Can BZ-3 Module Protect 3-Phase Power Supply Type TDR-240-24?
przeme 696 3
  • #1 20007520
    przeme
    Help: 11
    Rate: 91
    Hi. I have a question whether I can use the BZ-3 module to protect a 3-phase power supply Type TDR-240-24 ? The module contains a circuit which signals the blown fuse . According to the parameters, the rated voltage is 260V, isn't it too low for the module to be used in a 3-phase installation? There is no space in the distribution board for a normal fuse .
    pafciowaw
    Automation specialist
    Help: 480
    Rate: 365
    You can use - for this there is :) .
    Since one track is for max 250 V(DC/AC) then if two phases are connected through two tracks - half the phase voltage will be deposited on one track - that is below the possible voltage....
    tos18
    Help: 1113
    Rate: 1870
    I believe that NO
    The blowing of one fuse will result in a 400V phase-to-phase voltage at its contacts!
  • #4 20014522
    przeme
    Help: 11
    Rate: 91
    Thanks for your interest in the topic. However, I have managed to rebuild the switchgear.I have used overcurrent protection (triple S) as protection for the power supply . I think this will be a safer and more secure solution. Greetings
