Opel Astra J 2010 1.4 140KM - P0299 Turbine Error, Squeaking Sound During Acceleration
piotr10005 15972 3
  • #1 16485020
    piotr10005
    Rate: 34
    I have astre J 1.4 140KM from 2010.
    Recently I was traveling, the `` car breakdown '' light came on - contact service
    The car lost some power, after extinguishing everything went back to normal with power, but when starting it sounds like a louder squeaking (every time) and when adding gas for 1 s, you can also hear a very gentle squeaking during acceleration from the very bottom. (1000 revs - 3000 revs).
    After connecting to the computer there is a P0299 turbine error - undercharging.
    With this squeaking I drive for 2 weeks (mainly a 50 km route once) the car behaves perfectly, just squeaks, today the car failure light is on again
    I can't diagnose this squeaking, it seems to me from the intake manifold but I'm not sure because it carries around the car.
    The V-belt was removed and still squeaks.
    Did any of your honorable colleagues have such a case. Thanks for the answer.
  • #2 16485490
    decybel91
    Help: 1024
    Rate: 4232
    The description shows that you have a leak on the way turbo-wires-intercoller-suction manifold.
  • Loose spark plug caused squeak and recurring P0299
    #3 16504531
    piotr10005
    Rate: 34
    Squeaking eliminated, it turned out that the candle was not tightened.
    To be sure, I replaced the candles because the error returned P0299.
    Earlier, the message '' car breakdown .... '' was displayed once a week
    Now error P0299 appears after driving 2-5 km. and the display shows and goes into safe mode.
    I checked all connections and they seem ok
    does anyone have any idea what to look out for?
    and why after tightening the candle error occurs so often?
  • #4 16594348
    piotr10005
    Rate: 34
    Problem solved,
    diaphragm in the valve cover + valve in the intake manifold, regeneration 700 PLN :(
