Opel Astra H GTC Z19DTH - Error P2279 - sometimes cuts off the turbo, sometimes
skaxx 15681 16
How should I diagnose intermittent P2279 on an Opel Astra H 1.9 CDTI when the car sometimes goes into limp mode and loses boost?
Check the intake and vacuum control system for leaks and test the turbo variable-geometry control valve before buying another turbo. One reply recommends making dynamic logs with the current parameters and physically observing the engine response, starting with a careful inspection of the intake system [#16820025] The valve in question is not a sensor but a solenoid valve controlling the variable turbine geometry; a leaky hose behind it can cause the same symptoms, so the vacuum should be measured and the valve can be swapped temporarily with another car to test it [#16825056] [#16825112] The part numbers mentioned for the valve were ENT830025 or 7.01420.02.0 [#16825056] A later report on the same 1.9 DTH family said P2279 was ultimately caused by a damaged DPF pressure-sensor hose/cable, which led to a clogged DPF; after replacing the hose and cleaning the DPF, the errors disappeared [#19643477]
  • #1 16819977
    skaxx
    Rate: 16
    Hi. One time, the turbo began to cut off, the car went into emergency mode, lost power and white smoke flew from the back. The mechanic said turbo. I changed the turbo - the power came back with one problem. There are days when I enter the emergency mode again, the car loses power completely - it often happens when I let go of the gas / stop. Engine reset, I will drive a bit and again .. Then suddenly a dozen days comes, when it is totally ok, full power, acceleration and everything as it should. On the computer he showed me P2279. Maybe it is a flexible hose somewhere from the inlet, which once goes well and once so that the air can escape some leak?
    The second thing. I wanted to go chip the car. The tuner wrote to me that it's nice to check EGR and intake flaps beforehand. I don't know anything about automotive electromechanics - so the question is how to check the efficiency of these two elements?
    If someone is to recommend a good mechanic from Poznań or from the surrounding area, I am asking for advice.
    Best wishes.
  • #2 16819982
    sk700
    Help: 173
    Rate: 420
    This tuner has a dynamometer? If so, he will diagnose the car himself before changing maps, unless he is a bouncer. Unless there is no dynamometer, this is the second option.
  • #3 16819988
    skaxx
    Rate: 16
    tuneforce.pl
    I planned here. Well, but in front of the chip, however, I would rather understand what this leak.
    sk700
    Help: 173
    Rate: 420
    So they have dynamos. You would have to mumble in the inlet with the computer closed and a view of the current parameters. For quick assessment of these components, all you need is dynamic logs that can be controlled from under the dignoscope and physical observation of the reaction. Start by looking carefully at the arrival. The error can also be caused by a problem with the variable geometry of the turbine or its control.
  • #5 16824515
    skaxx
    Rate: 16
    Yesterday the mechanic said it could be n75. I was looking for this sensor in an Opel store and intercars and I can't find it. I know this is a turbine vacuum sensor and I found something on the intercars for 270 gross, but I don't know if this is it. Could someone more in the subject send a link to this part in an Opel store or intercarsie or some other store? I saw something on the Allegro for PLN 100 but I don't think I trust it.
  • #6 16825020
    sk700
    Help: 173
    Rate: 420
    This is not a sensor but a solenoid valve to control variable turbine geometry. I don't remember how in this engine but it happens that there are two the same valves controlling different functions and they can be replaced to check if it is working properly. If you want to buy it rather a stimulant because new original ones are very expensive and substitutes if they already exist are the same lottery as stimulants.
  • #7 16825037
    skaxx
    Rate: 16
    And if I can ask you - if you find a moment, would you locate this solenoid valve at an Opel / Intercarsie store?
  • #8 16825056
    sk700
    Help: 173
    Rate: 420
    According to catalog ENT830025 or 7.01420.02.0
    It is safest to read the numbers from the current valve and select a replacement based on them.
    In your place I would change for a moment even from another car because no one will give you a guarantee that it is just this wine, so if it turns out that it will not help, however, it is a waste of money.
  • #9 16825092
    skaxx
    Rate: 16
    Thanks, it only costs PLN 180? ;about
  • #10 16825096
    sk700
    Help: 173
    Rate: 420
    skaxx wrote:
    does it cost only PLN 180? ;about
    Such a customer is a treasure :D
  • #11 16825108
    skaxx
    Rate: 16
    haha :D Seriously - I thought it was PLN 300. And the original probably above 500?
  • #12 16825112
    sk700
    Help: 173
    Rate: 420
    Unfortunately, I don't know the ASO prices. This valve is just one of the suspects, a leaky hose behind it can also cause such symptoms. Was the vacuum measured?
  • #13 16825115
    skaxx
    Rate: 16
    Unfortunately, we didn't measure any pressure. The mechanic looked at the intake system and did not notice any hole .. The strangest thing is that the last 2 weeks I have no problems - the car is going very well. But, for example, when I was going to the graves it was a tragedy, it still cut off the turbo and I had probably 15 horses in this car. I did the engine reset, it was good for a minute and it fell into emergency mode again. Now this problem does not occur. No random overall.
  • #14 16825123
    sk700
    Help: 173
    Rate: 420
    You were more like a fairy than a mechanic :) Almost every mechanic has a familiar familiarity where he has a system that takes parts and if he doesn't like it, he gives back without any problem. This is very useful in cases where without changing parts it will be hard to find the culprits.
  • #15 16826730
    skaxx
    Rate: 16
    And these valves that you sent me will be ok quality or is it rather a lottery?
  • #16 16827045
    sk700
    Help: 173
    Rate: 420
    They should work, in case there is still a guarantee ... Replacement like any replacement, do not expect miracles.
  • DPF pressure sensor hose caused P2279 fault
    #17 19643477
    Stachu2071
    I have a Zafira B 1.9 DTH. I also struggled with P2279 for over a month. Removing the flaps from the manifold did nothing, as well as removing and sealing it, cleaning the EGR, throttle, etc. The culprit of all the confusion was the DPF pressure sensor cable shot through which the DPF did not burn out and clogged so that after replacing the hose, the pressure difference was over 80 kPa, i.e. 800 mbar. Cleaning the DPF with a home-made method with a pressure washer helped. DPF parameters as new. All errors are gone. I recommend replacing the original hoses with those from FMIC because they are several times cheaper and better
The discussion revolves around an Opel Astra H GTC Z19DTH experiencing intermittent turbo cut-off and entering emergency mode, indicated by error code P2279. The user replaced the turbo but continues to face power loss, particularly when decelerating or stopping. Suggestions include checking for air leaks in the intake system and assessing the EGR and intake flaps before chipping the car. A potential issue with the N75 solenoid valve, which controls the variable geometry of the turbo, is also mentioned. Users recommend verifying the vacuum system and replacing faulty components, with one sharing a similar experience with a Zafira B 1.9 DTH, where a DPF pressure sensor cable was the culprit. The importance of using quality replacement parts is emphasized.
TL;DR: Error P2279 on the Z19DTH often traces to intake leaks or a clogged DPF; one user measured 80 kPa backpressure and noted, "Cleaning the DPF with a home-made method with a pressure washer helped." [Elektroda, Stachu2071, post #19643477]
Why it matters: This FAQ helps Opel Astra H/Zafira B 1.9 CDTI owners quickly diagnose intermittent turbo cut and limp mode due to P2279.
What does code P2279 mean on my Z19DTH (Astra H/Zafira B)?
P2279 flags an intake air system leak. On the Z19DTH, users also see it when turbo control or DPF issues disrupt airflow readings, triggering limp mode. Intermittent power loss after lifting off the throttle is common. Inspect intake hoses, vacuum lines, and turbo control first. [Elektroda, sk700, post #16820025]
Why does my turbo cut off when I let off the gas?
Limp mode engages when the ECU sees airflow/boost out of range. Intake leaks, weak vacuum to the VGT actuator, or a sticky variable-geometry mechanism can all cause a sudden cut after throttle lift. Check hoses and the VGT control solenoid. [Elektroda, sk700, post #16820025]
How do I quickly test for an intake leak on this engine?
Use a smoke test or pressure test of the charge system. Watch live MAF/boost parameters while gently flexing hoses and joints. Intermittent leaks often appear when hoses shift under load or heat. Resetting the ECU may temporarily mask the issue. [Elektroda, sk700, post #16820025]
Could the DPF cause P2279 or limp mode?
Yes. A ruptured DPF pressure-sensor hose can halt regeneration and clog the DPF. One user saw >80 kPa differential and repeated errors until fixing the hose and cleaning the DPF. That restored normal parameters. [Elektroda, Stachu2071, post #19643477]
What is the N75 on this car, and what does it do?
Here, "N75" refers to the vacuum solenoid that controls the variable-geometry turbo vanes. If it sticks or leaks, boost control fails and the ECU may trigger limp mode. It is a control valve, not a sensor. [Elektroda, sk700, post #16825020]
Are there two identical solenoids I can swap to test?
Yes. This engine may use two identical vacuum solenoids for different functions. Swap positions temporarily to see if the fault moves. This quick A/B test can confirm a weak valve before buying parts. [Elektroda, sk700, post #16825020]
Which part numbers fit the VGT control solenoid?
Technicians in the thread reference ENT830025 and 7.01420.02.0 for the variable-geometry turbo control solenoid. Read the numbers on your current valve and match accordingly to avoid misorders. [Elektroda, sk700, post #16825056]
How much should I expect to pay for the VGT solenoid?
One buyer reported a price around PLN 180. New OEM parts cost more, while budget options can be a lottery on reliability. Confirm return terms before purchase. [Elektroda, skaxx, post #16825092]
How do I check EGR and intake flaps before a remap (chip tune)?
Run dynamic logs on a dyno or road with a scan tool. Observe EGR command vs. flow, intake flap operation, and boost tracking. Many tuners can diagnose these during pre-map checks on the dyno. [Elektroda, sk700, post #16820025]
Should I visit a tuner with a dynamometer first?
Yes. A reputable tuner with a dyno can diagnose issues from live data before altering maps. "If so, he will diagnose the car himself before changing maps." [Elektroda, sk700, post #16819982]
How do I measure vacuum and verify VGT control?
Connect a vacuum gauge to the actuator line and observe vacuum rise with commanded boost. Inspect all vacuum hoses for splits and loose fits. Replace any suspect lines before condemning the solenoid or turbo hardware. [Elektroda, sk700, post #16825112]
Can a bad turbo still be the cause after replacement?
Yes. Variable-geometry control faults, weak vacuum, or leaking hoses can mimic a failed turbo. The thread notes symptoms vanished for days, then returned, pointing to control or plumbing rather than the cartridge. [Elektroda, skaxx, post #16825115]
What is DPF differential pressure, and what number is worrying?
DPF differential pressure is the exhaust pressure difference across the filter. A reported 80 kPa (≈800 mbar) indicated a severely clogged DPF here. After fixing the hose and cleaning, errors cleared. [Elektroda, Stachu2071, post #19643477]
Is pressure-washer DPF cleaning safe?
One user used a pressure washer and restored normal DPF parameters, clearing P2279. However, improper cleaning risks substrate damage or water ingress. Consider professional service if unsure. [Elektroda, Stachu2071, post #19643477]
Quick how-to: swap the two vacuum solenoids to confirm a bad valve
  1. Label both similar solenoids and hose routing.
  2. Swap their electrical and vacuum connections one-for-one.
  3. Test drive while logging boost; if the fault moves function, replace that valve. [Elektroda, sk700, post #16825020]
Which hoses should I upgrade to prevent repeat failures?
Replace brittle vacuum and DPF pressure-sensor hoses. A user recommends FMIC-grade hoses as cheaper and more durable than OE. This prevented regeneration failure and high backpressure. [Elektroda, Stachu2071, post #19643477]
