Toshiba Windows 10 Restart Issue - CRITICAL_SERVICE_FAILED Error Post-Update
bulbulatrix 5229 1
  • Suggesting offline repair to avoid factory reset
    #1 17397432
    bulbulatrix
    Same as the subject, but the problem with Toshiba: suddenly the computer restarted (there was an update in the background) and the CRITICAL_SERVICE_FAILED error screen appears notoriously.
    Previous actions from the Troubleshoot menu:
    1. System restore - no options.
    2. Repair during startup - error - refers to the log file
    3. Command line - the REGBACK method did not work.
    4. Various modes of emergency start and without registry etc. - restarted in option F7 (Disable driver checking enforcement) despite the fact that no new driver has been uploaded for a long time, except Windows Update of course. Restarting continues with the same error.
    5. Restore previous build - an error has occurred and refers to Reset settings to initial state.
    I prefer to avoid such a reset, especially since I don't have a USB with the system (it was updated online from pre-installed Windows 7)
    Do you have any ideas on how to solve this?
  • #2 17397444
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    Run in "F7" mode and dump recently installed windows update.
