Renault Kangoo 1.5 Dci 2008: Air Conditioning Inoperative Despite Functional Clutch and Coil
rylik91 12405 18
Why does the air conditioning on a 2008 Renault Kangoo 1.5 dCi not engage even though the clutch, coil, refrigerant charge, and pressure sensor seem OK?
The air conditioning was ultimately not working because the engine controller/ECU was damaged; after the ECU repair, the A/C worked normally again [#16828845] Before that, the useful diagnostic clue was that the second radiator fan speed did not start, so that circuit should be checked as part of A/C enable logic [#16487851] One user also noted that on similar Renaults, the A/C switch panel wiring or the A/C request circuit can break and prevent compressor engagement [#16487283]
  • #1 16484258
    rylik91
    Help: 5
    Rate: 101
    Hello crew, I have a problem with the Renault Kangoo 1.5 Dci 2008, the air conditioning is not working. The clutch and coil are operational. The valve, the clutch, sticks and the air conditioner cools elegantly. Now a bit of theory, air conditioning checked and loaded, the ear is well programmed sees the car with the air conditioning, when I turn the Ac knob, the fans start, but the pressure sensor value does not increase. The pressure switch I changed the same. Temperature sensor shows fine. There is no control on the coil from the relay, the fuses are checked. The engine controller does not give the weight to the relay and therefore does not turn on the air conditioning, but where the reason, only what I noticed, does not turn on the 2nd fan speed, but that it would have such an impact ?? There are no errors in the ECU. Has anyone had a similar case or can help? Thanks in advance for any suggestions ;) Greetings!
  • #2 16484274
    szymitsu21
    Help: 343
    Rate: 1300
    can the clutch run in tests?
  • #3 16484329
    rylik91
    Help: 5
    Rate: 101
    Not really, because it crashes a test error, is it a Clip. Kts, Delphi
  • #4 16484598
    szymitsu21
    Help: 343
    Rate: 1300
    And what are the parameters?
  • #5 16484599
    rylik91
    Help: 5
    Rate: 101
    The pressure of 5 bar sees and the power of the compressor is 400 W too, the temperature sensor shows well.
  • #6 16485357
    milejow
    Help: 1563
    Rate: 5150
    rylik91 wrote:
    when I turn the Ac knob the fans start
    What fans are you writing about, is there one on the coolers?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #7 16485456
    rylik91
    Help: 5
    Rate: 101
    Milejow ordinary typo, you would write something that will help, maybe you know where the diode is located on the compressor installation?
  • #8 16486926
    milejow
    Help: 1563
    Rate: 5150
    Inside the wiring harness, about 20 cm from the box under the hood, from which the beam comes out at the bottom, but there is no fault in it, it only extinguishes the arc on the relay.
    In drawing No. 322.
    After the air conditioning is turned on, the condenser fan starts blowing, right?
    To start the air-conditioning, you need the correct pressure of the medium, the correct engine temperature, and no significant and dangerous faults for the engine, if this is met, there is no whip, the air-conditioning must start.
    • S44.pdf (457.19 KB) You must be logged in to download this attachment.
    Działalność własna
  • #9 16487083
    tomasz0703
    Help: 69
    Rate: 490
    Why don't you focus on the second fan speed?
  • #10 16487092
    milejow
    Help: 1563
    Rate: 5150
    Because this will turn on when the pressure exceeds 20bar.
    Działalność własna
  • #11 16487283
    celestyn6
    Rate: 74
    I had a similar problem in C4. It turned out that the air-conditioning switch had a break on the second circuit in the control panel. Check according to the panel output diagram.
  • #12 16487340
    Aleksander_01
    Help: 1167
    Rate: 3436
    Right. What you see is done, not theorized.
  • #13 16487851
    milejow
    Help: 1563
    Rate: 5150
    So now write, as a result of which you believed that the fan is not working in the second gear ??? He did not check it on the air conditioning because the compressor is not making pressure and somehow I do not see him wrote that he warmed up the engine until the fan turned on. Somehow I did not read about the performance test of the fan. In addition, this controller completely ignores the condition of the radiator fan (it controls but does not control), the factor pressure and engine temperature are important for it. No equipment is needed to check the second speed of the fan, just unplug the ECT and turn on the ignition.
    Działalność własna
  • #14 16488529
    genek1000
    Help: 289
    Rate: 1057
    Gentlemen, we are talking about Kangoo I or Kangoo II :?: Because this is a fundamental difference :D
    As for one, probably the injection controller is "grafted" from the version without "AC" or there is an incorrect reading of one of the parameters that affects the permission of the additional engine load by the compressor. Errors are not budut and air conditioning is not budut :cry:
  • #15 16490194
    milejow
    Help: 1563
    Rate: 5150
    genek1000 wrote:
    or there is an incorrect reading of one of the parameters affecting the permission of the additional engine load by the compressor.
    In this case, the fan will also not turn on and the author writes that after turning on the AC, the compressor starts on the first gear, only the compressor is silent, the second thing is that none of us knows the actual state that exists in the car.
    Działalność własna
  • #16 16490754
    genek1000
    Help: 289
    Rate: 1057
    With this fan that it will not turn on if there is no permission, it is different. :| I know various cases of software being kicked by engineers to such absurdities that in the absence of pressure in the air conditioning (no refrigerant), the controller normally allows the compressor to work and runs everything dry. This is just a fairy tale :cry:
  • #17 16492596
    rylik91
    Help: 5
    Rate: 101
    Gentlemen, Hello, it is impossible to make an executive test of the air conditioning clutch, I tried to do a test of the second speed of the fan and this one does not start, the first one without problems. I repeat. The car in the controller sees that the air conditioning is working and the car with the air conditioning is coded in the option. What is the driver's copying, how the air conditioning worked without problems! I gave the ECU to check, we'll see what comes out of it.
  • #18 16494362
    genek1000
    Help: 289
    Rate: 1057
    rylik91 wrote:
    19 May 2017 06:28 Topic author Kangoo 1.5 Dci 2008 - Air conditioning does not turn on
    rylik91 wrote:
    24 May 2017 07:58 Topic author Re: Kangoo 1.5 Dci 2008 - Air conditioning does not turn on
    For a split personality, sorry, but I will not help :cry:
    Maybe an exorcist - but it's probably not on this forum :D
    Besides, I did not write about this particular case, but I know such cases of copying the software in the factory that contradicts the logic of operation :cry:
  • #19 16828845
    rylik91
    Help: 5
    Rate: 101
    Hello, I meant that when the relay is outside, the air conditioner works, the engine controller was damaged, after the repair of the ECU, the air conditioner flashes nice, thank you all for your help. best regards
The discussion revolves around a malfunctioning air conditioning system in a 2008 Renault Kangoo 1.5 Dci. The user reports that while the air conditioning clutch and coil are operational, the system fails to cool effectively. Despite the air conditioning being properly charged and the pressure sensor showing low values, the ECU does not activate the relay for the air conditioning. Various suggestions are made, including checking the second fan speed, the pressure switch, and the ECU for potential faults. The user later discovers that the issue was related to a damaged engine controller, which was repaired, allowing the air conditioning to function correctly again.
