Kia ceed 2011: Understanding the Low Tire Pressure Indicator System & ABS Connection
autoas 11964 5
  • #1 16482640
    autoas
    Help: 571
    Rate: 3924
    Hello!
    Someone could tell what the system is there, should there be sensors (which are not in this car ...) whether the system works with ABS
    There is only a tire indicator on the board with an exclamation mark that blinks ...
    Or maybe there is a "learning" button somewhere ...
    Best regards!
    srbastek
    Rate: 38
    I am sure you will read this information from the user manual.
    koala106
    Help: 471
    Rate: 1240
    Wheel sensors.
  • #4 16482688
    autoas
    Help: 571
    Rate: 3924
    The customer claims that he changed tires and in the workshop they said that there are no sensors .... he bought such a car and now he came to me for diagnostics but I only have an autocom to KIA and he does not detect the TPMS system (only I do not know if there is it or autocom yes has ... that it doesn't detect :) )
    koala106
    Help: 471
    Rate: 1240
    I just have ceed - only 2015 and the workshop also claimed that there are no sensors. I found out how I bought second rims and put on summer tires - after 30 km the light came on. A new set of sensors around 800. In 2011 they require coding, in newer they code themselves.
  • #6 16482738
    autoas
    Help: 571
    Rate: 3924
    So anyway he must have sensors and hi .....
