Audi A3 8p 2007: Clutch Pedal Slow Return, Possible Grinding - Causes & Solutions to Consider
Maniekpolo 14472 2
  • #1 16481034
    Maniekpolo
    Rate: 12
    Hello. I have a problem with my car, namely the clutch pedal. Namely, once every 10-20 times the pedal "comes back" very slowly and can grind in the crate, and it happened two or three times that I had to pull it up with my foot. The clutch itself works flawlessly, it catches virtually from below. Toy car is a3 8p 2007. Where to look for the reason? Clutch / pedal pump in itself or is it likely to be a clutch in the box? Regards
  • #2 16481245
    marci4
    Help: 169
    Rate: 177
    Typical damage in this model. It is best to replace the set - the clutch pedal (or the pump itself - Master Cylinder), as well as the slave cylinder (slave cylinder) because it likes to fall and the cost is not that big.
    Write what engine and gearbox you have. In some, access to the slave is from outside.
  • #3 16481254
    Maniekpolo
    Rate: 12
    BKD engine, HDV gearbox with an island in the middle, unfortunately.
