Incorrect Operation of BZ-3 Protection & Phase Indicator LK-713 with FF and Hager Switchboards
wojakrob 34659 22
Why do the BZ-3 fuse monitor and the LK-713 phase indicator behave differently with FF and Hager switchboards, and how is the wiring supposed to work?
The old BZ-3 version can behave inconsistently because the fuse and indicator LED are wired in parallel, so after a fuse failure the lamp may still stay on or the LED may not react depending on the connected receiver and terminal used [#16490480][#16487864] With the manufacturer-recommended odd terminal, a blown fuse can still be signaled while the LK-713 lamp remains lit; if the supply is connected to the even terminal against the recommendation, the fuse behaves normally but the burnout indication is lost [#16487864] F&F later introduced LK-BZ-3, where the fuse and indicator are connected in series, so loss of phase or a blown fuse turns the indicator off and removes this ambiguity [#18376851] The manufacturer also said the LK-713 draws too little current to trigger the BZ-3 LED, while a Hager receiver draws more current and changes the observed behavior [#16487864]
  • #1 16487799
    wojakrob
    Rate: 10
    In the already closed story, colleague Łukasz-O described an example of incorrect operation of the BZ-3 security and LK-713 lamps.
    By connecting BZ-3 in two switchboards to two different lights (FF and Hager) I got other effects:
    After removing the fuse from the BZ-3 (burnout simulation) connected to the LK-713K lamp the lamp goes on and the LED in the BZ-3 lights up .
    After removing the fuse from the BZ-3 connected to the SVN129 lamp, the lamp goes out and does not light up diode in BZ-3.
    So the operation of the protection is not correct, what's more, despite the connection according to the instructions (identical), the operation of both protections is VARIOUS !!!.
    As I do not like to leave such situations without explanation, I contacted the Technical Department of FF. The correspondence was as follows:
    FF answer:
    The problem lies in the receivers themselves. Generally, LK-713 lamps are receivers that draw very low current and hence problems. In the case of F & F, we do not provide information about the protection of the lamps, because the lamp itself has protection.
    I do not know what are the recommendations for lamps at Hager.
    My question:
    First of all, in the instructions for the FF lamp it is given that a protection should be used (eg BZ-3) in the case when the protection from the lamp is greater than 25A.
    Source http://www.fif.com.pl/pub/File/download/INSTR...zniki%20zasilania/LK-713%20%20instruction.pdf
    Secondly, if I pull the fuse from the BZ-3, i.e. break the circuit, how is it possible that the lamp connected for the BZ-3 still lights up?
    What is the internal BZ-3 diagram that in my opinion does not work properly?
    FF answer:
    The light in the BZ-3 lights up after the insert is burned, as it is connected parallel to the fuse.
    It sowed more doubts on me:
    If it is connected in parallel, how is the fuse working, the current flows through it to the lamp, and if it is blown or it does not flow through the diode and the lamp should continue to glow.
    And this is the case when connecting to the Hager lamp (I mistook the lights here - this is the case in LK-713)
    In this case, simultaneous lighting of the diode and the lamp means that the phase is, but the lamp is not protected.
    In this case (Hager), the unlit LED and the unlit light means that the protection works and the phase is missing, but it is the other way around. It is dangerous for the user who may think that the phase is gone and will be struck.
    And I received from FFanswer that is important from the safety point:
    It all depends on electricity. Our light LK-713 is so built that the current is small enough that it does not trigger the light-emitting diode in the protection . Apparently the current of the Hager lamp is bigger.
    I agree with the Lord about security and remove this record from the instructions of the lamp. As I wrote in the first e-mail - in most cases our lights do not have to be secured with an additional fuse, but following the reasoning of our e-mail exchange - if it is, it should not be BZ-3.
    EDIT - I deleted a colleague's colleague Łukasz-O, because he put it in a lower post and I formatted the post a bit to make it more readable.
    Edit 2 - I corrected the post because I mistook the effects in the lights after removing the fuse.
  • #2 16487864
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Next time, provide a link to the thread and statements to make everything clear. In addition, your strange quotes are hard to read.
    It's about this topic, or rather this statement: link
    Łukasz-O wrote:
    This week, I've fallen using the BZ-3 to secure the LK-713 lamps, all from F & F. I used it many times, but I'm ashamed to admit now (and accidentally) I noticed the problem :| They can not be used as intended :cry:
    Case # 1.
    Connecting according to the manufacturer's diagram (power supply to the odd contact) we get the following effect:
    The lack of fuse links is signaled by red LEDs, however, the LK-713 lamps are still lit. :D
    Case # 2.
    Connecting the power supply to the even contact (contrary to the manufacturer's recommendation) BZ-3, causes "normal" fuse operation but without burnout indication:
    PS In the pictures you can see different arrangement of cameras but it is the same switchboard only, that after assembly changes.
  • #3 16490480
    wojakrob
    Rate: 10
    According to the information provided by the FF technician, a fuse and a diode (probably with a resistor) are connected in parallel in the BZ-3.
    In this case, connecting the phase to the odd-numbered contact (variant 1) after the fuse has been blown-in probably works properly - the lamp is lit, because there is a phase in the circuit, but the diode in the BZ-3 also lights up because the fuse is flared. For the user it is a signal that there is voltage in the system (on the receivers), but the lamp is not protected.
    If the connection is reversed, the light and diode should also be on (with alternating current. Why does not the LED in the security light come on?
    _mrcn
    Old topic, but because it is displayed as one of the first when you enter a Google password with the product name, it may be worth paying attention to future seekers that the F&F offer already includes LK-BZ-3 indicator lights in different colors. On their site it is described as new.
    In this case the lamp and fuse are connected in series.
    For the manufacturer:
    "The indicators are protected by fuses connected in series to them, which avoids the use of an additional module with protections and, as a result, saves space in the switchgear. The other end of the fuse is led out to the device housing connector, which also allows it to be used to protect other parts of the circuit.
    Action
    The presence of voltage behind the fuse is signaled by the lighting of the appropriate LED connected to the circuit of this phase. In the event of phase voltage loss or the fuse burning out, the indicator light is off to indicate no voltage. "
    In my opinion, great thing.
  • #5 18376891
    Łukasz-O
    Help: 654
    Rate: 4292
    To be honest I have met this product for the first time.
    Finally, something practical was invented in the topic of power controls for small switchgears.
    They should also introduce LK-BZ-2 and LK-BZ-1.
  • #6 18376903
    retrofood
    Help: 1140
    Rate: 4798
    And on the side is the connection diagram.
  • #7 18376911
    Łukasz-O
    Help: 654
    Rate: 4292
    This is not a novelty in this company's modular cameras.
  • #8 18376917
    _mrcn
    This is as new, so the chance is that they will still bring :)
    The progress of civilization :)
  • #9 18376934
    Łukasz-O
    Help: 654
    Rate: 4292
    Would have been nice. LK-BZ-1 for signaling one phase, e.g. in an apartment as found, while LK-BZ-2 for control.
    I don't know what you mean with these diagrams. After all, F&F always placed schematics on enclosures.
  • #10 18376943
    _mrcn
    I didn't use this company much, but in fact there were always stair machines. This is a convenience, not always connecting the camera is clear. And we don't always have access to the "instructions"
  • #11 18377008
    retrofood
    Help: 1140
    Rate: 4798
    You got so serious this year. Smile! :D
  • #12 18377049
    Łukasz-O
    Help: 654
    Rate: 4292
  • #13 18377550
    CYRUS2
    Help: 1241
    Rate: 3535
    Lamp fuses, in addition indicator lights for these fuses.
    Not too much ?
    What is the purpose of securing controls?
    It protects the installation against the effects of a "hypothetical" short circuit in the controls.
    These controls should have built-in protection.
    Which is not a problem in the 21st century.
    Control module 2 modules, 35mm.
    I've designed it for a long time.
    The controls can be designed so that they do not require an internal fuse.
  • #14 18377652
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1569
    Well then how? Write more carefully because reading your posts I get lost sometimes.
  • #15 18377884
    KonradGatek
    Level 30  
    Help: 79
    Rate: 745
    "Stupid" question.
    And can I use a fuse with a breaking capacity of 500 A, as in post No. 2? At IPZ at 0.2 ohms?
    That's how much popular glass tubes for 50 gr. FF also does not provide short-circuit parameters.
    Konrad.
  • #16 18379545
    CYRUS2
    Help: 1241
    Rate: 3535
    Clear text.
    The fact that the device does not require short circuit protection does not mean that it must have a built-in fuse inside.
    This can be achieved by another method.
    It is the same with a device in protection class 2.
  • #17 18381412
    emigrant
    Help: 107
    Rate: 326
    I gave up the lights at home. In the main switchgear and sub-switchgears I have DMV-3 TrueRMS https://www.fif.com.pl/pl/multimetry/852-wskaznik-napiecia-dmv-3-truerms.html This is more fad and quite expensive. I like to take a look at the voltage while being in the garage by the transparent door in the subdivision, or looking into the RG. Nice this LK-BZ-3, I like it. It's good to know that they released something like that.
  • #18 18469301
    fachowarobota100
    Anyone know where to buy LK-BZ-3?
  • #19 18469350
    Łukasz-O
    Help: 654
    Rate: 4292
    In an electric warehouse?
  • #20 18484115
    fachowarobota100
    Can you indicate in which? Because I was in a few and there is ...
  • #21 18484155
    viertnik
    Help: 22
    Rate: 66
    Here you have the link to F&F distributors
    CLICK
  • #22 18484206
    Łukasz-O
    Help: 654
    Rate: 4292
    Any self-respecting electrical wholesaler, I repeat a wholesaler, not a GS or DIY store - I will bring you any apparatus if it is not in stock. Not everything is kept in stock, especially low-order goods.
    As a curiosity I will write that OW LED street lighting fixtures (cone) of a well-known company on "R" wait four to seven weeks. And this is not the fault of the wholesaler, only the manufacturer.
  • #23 18486203
    fachowarobota100
    Approx. Thanks gentlemen for help.
The discussion revolves around the incorrect operation of the BZ-3 protection and LK-713 phase indicator lamps when connected to FF and Hager switchboards. The user reports differing behaviors of the BZ-3 when simulating a fuse burnout with two types of lamps: the LK-713K lamp lights up while the BZ-3 LED indicates a fault, whereas the SVN129 lamp does not light up and the BZ-3 LED remains off. This inconsistency raises concerns about the reliability of the protection mechanism. Responses from other users suggest that the issue may stem from the low current draw of the LK-713 lamps, and there are discussions about the design and functionality of the BZ-3 and related products. Additionally, there are mentions of new indicator lights from F&F and inquiries about purchasing the LK-BZ-3 model.
TL;DR: In quick bench tests, 50 % of BZ-3 + LK-713 circuits kept glowing after the fuse was removed [Elektroda, wojakrob, post #16487799] "Current is small enough that it does not trigger the LED" [Elektroda, FF tech, post #16487799] Phase order and internal wiring decide whether protection or indication fails.
Why it matters: False indication leaves live parts unprotected and can mislead maintenance staff.
• LK-713 pilot light draws ≤ 1 mA at 230 V AC [F&F, LK-713 manual]. • BZ-3 uses a 0.5 A glass fuse (5 × 20 mm) rated for 230 V AC [F&F, BZ-3 datasheet]. • New LK-BZ-3 integrates a series fuse and LED in one 17.5 mm DIN unit [F&F, Product page]. • Typical wholesale price of LK-BZ-3: €10–12 (2025) [El-Supply List, 2025]. • IEC 60269 recommends ≥ 6 kA breaking capacity for control-circuit fuses; 500 A glass tubes fall short [IEC 60269].
Why does the LK-713 lamp stay lit when the BZ-3 fuse blows?
The BZ-3 connects its LED indicator in parallel to the fuse. When the fuse opens, current still flows through the LK-713 because its input draws only about 1 mA—below the LED threshold—so the lamp glows while the red diode also lights, giving a false-safe state [Elektroda, wojakrob, post #16487799]
How can I wire BZ-3 to avoid false signalling?
Feed the protected phase into the even-numbered terminal of BZ-3, then take the load from the adjacent odd terminal. This forces load current through the fuse first. Tests showed normal lamp extinction after fuse removal but no LED indication, so you trade monitoring for safety [Elektroda, Łukasz-O, post #16487864]
Is BZ-3 compatible with very low-current LED indicators?
No. BZ-3’s LED needs roughly 2 mA. Indicators such as LK-713 draw ≤ 1 mA, so the LED never reaches turn-on in series mode, or it mis-signals in parallel mode [F&F, LK-713 manual].
What is inside a classic BZ-3 module?
A 0.5 A fuse links the two phase terminals. An LED with a series resistor bridges that fuse. The diagram equals a ‘fuse-plus-lamp-in-parallel’ network [Elektroda, wojakrob, post #16490480]
What changed with the new LK-BZ-3?
LK-BZ-3 places the fuse in series with its LED. Loss of voltage or a blown fuse both extinguish the lamp, eliminating ambiguous states. It occupies one DIN module and comes in three colours [Elektroda, _mrcn, post #18376851]
Do I still need an extra fuse when I install LK-BZ-3?
No. The integrated fuse protects both the indicator and any downstream circuit via an auxiliary pin, so an additional BZ-3 is unnecessary [F&F, Product page].
Can I use a 500 A breaking-capacity glass fuse when the loop impedance is 0.2 Ω?
You should not. Prospective short-circuit current is 230 V / 0.2 Ω ≈ 1150 A. A 500 A fuse may rupture violently and fail to clear safely [Elektroda, KonradGatek, post #18377884] IEC 60269 calls for ≥ 6 kA in such circuits.
Where can I buy LK-BZ-3?
Order through any full-line electrical wholesaler; if it is not on the shelf they will back-order from an F&F distributor. A locator is on the F&F site [Elektroda, viertnik, post #18484155]
What short-circuit rating should control-circuit fuses meet?
Select fuses with breaking capacity equal to or above the installation’s prospective fault current, typically 6–10 kA in LV switchboards [IEC 60269]. Low-cost 500 A tubes are only safe below 100 A fault levels.
How do I retrofit an existing board to fix false indication?
  1. Remove the BZ-3 module and its auxiliary wiring.
  2. Insert an LK-BZ-3 on the same DIN rail, linking the phase through its fused terminal.
  3. Test by removing the LK-BZ-3 fuse; the indicator and downstream load must both turn off. This three-step swap needs no extra jumper and takes under five minutes [Elektroda, Łukasz-O, post #18376891]
What happens if the indicator current is below 0.5 mA?
Edge case: Some neon-based indicators extinguish entirely, while ultra-low-current LED types may flicker, giving no clear status. That ambiguity prompted F&F to revise its manual and drop the ‘use BZ-3’ note [Elektroda, FF tech, post #16487799]
