Renault Trafic 2.5 dci: AC Not Functioning, Zero Voltage to Compressor Coil
rutek79 27273 8
  • #1 17262690
    rutek79
    Gentlemen, the car as in the subject. The climate is not working. No voltage to the compressor coil. Does anyone have a diagram or description which relay and fuse are for this, is it possible that the bundle has been released somewhere
  • #2 17262704
    uzi14
    Rate: 11
    Which year of the car? Air conditioning fully loaded? Does the button light up from turning on the air conditioning?
  • #3 17262733
    decybel91
    Help: 1024
    Rate: 4232
    Connect to the computer and erase the errors in the engine ecu - if it is on the pressure of the refrigerant, the air conditioning will start. If not in the parameters, you have the permissions to start the air-conditioning
  • #4 17262753
    rutek79
    The climate is packed. 2007. Just when I turn on the button, it seems to me that it lights up on the panel. But the sun was shining in him so much that I could not see well. It is in the motor parameters as an enable
  • Check fuses, relay, and pressure sensor signal
    #5 17263189
    uzi14
    Rate: 11
    You have these elements from Klima. Under the hood. Plate fuse
    Normal fuse
    And the compressor relay.
    Check the fuses and if they are ok, open and turn on the relay. Check if it has voltage. When you turn on and the compressor works, you will check if there is a signal to the relay. If not, check with the computer that the air conditioning pressure sensor is not lying.
    The element marked in red
    • Renault Trafic 2.5 dci: AC Not Functioning, Zero Voltage to Compressor Coil WP_20180607_001.jpg (2.28 MB) You must be logged in to download this attachment.
    • Renault Trafic 2.5 dci: AC Not Functioning, Zero Voltage to Compressor Coil WP_20180607_002.jpg (3.09 MB) You must be logged in to download this attachment.
    • Renault Trafic 2.5 dci: AC Not Functioning, Zero Voltage to Compressor Coil WP_20180607_003.jpg (3.33 MB) You must be logged in to download this attachment.
  • #6 17264136
    rutek79
    So no permanent plus on compressor relays. Klima works right away for a short time
  • #7 17264489
    uzi14
    Rate: 11
    How standing? Did you turn on the relay manually or what? If there is no permanent plus on the relay, the fuse is marked as normal. And if there is no signal (the signal is rather mass, it will be from the ECU), check in the engine controller if it shows the pressure. (write how you passed, checked this plus) and what about this button from Klima lights up?
  • #8 17264538
    rutek79
    The button from the air conditioning is on. The fuse is good, of course, and the current goes from the fuse to terminal 30 of the air conditioning relay. In the section from the fuse to the relay, a plus was lost somewhere. I think the cable is rotten. I found a diagram and the air-conditioning relay has a constant plus on terminal 30 coming from the fuse box and then to the battery. So the one I wanted, so I briefly gave + to terminal 30 of the relay and the Climate came to life. Everything works as it should. The compressor turns on and off. Fans too. So, in order not to disrupt half of the car, I pulled out the ori fuse and put on this cable, which gave a plus to the relay a 10A fuse and that's it. Everything works as it should. I soldered the tips and it works
  • #9 17266053
    uzi14
    Rate: 11
    Well done. May it work as long as possible. Make sure the fans are running because we are hot. best regards
The discussion revolves around a Renault Trafic 2.5 dci with a malfunctioning air conditioning system, specifically noting zero voltage to the compressor coil. Users inquire about the year of the vehicle and the functionality of the AC button. Suggestions include connecting to the engine ECU to clear errors related to refrigerant pressure, checking fuses and relays under the hood, and verifying the voltage at the compressor relay. The author later identifies a loss of voltage between the fuse and the relay, ultimately resolving the issue by providing a direct power source to the relay, allowing the AC system to function correctly.
