1, Engine 1.1 8V 55KM, mileage approx. 200 thousand. km. PB + LPG Checked with a threaded pressure gauge, warm engine, gas in the floor, all spark plugs unscrewed. Oil test - 15 ml of fresh oil added to each cylinder. Symptoms: oil burns, accelerates poorly, blows into tight mufflers that growl and hum (middle and rear mufflers replaced by a muffler who only does this). The muffler himself suggested that the exhaust system is working and something is wrong with the combustion chamber, so then the compression was measured and he was right.
    And does the oil test rule out, for example, puncturing the compression on the second cylinder (6 bar) through the cylinder head gasket outside the block?
  • #17 16480338
    gimak
    Help: 614
    Rate: 1678
    When the engine runs on gas, I suppose the deposit is already washed away. I had an engine in the south, covered with sediment, and after gassing, after driving about 20 thousand. km all settlements have disappeared. But during these 20 thousand. km I changed the oil three times. I can also say that after the disappearance of these deposits, the compression on the cylinders increased, in fact it went back to the level when the engine was new. Here I suppose there will be something more serious than seized rings.
  • #18 16480351
    hobbista
    Help: 108
    Rate: 173
    The buddy 8850 ring seizure usually occurs on all cylinders. They clog together with the oil control ring. Then the measurement of the pressure is not error-prone, however, the engine consumes excessive amounts of oil and fumes. You have a different situation. You have one cylinder down. Of course, you can flood with kerosene and other specifics. I wish you good luck in these experiments, but I think that you have a mechanical damage to this pot, which will not heal anything. Motor szrot.
  • #19 16480352
    Help: 1405
    Rate: 6430
    It would be audible and not so easy to break through the water mantle on the way.
    Well, look at the workload of thousands of users wasted on the uncertain repair of the 1100cc punt.
  • #20 16480724
    8850
    Rate: 285
    @strumien swiadomosc: this is a group of "beginner cars" and I am writing here, not mechanics and sewers. I remember that the failure on the cylinder was due to the rich mixture loaded in the engine. First, the LPG computer collapsed and it was flooded with gas. I replaced the driver. Then the gasoline pressure valve fell off and gasoline was added to LPG - it also went out and the flat was too rich. I solved both problems but then there was a problem with this cylinder. I suppose that the engine did not overheat even once, the water temperature was always normal, which does not mean the correct temperature in the cylinder.
  • #21 16480731
    Help: 1405
    Rate: 6430
    Then take it and pour kerosene overnight, worse if it gets you into the oil.
  • #22 16480746
    ociz
    Help: 1379
    Rate: 3486
    I was doing something like that with the SC 900 and the effect was good, the oil stopped eating and all the horses came back. Except I had the oil pan removed and used a damper spray. You will never drain all the oil from the bowl, so also what you add there.
  • #23 16480765
    kkknc
    Help: 1915
    Rate: 6709
    After LPG, the engine is clean. So the carbon deposit isn't there. Recently, a colleague in the SC900 quickly put the head to work, the bowl down, the pistons pulled out. Manual honing machine for a drill, because there was almost no trace of it, new rings. And it works. Compression jumped to 11.5 from 6.5-8. It is equal on all cylinders. Oil needs to be added about 0.5l per 2000 km. The engine supposedly had 280,000.
  • #24 16482122
    barteksmrek
    Help: 89
    Rate: 224
    Rolling the subject and punching points.
  • LPG may cause carbon deposits and stuck rings
    #25 16482492
    8850
    Rate: 285
    @kkknc an interesting situation, because if the gas is dry, it should be the other way around that there is carbon deposit because there is no proper lubrication? Unless the higher temperature burns the carbon deposit? At the automotive forum, the guest drove the LPG-powered car and pulled out the seized rings on the pistons (its description):
    https://www.forumsamochodowe.pl/lancer-1-8-20...pg-spalone-zapieczone-pierscienie-vt78865.htm
    Pictures of his pistons with stuck rings:
    http://pl.tinypic.com/view.php?pic=2el3yus&s=8
    http://pl.tinypic.com/view.php?pic=oid36r&s=8
  • LPG burns cleaner than gasoline, keeping oil cleaner
    #26 16482533
    kkknc
    Help: 1915
    Rate: 6709
    And tell me what dry gas is. There is no water in it or what? And wet gasoline because it has water? There the answers are given. And you picked up the first one that suited you. It doesn't matter if it's bad. The important thing is that it suited you. LPG is a clean fuel as opposed to ethylene, not gasoline. A typical LPG contains a mixture of two gases and a fragrance. And of course many other things, but only in trace amounts. However, ethyl is a whole cross-section of everything. After burning, you have lacquer ashes, and I suppose.
    This is clearly visible in the purity of the oil. It is nice and clean on LPG. After 15,000 it looks like 1000km on gas.
  • #27 16483436
    8850
    Rate: 285
    And whether the lack of compression on the 2 cylinder of 6 bars (after the 12 bar oil test) may be caused by a worn valve control plate servicing this cylinder, then the suction valve is not open for too long, or on the contrary? If I can sniff around here, I'll take the keyboard off and check it with a feeler gauge.
  • Gasoline deposits and leaking injectors blamed for ring sticking
    #28 16483449
    gimak
    Help: 614
    Rate: 1678
    The gas does not create a carbon deposit, because it does not have ingredients that would be used to form it under favorable conditions, as it is in the case of gasoline. As no scaling is formed on the gas, the oil is able to wash away the previously deposited sediment. The fact that such deposits are formed, in my opinion, is to blame for the engine, specifically the oil sump blowing on the rings. I came to this conclusion, based on the engines in my cars, viz. My first toddler from mid-74 (Italian engine), 40,000 each km, had a compression of 11 atm, did not take oil, had a hoof that was later comparable to a meganka. The keyboard and the carburetor itself were clean.
    In the second toddler, the compression was 9.4 and 9.2 atm on the new engine, the oil splashed 0.6 liters / 1000 (according to the instructions it could take up to 0.7 liters), compared to its predecessor, sludge and already 20 thousand. km the keyboard was overgrown. It was the same later with FSO1500 and Poldek, but in Poldek after gassing, the sediments disappeared and the compression returned to the one at the beginning.
    Now about gasoline. The former ethiline (leaded gasoline) was better than unleaded in terms of deposit formation. An example for me is the gasoline primer, which used ethylene for about 10 years and was clean inside - no sediment. It was enough that I poured unleaded petrol once and after two days the compulsion stopped working, there was little trouble with taking it apart because it was so overgrown inside. It was impossible to rinse it out, everything had to be scraped, and not everything was accessible.
    In the gassed Corolla I replaced three petrol injectors. The first one was under warranty, so I didn't see it, but the next two fell at the same time, clogged, became carbonized - now when I think about it, I suppose that the reason was that they were leaky and when working on gas they were slightly oozing and slowly overgrowing, I suppose on ethiline would not have happened.
  • #29 16483460
    Help: 1405
    Rate: 6430
    These photos are driving with a damaged air filter and it catches sand and dirt.
  • #30 16483478
    gimak
    Help: 614
    Rate: 1678
    If any valve is propped up (does not close) or is burnt out, there will also be a drop in compression, but the oil test shows the rings (piston-cylinder is not tight). In the past, it was checked where the leak was by connecting compressed air to the cylinder (through the plug hole) with the valves closed and listened to where it hisses or blows - from the oil pan, from the intake or exhaust.
The discussion revolves around the procedure for unlocking seized piston rings in a Fiat Punto 1.1 8V engine using kerosene. The user plans to flood the cylinder with kerosene to dissolve potential carbon deposits causing low compression (6 bar) compared to an oil test (12 bar). Responses suggest that while kerosene may help with soft carbon deposits, modern alternatives like carbon cleaners or engine rinses could be more effective. Some participants express skepticism about the success of this method, citing the age of the engine and the possibility of more serious mechanical issues. The importance of checking valve clearance and the condition of the engine is also highlighted, as these factors could contribute to compression loss. Overall, the community provides a mix of traditional and contemporary approaches to addressing the issue.
TL;DR: Compression under 8 bar reduces engine torque by ~25 % [Bosch, 2015]; “kerosene freed rings only in 1 of 10 cases” [Elektroda, barteksmrek, post #16478356] Pouring 250 ml kerosene overnight may restore seized rings but risks oil dilution and bearing wear.
Why it matters: A €3 kerosene trial can postpone a €500 engine swap if done safely.
• Fiat FIRE 1.1 8V combustion-chamber volume ≈52 cm³ at TDC [Fiat Data, 2002]. • Typical stuck-ring kerosene dose: 200–300 ml per cylinder [Haynes, 2012]. • Engine swap (used 1.2/1.4 FIRE) costs €400–€600 parts + labour [Local Market Avg., 2023]. • Commercial ring-freeing aerosols work in 30 min–2 h and claim 10–15 bar recovery [Xado Data Sheet, 2021]. • Acceptable compression spread: ≤1 bar between cylinders [Bosch, 2015].
Does kerosene really free stuck piston rings?
Sometimes. Soft carbon dissolves in light oils, so a 12-hour kerosene soak can raise compression by 2–6 bar [Haynes, 2012]. Forum users report success was rare: 1 in 10 attempts worked [Elektroda, barteksmrek, post #16478356]
How much kerosene should I pour into a Punto 1.1 8V cylinder?
Fill until the liquid sits just below the spark-plug threads—about 250 ml when the piston rests mid-stroke [Elektroda, 8850, post #16478330]
Do I need to position the piston halfway before filling?
Yes. Mid-stroke maximises soak around the ring pack and prevents overflow into the intake or exhaust tracts [Elektroda, 8850, post #16478330]
How long should the soak last?
Classic method: 12 h overnight, top up, then another 12 h [Elektroda, 8850, post #16478330] Carbon–cleaner aerosols need as little as 30 min [Xado Data Sheet, 2021].
What are the main risks of the kerosene method?
  1. Kerosene leaks into the sump, thinning oil and cutting bearing film strength by 50 % [Total Lubricants, 2020]. 2. Dislodged debris can score cylinder walls. 3. Incomplete drainage can cause hard starts and smoke.
Are modern ring-freeing fluids better than kerosene?
Yes. Formulations combine alkaline detergents and solvents that attack hard coke yet protect aluminium; some require no oil change [Elektroda, 8850, post #16480095]
Low compression on one cylinder—rings or valves?
Oil test jumped from 6 bar to 12 bar, pointing to ring sealing, not valves [Elektroda, 8850, post #16480272] A valve leak shows little change after adding oil [Bosch, 2015].
How do I confirm where the leak is?
Perform a leak-down test: 1. Bring suspect cylinder to TDC on compression. 2. Feed compressed air via spark-plug hole. 3. Listen—hiss in intake means valve, crankcase means rings, tailpipe means exhaust valve [ASE Standard, 2019].
Does running on LPG create or remove carbon deposits?
Propane–butane burns cleaner and leaves near-zero varnish, so long-term LPG use usually washes deposits away [Elektroda, gimak, post #16480338]
What if kerosene seeps into the oil?
Change oil and filter immediately; dilution beyond 5 % can cut bearing life by 60 % [SAE Paper 2014-01-2798].
How do I flush remaining kerosene from the crankcase?
  1. Drain sump hot. 2. Add cheap 10W-40 plus an engine flush additive, idle 15 min, drain. 3. Refill with quality oil and new filter [Haynes, 2012].
Is an engine swap cheaper than rebuilding?
Used FIRE engines sell for about €500; full rebuild with machining often exceeds €900 [Local Market Avg., 2023]. 'This topic makes no sense; buy a 1.4 for PLN 500' [Elektroda, barteksmrek, post #16480211]
Quick 3-step kerosene soak procedure
  1. Set piston mid-stroke; pour 250 ml kerosene through spark-plug hole. 2. Let sit 12 h, rotate crank two turns, top up, soak another 12 h. 3. Drain sump, add flush oil, idle 15 min, drain and refill. Edge-case: abort if kerosene level drops quickly—rings may be cracked.
