VW Tiguan 2015 2.0 TDI CUV: Error Codes 01325 & 17670 - Tire Pressure & ABS Sensor Issues
kantor8 20178 7
  • Missing TPMS controller communication in ABS module
    #1 16574502
    kantor8
    Rate: 15
    Hello, in VW Tiguan 2.0 TDI CUV 2015 engine I have error codes:
    Diagnostics done by VCDS:
    1.
    In group 3, I have a tire pressure error. The error code indicates no communication with the controller. There were no pressure sensors in the wheels. I assume the ABS system is reading the rolling resistance of the wheel or something similar. In the front right wheel, I replaced the abs sensor. I bought the car with the right wheel damaged. No other bugs shine. in the ABS block.
    In the Instruments group, it can be turned off so that it does not indicate an error on the meter. However, after a VCDS diagnosis, the fault still remains in the ABS block. Does anyone know how to turn it off permanently or maybe some hint where to look. Maybe someone has a schematic from Elsa ??
    Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
    Control Module Part Number: 5N0 614 109 BN HW: 5N0 614 109 BN
    Component and / or Version: J104 C6 450M VDA3 0021
    Software Coding: 0054593
    Work Shop Code: WSC 01357 011 00200
    VCID: 78FF82860B12618298-802C
    1 Fault Found:
    01325 - Control Module for Tire Pressure Monitoring (J502)
    004 - No Signal / Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 163
    Mileage: 62,205 km
    Time Indication: 0
    Date: 2017.06.29
    Time: 00:10:19
    Freeze Frame:
    Speed: 0.0 km / h
    Hex Value: 0x0000
    Bin. Bits: 00000000 00000000
    Voltage: 12.50V
    Bin. Bits: 00011111
    Count: 191
    Hex Value: 0x0000
    Friday, 07 July, 2017.21: 07: 07: 49450
    VCDS Version: Release 16.8.0 Running on Windows XP x86
    www.Ross-Tech.com
    Address 01: Engine Labels: 04L-907-309-V1.clb
    Control Module Part Number: 04L 906 016 CN HW: 04L 907 309 K
    Component and / or Version: R4 2.0L EDC H20 1843
    Software Coding: 01250032043611082000
    ASAM Dataset: EV_ECM20TDI01104L906016CN 001004 (VW36)
    ROD: EV_ECM20TDI01104L906016CN.rod
    VCID: 77FD81BACE0C6EFA91-8022
    2. A sensor / brake switch fault appears in the engine block. The car has a DSG gearbox - 7 speed. 4x4 version. There is no stop sensor on the brake pedal. There is a 3-pin plug under the ABS tank. Only that after disconnecting this plug the "stop" lights work normally. Someone knows which sensor it is and where it is.
    1 Fault Found:
    17670 - Brake Switch (F)
    P0572 00 [167] - Short to GND
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 62,390 km
    Date: 2016.14.31
    Time: 20:58:26
    Engine speed: 909.00 / min
    Normed load value: 0.4%
    Vehicle speed: 26 km / h
    Coolant temperature: 74 ° C
    Intake air temperature: 66 ° C
    Ambient air pressure: 960 mbar
    Voltage terminal 30: 14.180V
    Unlearning counter according OBD: 40
    Requested transmission torque: 1000.0 Nm
    Limitation: accelerator pedal: 0.0 Nm
    Cruise Control System (CCS): Status-Bit 0: 0
    selected gear-Bit 0: 3
    Engine control module reset status-Bit 0: 0
    Engine control module reset status-Bit 8: 0
    Transmission torque intervention status-Bit 0: 0
    Transmission torque intervention status-Bit 8: 80
    Calculated reducing transmission intervention torque: 1000.0 Nm
    Readiness: 0 0 0 0 1
    3. In VCDS error codes, this error does not appear. But it shows on the meter. Start / Stop failure. could the reason be that I installed a 72Ah battery from the usual version. That battery costs a lot, about PLN 600.
  • #2 16574572
    Heroses
    Help: 71
    Rate: 160
    check what the engine sees, how you press the stop and what abs sees if the signals match. Check the coding if someone did not want to get rid of TPMS
  • Brake switch low-voltage suspected in ABS fault
    #3 16574615
    kantor8
    Rate: 15
    Can you get a little brighter ??? I understand that he should check the Measuring Blocks parameters after pressing the brake both in the address 01-motor and address 03 - ABS.
    Read more on the website https://www.yourmechanic.com/article/p0572-ob...rake-switch-a-circuit-low-by-valerie-johnston
    that the error may be due to a low voltage on the Brake Switch sensor. Except I don't know which sensor it is.
  • #4 16711419
    kantor8
    Rate: 15
    Hello, the car has already been visited by many specialists but still nothing. I reheat the topic of errors. I still have an error in the motor group, but the error is in the brake switch.
    Can anyone tell me which sensor it is, where to look for it
    In the ABS group in the measuring blocks we have the BLS OFF function (F sensor) - it is always on OFF, even when the brake is pressed. When the brake is applied, the pressure in G201 increases. The bell is that after unplugging the pressure sensor on the brake pump, the pressure continues to change when the brake is pressed.
    I have no idea where to look for this Brake switch F
    I am asking for any specific advice.
  • #5 17090049
    hrabia michał
    Rate: 11
    Hello TMPS error badly coded counter from the brake sensor fault no connection between the BCM and the engine control unit check the wiring
  • #6 17090166
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    On the master cylinder.
  • #7 17102129
    hrabia michał
    Rate: 11
    not on the pump, only in the meter, enter the phone number, I will explain what and how or call 608 174 504 greetings
  • Asking whether Audi TPMS disable procedure fits Tiguan
    #8 20454461
    gluzab
    I have the same problem with tire pressure in Tiguan -01325 system (J502), 004- no communication.
    I checked the harness only visually, Appearance OK. Szpece said that the ABS should be replaced with the controller.
    I wanted to try turning off the tire pressure checks but I'm not sure how to do that???
    A colleague wrote that it was a display coding error, but no one was messing with it.
    Please help I have vcds ACP 21.3.0
    Regards GB[/table]
    I found the procedure for disabling TPMS Control on YT. this is for the Audi A6,
    https://youtu.be/5zDFqi0CgP4
    Can this be adapted to my Tiguan 2012 Lift?
The discussion revolves around error codes 01325 and 17670 in a 2015 VW Tiguan 2.0 TDI CUV, indicating issues with tire pressure monitoring and the ABS sensor. Users report a lack of communication with the tire pressure controller and persistent ABS errors despite replacing the ABS sensor. Suggestions include checking the brake switch sensor for low voltage, inspecting wiring connections, and verifying coding settings. Some users seek methods to disable the tire pressure monitoring system (TPMS) and inquire about specific sensor locations and troubleshooting steps.
