Integra 64 Alarm System: Disabling Sound on INT-KLCDS-GR Keypad and Other Signals
losadamos 21717 7
  • #1 12452802
    losadamos
    Rate: 13
    I have an alarm installed in my house (integra 64, keypad INT-KLCDS-GR) with 2 zones.
    Is there any possibility to completely disable the sound on one of the keypads (not only the sound of the keys but also other signals) ?
    Read also: Satel Integra -. system configuration - Selected topics Selected most interesting topics about configuring the Satel Integra system Outputs (programmable and otherwise) of alarm panels How the control panel alarm outputs work
    Connecting any detector to any control panel - a tutorial
    How to connect a siren to a control panel -. tutorial
    Types of outputs of the Integra control panel, that we use for home "automation"
    Furnace C.O. - Integration with alarm (e.g. Satel Integra) ETHM 1 Plus/ Integra Control. Selected issues.
    Please check out our other tutorials, featured topics, articles, in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Guides dot. security systems
    If you do not find an answer to your question in the above topics, feel free to visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from the other sections of the forum, including those for people beginning their adventure with electronics:
    General Guides
    Alberciak
    Help: 41
    Rate: 60
    There is an option. TS-> Structure-> Manipulators-> Settings -> you select the keypad you want to program and uncheck the entry and exit time signaling, and key sounds.
  • #3 12936309
    Piorun2002
    Rate: 25
    And is it possible in this keypad (INT-KLCDS-xx) to change the volume of the buzzer - in other keypads it is possible to do it from the menu, but in this one there is no such option.
    Maybe there is a patent like a jumper / resistor ?
  • #4 12936914
    bhtom
    Help: 446
    Rate: 604
    Piorun2002 wrote:
    resistor ?
    if any more, then with a resistor ;)
    You can try to seal the buzzer with insulating tape - it should help
    Greetings.
  • #5 12948051
    humek
    Level 32  
    Help: 170
    Rate: 164
    What resistor and why tape it ? In the options of the keypad in INTEGRA you have everything you need friend. You can adjust both the buzzer volume and whether it should signal exit time (separately) and entry time and alarm signaling.Everything can be set separately for each keypad.
  • #6 12953772
    Alberciak
    Help: 41
    Rate: 60
    Fellow HUMEK, this keyboard model does not have a buzzer volume control
  • #7 12960463
    Rysiek2
    CCTV and Stationary Alarms specialist
    Help: 447
    Rate: 659
    ...The sealing patent works, I also recommend it.
  • #8 12964058
    Piorun2002
    Rate: 25
    bhtom wrote:
    You can try sealing the buzzer with insulating tape - it should help.
    No here you surprised me, panten simple as cep construction but it works great :-) , THX
    I still have a question about the display itself, previously I had CA-10, there the Manipulator signaled on the fly which detectors are violated (without entering the test menu).
    Is it possible in this manipulator to set the display so that the status appears, for example, instead of the name of the manipulator - I went through all the menu options, but I could not do it.
The discussion revolves around the Integra 64 alarm system and the INT-KLCDS-GR keypad, focusing on the possibility of disabling all sounds, including key sounds and other signals, on the keypad. A solution is provided where users can navigate to TS -> Structure -> Manipulators -> Settings to uncheck entry and exit time signaling and key sounds for the selected keypad. However, it is noted that the INT-KLCDS-GR model does not have a built-in option to adjust buzzer volume, leading to suggestions such as using insulating tape to muffle the buzzer. The conversation also touches on the display functionality of the keypad, with users inquiring about the ability to show detector status directly on the display.
