Nissan Almera Tino 2000 - Error P1610 Lock Mode: Immo Light Issues, Engine Start, Key Fob & NATS
slevy70 6990 1
  • #1 16479844
    slevy70
    Help: 42
    Rate: 207
    After turning the ignition, the immo lights up red all the time, after turning the ignition off, it flashes, the car does not start. After the first time, it starts and goes out, as soon as I turn the ignition on again, it fires, the engine is running and after a while the red immo indicator lights up permanently. NATS and Motor Diagnosis - One P1610 Lock mode error. In voltage measurements they are correct (permanent and after ignition), while the start permission is OFF.
    Where to start ?
    The key fob does not work either, although it is functional, the synchronization with the 6x on-off procedure, etc., does not work.
  • #2 16481091
    avital
    Help: 10
    Rate: 32
    The first step, the easiest in this situation -
    Obtain the PIN code and perform the key learning procedure with the diagnoscope (it may be Launch) - it restores the lost synchronization at the same time.
