Scooter - Replaced Chopper, Cables, and Bulbs: Indicators Still Not Working, Long & Short Lights
Piotrek1337 36180 7
  • #1 16541862
    Piotrek1337
    Rate: 18
    Well, I dismantled the entire scooter and do not work signposts, long lights, short operate, the scooter fires, the horn works. I replaced the chopper and cables from lights and all the bulbs. And they still do not work.
  • #2 16541872
    Paulo93
    Help: 29
    Rate: 22
    Did you check the switch?
  • #3 16541888
    Piotrek1337
    Rate: 18
    I checked, works.
  • #4 16541900
    Paulo93
    Help: 29
    Rate: 22
    Switching on cables everywhere is?
  • #5 16541912
    Piotrek1337
    Rate: 18
    I was checking.
  • #6 16542114
    web69
    Help: 188
    Rate: 629
    If the bulbs are good, the breaker, switch and connections too, then maybe charging?
  • #7 16543300
    Staszek49
    Help: 228
    Rate: 1140
    You do not give your scooter. Usually in scooters (cheaper) the directions are powered from the battery, so start by checking the battery and the direction switch. How many fuses you have at the battery and are operational. Did you connect the lamps from Saint during the assembly of the scooter? direction. To check if you have an efficient interrupter, unplug it and connect the cables (connectors). If you have a really efficient switch from St. direction, after switching on the ignition and switching the switch St. in the direction of, for example, the "right side", the lamps of the right side should be lit with continuous light. In this case, replace the breaker with a working one, and if the lamps do not light, then you must look for a fault in the installation.
    Also check the correctness of connecting the ignition and its efficiency.
  • #8 18986305
    Krainagier11
    Rate: 18
    Piotrek1337 wrote:
    Well, I disassembled the entire scooter and the turn signals do not work, high and short lights work, the scooter fires, the horn works. I replaced the circuit breaker, the light cables and all the bulbs. And they still don't work.
    voltage regulator check
The user reported issues with their scooter's indicators and lights not functioning despite replacing the chopper, cables, and bulbs. Responses suggested checking the switch, battery, and connections. It was noted that in many scooters, indicators are powered directly from the battery, so verifying the battery's condition and the direction switch is crucial. Additionally, checking for operational fuses and ensuring proper assembly of the lamps was recommended. A voltage regulator check was also advised as a potential troubleshooting step.
