Derbi Senda Xtreme: Loss of Spark After Rain Exposure and Engine Shutting Off During Ride
Michu7563 7548 6
  • #1 16480544
    Michu7563
    Hello!
    My problem is that when I recently drove the Santa, which I parked in front of the house and after some time it started to rain heavily and it was raining all over the electrics and everything. I got in, it fired normally, I drove maybe 3 km and suddenly it went out while driving. I was surprised, I tried to fire again and it fired normally, I drove with 500 m and went out again. I took her to the garage. The next day (it was already dry outside) he tries to fire it. Normally it fired, I drove 1.5 km and I turned it off after a while I wanted to light it, it lit it for a moment and then it went out. The next day it tries to light it and it fired for a while and then it went out. Before firing, I checked if there was a spark and it was there, but after firing, when I checked the spark again, it was gone.
  • #2 16481579
    BANANvanDYK
    Help: 1167
    Rate: 2602
    What ignition? Leonelli, Ducati or Kokusan?
    I would start with disconnecting the extinguishing from the module, depending on the type of ignition it is solved differently.
    It is very possible that it flooded the ignition switch, ignition switch or installation and the resulting breakdown cuts the spark.
    Otherwise, there could be a damage to the power coil on the stator (interturn short circuit), it would be a coincidence with this rain, you can only diagnose it with a meter.
  • #3 16482334
    Michu7563
    Ignition ducati energy
  • #4 16483508
    BANANvanDYK
    Help: 1167
    Rate: 2602
    This is why you disconnect the cable from the "stop" terminal of the module's coil, or in the second version, the plug with two wires (green, yellow) between the stator and the electrical installation.
  • #5 19642351
    Mateusz154
    I did it and it has a spark, what can I connect it and it will be a spark or something
  • Check the kill circuit wiring for corrosion and shorts
    #6 19642414
    rafik54321
    Level 30  
    Help: 158
    Rate: 285
    And how do you turn off the bike afterwards? Shifting into gear, holding the brake, and releasing the clutch until you stall the engine? :P
    You just know that you have a fault somewhere in the extinguishing circuit. That is, to check the wires from the module, through the steering wheel switch (if any) to the ignition switch, and finally to the ground :) .
    Nobody will tell you any more. Look for signs of corrosion, such white raid, muck, water, etc. All cubes, connectors on the way also to be checked.
  • #7 19642420
    Mateusz154
    Well, only that is the magneto is ok, the module also only a beam and ignition switch and mass I know that at the back I have something unfastened that there are two black cables on the back on the screw and I do not know what it is for
The discussion revolves around a Derbi Senda Xtreme experiencing a loss of spark after exposure to rain, leading to engine shutdowns during operation. Users suggest potential causes, including issues with the ignition system, specifically the Ducati Energy ignition module. Recommendations include disconnecting the extinguishing circuit, checking for water damage in the ignition switch, and inspecting wiring for corrosion or loose connections. The importance of diagnosing the power coil on the stator is also highlighted, as it may be affected by moisture, leading to intermittent spark loss.
