[Solved] Ford focus mk3 - engine failure immediately service - turbo 1.6 tdci 115 km
Norbert_lubin 49041 6
  • #1 17729545
    Norbert_lubin
    Rate: 55
    Hello colleagues.
    Colleagues, I have a problem with the turbine, namely when I start a cold car, everything is ok until it warms up, but when the car reaches its normal operating temperature, the revs will exceed 2500 rpm. appears on the display Engine failure immediately Service. Due to the fact that I work in a company related to the regeneration of fuel systems and turbo, my colleagues cleaned the entire turbo, sanded the geometry and polished the surfaces that are movable and set the turbine correctly on the machine, but it did not change anything. I would like to add that, according to Esitronica, the turbo copy sensor should work in the lower range from 0.8v to 1.4v in the upper range from 3.2v to 3.7v and if I did not set the pear, it cannot be set at the upper limit, only what I was able to set down 1.3v and up 3.18v. I made the pear settings in such a way that I disconnected the vacuum, turned on the ignition and connected to the mass of the car with the meter and checked the signal on the purple wire. I even replaced the vacuum control valve, but it didn't improve anything, I only checked the pressure hoses, I'm afraid that maybe the hoses are swapped in the vacuum valve. Colleagues, please tell me how can I still check this sensor. I forgot to write that the computer shows the error of jamming the copy sensor (sensor A) in the upper position, so I assume the failure of this sensor .Ps. colleagues, the pressure control valve has 3 outputs, can you write which output from which place they leave because on the net what I found is only with 2 outputs .Ps. Thank you very much for help .
  • #2 17729649
    Daro122
    Help: 165
    Rate: 751
    Buddy, the error number though.
  • #3 17729865
    Norbert_lubin
    Rate: 55
    COLLABORATION ABOUT THIS LIST OF ERRORS THAT I HAVE READ WITH FORSCAN.U
    === PCM DTC P2599: 00-64 ===
    Code: P2599 - Position sensor A operating parameters for turbocharger boost pressure control - jammed in position for high values
    Status:
    - DTC has turned to a permanent fault - intermittent fault at the time of command
    - Fault indicator lamp is off at this DTC
    - The test has not been completed
    Module: Engine Control Module (Power Train Chain Control Module).
    === END PCM DTC P2599: 00-64 ===
    === PCM DTC U0418: 00-68 ===
    Code: U0418 - Invalid data received from A brake control module
    Status:
    - Earlier DTC Set - Not present at time of command.
    === END PCM DTC U0418: 00-68 ===
    === OBDII DTC P2599-P ===
    Code: P2599 - Error
    Status:
    - Pending - the fault is waiting for confirmation
    Module: On-Board Diagnostics II
    === END OBDII DTC P2599-P ===
    === SASM DTC None ===
    Successful reading of the DTC, there were no error codes
    Module: Steering angle sensor module
    === END SASM DTC None ===
    === ABS DTC None ===
    Module: Antilock BrakingSystem.
    === END ABS DTC None ===
    === RCM DTC U0253: 00-2F ===
    Code: U0253 - Lost Communication with Additional Protocol Interface Module
    Status:
    - DTC present at the time the command was issued
    Module: SRS system module
    === END RCM DTC U0253: 00-2F ===
    === PSCM DTC None ===
    Module: Power steering control module
    === END PSCM DTC None ===
    === BCMii DTC B1130: 07-28 ===
    Code: B1130 - Light switch module
    Additional fault symptoms:
    - Mechanical faults
    Status:
    Module: Body control module
    Frozen Frames:
    -GLOBTIM: 3573917 s - Global real time
    -TOTDIST: 229 728.0 km - Total (traveled) distance
    -MAINECUV: 14.75 V - Main power supply of the ECU controller
    -INCARTMP: -40 ° C - Temperature inside the vehicle
    === END BCMii DTC B1130: 07-28 ===
    === FCDIM DTC None ===
    Module: Front control / display interface module
    === END FCDIM DTC None ===
    === PDM DTC None ===
    Module: Passenger's door control unit
    === END PDM DTC None ===
    === DDM DTC None ===
    Module: Driver's door module
    === END DDM DTC None ===
    === ACM DTC None ===
    Module: Audio equipment control module
    === END ACM DTC None ===
    === IPC DTC None ===
    Module: Instrument panel control module
    === END IPC DTC None ===
  • #4 17729920
    Daro122
    Help: 165
    Rate: 751
    Pin 3 of the position sensor for controlling the boost pressure of the turbocharger, after turning the ignition switch, you should have a voltage between 0 and 0.2 V. Resistance less than 1 ohm between pin 3 of the sensor and B36 of the controller
    Sensor pin 2 and motor controller pin B52 resistance lower than 1 ohm (for T1DA motor). Check it out, we'll see.
  • #5 17729960
    Norbert_lubin
    Rate: 55
    WHAT DOES THE MARKING B36 MEAN? I DO NOT UNDERSTAND IF YOU CAN WRITE ME AS FOR THE DEBIL :-) LATHOLOGICALLY ??? I HAVE INCLUDED THE PHOTO OF THE PLUGS FROM ESITRONICA.
    should I check it according to the drawing I made? or maybe otherwise ???
    the drawing in the attachment
    • Ford focus mk3 - engine failure immediately service - turbo 1.6 tdci 115 km 20190125_200402.jpg (1.34 MB) You must be logged in to download this attachment.
    • Ford focus mk3 - engine failure immediately service - turbo 1.6 tdci 115 km 20190125_193116.jpg (1.31 MB) You must be logged in to download this attachment.
  • #6 17730173
    Daro122
    Help: 165
    Rate: 751
    "Driver B36" is talking about the driver connector, you have ESITRONICA, you should be able to do it.
  • #7 17855738
    Norbert_lubin
    Rate: 55
    Hello, the cause of the damage was a modified batch to the engine controller, uploading a clean batch fixed the car's work. subject to close.
The discussion revolves around a Ford Focus MK3 experiencing an "Engine failure immediately Service" warning when the engine reaches normal operating temperature, particularly affecting the turbocharged 1.6 TDCi engine. The user has had the turbo cleaned and calibrated but continues to face issues. Error codes P2599 and U0418 were identified, indicating problems with the turbocharger boost pressure control and invalid data from the brake control module, respectively. Suggestions include checking the voltage and resistance of the position sensor for the turbocharger boost pressure control. Ultimately, the issue was resolved by uploading a clean batch to the engine controller, restoring proper functionality.
