[Solved] Simson S50 1989: Front & Rear Light Issues with 6V Electrical Installation, Possible Coil Damage
forest_89 13107 18
How can I diagnose why the front and rear lights on my 6V Simson S50 do not work while the brake light still does, and do I need to retime the ignition if I replace the lighting coil?
The fault is most likely in the wiring, ignition-switch connections, or ground, not in ignition timing: check the cables, the switch terminals, and try powering the lamps directly from the lighting coil to see whether the coil or the switch is bad [#16496562] [#16496662] The brake light can still work even when the lighting circuit has a problem, because it is fed from the rear-light circuit [#16514580] On this Simson, the front and rear lights are supplied from separate coils, and the front light feed goes through ignition-switch pin 59 and out at 56 [#16496662] If you replace the lighting coil, you do not need to set the ignition again; just remove the flywheel to access the coils, and if you remove the base plate, mark its position first and recheck the breaker gap if needed [#16496606] In the thread, the real cause turned out to be cracked insulation and a wire broken off at the coil outputs; after resoldering and reinsulating the wires, the front and rear lights worked again [#16516661] [#17239712]
  • Diagnosing 6V lighting circuit and coil replacement question
    #1 16496417
    forest_89
    Rate: 13
    Hello, I have a Simson S50 1989 with 6V electrical installation. Recently, I noticed that I have no light in the front and back. The STOP light works. I checked the bulb in the back are functional, I replaced it with the STOP bulb. I don't know if there is a problem with the ignition, the circuit is broken, or is the light coil damaged? Where can I start my diagnosis?
    I have a question, but if it turns out that the coil of lights is damaged, do you need to set the ignition again when replacing it?
    Regards.
    TheGolibroda
    Rate: 14
    First check the cables, inserts at the ignition switch, whether the weight is good. Try to connect the lights directly from the coil, as it will be a good coil, if not the ignition switch.
    sanfran
    Help: 963
    Rate: 3004
    No, you take off the magnetic wheel and you have access to the coils. If you have to remove the magneto base, mark the position relative to the engine block and place it the same.
    Alternatively, you will need to adjust the interrupter gap when removing the spark gap.
    Krzys55
    Help: 89
    Rate: 303
    In Simon, the front light is powered from a coil other than the rear one. one supplies the front light the other rear light, stop speedometer lighting. The front power comes to pin 59 of the ignition, goes out of 56.
  • #5 16514439
    forest_89
    Rate: 13
    Hello, today I checked this electrical installation in Simon with a meter.
    At the output of the 4V ignition coil
    At the output of the coil from a 6V stop light
    On the other two 2.5V and 0V cables.
    Do I have something mixed up in the wires, wrongly connected to the ignition? damaged coil?
    The "stop" light glows elegantly.
    I printed several simson installation diagrams and saw that two wires come out of one coil. Are these cables from the rear and front lights or stop lights?
    I would like a connection diagram in the ignition switch, I am spreading my hands.
    Regards
    Krzys55
    Help: 89
    Rate: 303
    The stop light is supplied from the rear light, so something on the wires.
  • #7 16514813
    forest_89
    Rate: 13
    Ok, I'll see today. And I have a question, can you tell me exactly what simson model I have? year of manufacture 1989, 3-speed s50 engine, 6V installation with battery and indicators, because I do not know what wiring diagram to look for. As I bought a simson, in proof I have a simson s51 and the engine is s50. It is possible that the frame from s51 and the engine s50?
    Regards.
    BANANvanDYK
    Help: 1167
    Rate: 2602
    Flatboat. Frame from S51 / 1, installation from S51, motor from S50
    Krzys55
    Help: 89
    Rate: 303
    If it is 89, then rather S51. The scheme is the same, it doesn't matter too much. Can you take a photo of a simson?
  • #10 16516661
    forest_89
    Rate: 13
    Yesterday, using the diagram, I connected the pins from the coils to the ignition, the rear and front light is (although weak), there is no stop light. I took off the magneto, pulled out the ignition apparatus and noticed that the insulation of the wires is in a tragic condition, cracked, the wires rub against each other, maybe this is the reason because the output from one coil No voltage as measured by the meter. Today I will take to soldering and see what happens. If there is still no effect then the coil may be damaged? I'll take a photo of Simson.
    Regards.
  • #11 16516690
    Krzys55
    Help: 89
    Rate: 303
    Here is the diagram Simson S50 1989: Front & Rear Light Issues with 6V Electrical Installation, Possible Coil Damage Simson S50 1989: Front & Rear Light Issues with 6V Electrical Installation, Possible Coil Damage The headlight coil is a red-white wire terminal 59 of the ignition switch. The tail light coil is a green-red wire.
    S51/1 uses 12V wiring and different coils
    #12 16518015
    BANANvanDYK
    Help: 1167
    Rate: 2602
    In appearance, almost the same. The year 1989 was the S51 / 1 version where each version had a 12V installation, a completely different wiring diagram and a difference in the performance of several components. With electrics mainly other switches, rear brake stop light switch on the engine, electrical equipment in the right glove box.
    In S51 / 1 and in some versions of S51 with 6V installation, the rear position light was supplied with a lighting coil, in others with a charging coil and a stop light.
  • Frayed coil wires were causing lighting faults
    #13 16518506
    forest_89
    Rate: 13
    Hello, yesterday I pulled out the base of the spark gap, re-soldered all wires on the coil outputs and noticed that on the red-yellow wire one wire was not soldered to the wire. The wires were cracked in the same place, as if the base of the sparker cut the insulation and maybe that the voltage was escaping to the ground. The wires were frayed. After soldering, proper wire insulation and installation of the ignition apparatus, the rear position light and the front lamp are lit. I am only surprised that the rear position light is connected to the lamp at the front. And as you said before it was STOP light, rear position light, the speedometer lighting should go from one coil and the front light from the other coil. Generally there are lights, only the Stop light is very bright and the rear position and the front lamp weaker.
    Below are the photos of the simac you asked for.
    Regards.
    Added after 11 [minutes]:
    BANANvanDYK
    Help: 1167
    Rate: 2602
    Do you have SR50 front telescopes or windbreaker springs? If it is the latter, then it is better to change the springs to the original. MZA before your wheel falls out of telescopes.
    In the pictures it looks more like the S50, only the frame with the documents comes from another model.
  • #15 16519594
    Krzys55
    Help: 89
    Rate: 303
    Why would it fall out?
  • #16 16519682
    BANANvanDYK
    Help: 1167
    Rate: 2602
    The support tube must be inserted a certain minimum distance into the telescope shin. By increasing the length of the spring or / and lengthening the connecting rod, the support tube is inserted shallow, which first reduces the stability of the suspension, and secondly, if the suspension rebounds the other way, there is a greater risk of the support tube falling out of the shin. The design of Simson telescopes does not have a stroke limiter (telescope length) as in normal motorcycles, so replacing the springs means a different length of the telescope, and in the event of a spring break results in an accident of the shin from the support tubes called "wheel fall".
  • #17 16520529
    forest_89
    Rate: 13
    From what I remember when I exchanged lags, I have springs from SR50.
  • #18 16520917
    BANANvanDYK
    Help: 1167
    Rate: 2602
    There is no such thing as SR50 springs. These things were invented by sellers, so what you have is a 100% windbreaker spring with a length of about 36 cm and a thin wire. All Simson models used the same springs with a length of 304 mm, only in S50 until 1979 they were slightly longer (317 mm). Install MZA springs (3.2 mm wire), in fact they are slightly longer (as for S50), but it will be a safer solution than these fakes. By the way, you will not have a problem with the stability of the vehicle placed on the central foot.
  • #19 17239712
    forest_89
    Rate: 13
    thanks for helping everyone. Re-soldering the wires solved the problem.
The discussion revolves around troubleshooting front and rear light issues on a 1989 Simson S50 with a 6V electrical installation. The user initially reported no light output from the front and rear lights, while the STOP light functioned correctly. Various responses suggested checking the wiring, connections at the ignition switch, and the condition of the coils. The user discovered low voltage readings from the coils and identified damaged insulation on the wires, which was likely causing the issues. After re-soldering the connections and insulating the wires, the front and rear lights began to function, albeit weakly, while the STOP light remained bright. The conversation also touched on the compatibility of parts from different Simson models and the importance of using the correct wiring diagrams for troubleshooting.
