Retrieving Windows 10 License Number After Disk Failure on Toshiba Upgraded from Windows 8
pcnet 5280 7
  • #1 16481532
    pcnet
    Level 32  
    Help: 11
    Rate: 217
    Laptop purchased from windows 8. It has a sticker but no number. Then it was made via the internet upgrade to win10. The disk has failed and is installing new windows 10.
    Where to get the license number?
    PC-NET
    Słonecznikowa 6B, Częstochowa, 42-224 | Company Website: https://agapo.pl
  • #2 16481551
    Matuzalem
    Help: 1653
    Rate: 1101
    There is no possibility or need. If the key prompt appears, choose "I don't have the key ...", activation will take place on the march (after connecting to the network and logging into the Microsoft account.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #3 16482461
    pcnet
    Level 32  
    Help: 11
    Rate: 217
    and how is win10 with a local account?
    PC-NET
  • #4 16482531
    Matuzalem
    Help: 1653
    Rate: 1101
    This should not bother you (in the worst case telephone contact will be needed - however, the probability is negligible).
    It does not change the fact that - in your case - the Windows 10 key that can be read from the system is not individual and on its basis it is impossible to activate the system.
    Doradztwo podatkowe
  • #5 16482561
    pcnet
    Level 32  
    Help: 11
    Rate: 217
    what is it about? I thought it was stitched somewhere in the bios
    PC-NET
  • #6 16482695
    Matuzalem
    Help: 1653
    Rate: 1101
    It is, but in this case from Windows 8.
    Doradztwo podatkowe
  • #7 16551626
  • #8 16551892
    pcnet
    Level 32  
    Help: 11
    Rate: 217
    For me it went without a problem alone
    PC-NET
The discussion revolves around retrieving a Windows 10 license number after a disk failure on a Toshiba laptop that was upgraded from Windows 8. Users suggest that if the Windows 10 activation prompt appears, selecting "I don't have the key" will allow for activation via a Microsoft account once connected to the internet. It is noted that the Windows 10 key is not unique and cannot be used for activation. The Windows 10 license should activate automatically during installation, especially if the upgrade was legal. Users recommend checking the motherboard's serial number for activation and mention that a simple program can be used to retrieve the current serial number.
