There is no electricity in the scooter / lights / horn / turn signals - Baotian
Matox123 11019 4
  • #1 16588124
    Matox123
    Hello, I recently replaced the starter relay. After this exchange, I started the scooter, and then suddenly I had no turn signals, rear lights and a horn. There are no lights on the meter from the direction indicators, and when I turn on the high lights, they are on and the indicator light is on the meter.
    What could have burned down or something?
  • #2 16588204
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    The answer will probably be given by the modertor giving a reprimand. What did you check and what did you try to do for repair? Some indicator light in the paws and in the ring. We don't even know what the installation is there. Or maybe you lost the mass connection and hence the inclusion of traffic lights changes the state?
  • #3 16588727
    Matox123
    The mass connection is checked. It is good
    Added after 2 [hours] 34 [minutes]:
  • #4 16590855
    Staszek49
    Help: 228
    Rate: 1140
    Buddy, you probably did not check the fuse (s), which are usually located next to the battery. You probably know that some of the electrical receivers in the scooter are powered by the battery (directions, horn, starter). Check the electrical connections and the components that you have assembled yourself.
    Get the scooter wiring diagram.
  • #5 16597447
    Matox123
    The fuse is good ... And here is the diagram.
