Comparing SATEL PERFECTA alarm control panels: Understanding zones and detectors
gulson 40650 9
  • In March 2017, we witnessed the premiere SATEL PERFECTA alarm control panels . Perfecta is another family of SATEL exchanges, and therefore another portion of information to be learned. We have prepared a comparison of the most popular exchanges that will help you choose the right solution for you.
    Number of zones, i.e.: How many wired detectors can I connect?
    In CA series control panels , the case is as follows: CA-5 will handle up to 5 zones. The CA-6 control panel will handle max. 8 zones, while CA-10 will handle up to 16 zones.
    VERSA family control panels , i.e. VERSA 5, 10, 15, VERSA Plus and VERSA IP, are devices that will always support up to 30 zones. Development up to 30 zones is made by using INT-E expanders.
    In INTEGRA control panels , the maximum number of zones depends on the number that is within the symbol of the given control panel. The INTEGRA 24 control panel will support up to 24 zones (4 on board). INTEGRA 32 will handle 32 zones (8 on board). The INTEGRA 64, 64 Plus, 128, 128 Plus and INTEGRA 256 Plus control panels have 16 zones on the board. The INTEGRA 128-WRL control panel will support up to 128 zones, and has 8 zones on the PCB. Development o these zones are always used by means of expanders, e.g. INT-E.
    In the PERFECTA series , the maximum number of zones is also indicated in the control panel symbol. So PERFECTA 16 will handle max. 16 inputs, and PERFECTA 32 will handle max. 32 entries. Traditionally, expansion based on INT-E expanders, with each PERFECTA supporting 8 zones (on board) as standard.
    Division of the system into zones, i.e. how many independent areas can I arm?
    CA series it looks like this: CA-5 - no zoning, i.e. turn everything on and off. CA-6 has 2 zones and CA-10 max. 4 zones.
    In the VERSA series there are always 2 zones available, but each of them can be armed in 3 ways:
    1. full mode
    2. night mode
    3.day mode.
    With the right configuration, you can achieve very interesting effects in the management of these zones. Despite the existence of only 2 zones, you can independently arm the ground floor, floor and garage.
    In exchange PERFECTA series the case is identical.
    Central series INTEGRA , has a different number of zones depending on the model: INTEGRA 24: 4 zones, INTEGRA 32: 16 zones, INTEGRA 64 and larger: 32 zones.
    GSM / GPRS module, i.e. notification and control.
    Old panels CA series they do not have GSM modules, but they can always be retrofitted with an external module, e.g. GPRS-T1, GPRS-T4 etc.
    IN VERSA exchanges it's similar (with one exception): VERSA Plus has a built-in GSM module with support for two SIM cards. The built-in module usually provides more functions, i.e. detailed notification, control panel remote control functions via SMS, remote control panel programming. Modules purchased separately do not have such capabilities.
    Centrale INTEGRA series also have such a solution - it is INTEGRA 128-WRL. This control panel has a GSM / GPRS module installed. Its functionality also enables the implementation of detailed messaging, remote SMS control and remote programming of the control panel via GPRS.
    In case of PERFECTA control panels the situation is clear. Each PERFECTA control panel has a built-in GSM module that supports two SIM cards. As before, the built-in GSM module enables the implementation of detailed messaging, remote SMS control, remote programming of the control panel, remote firmware update (via GPRS). The fact that there are two SIM card slots (similar to VERSA Plus) increases security in the context of the reliability of event monitoring to security agencies. In case of problems with one GSM operator, the control panel automatically switches to the next SIM card. However, this is not all, but more on that.
    Mobile applications for remote control of panels
    CA-5, CA-6, CA-10 control panels they have not had their smartphone control applications and this is not expected to change.
    The VERSA control panel family has its mobile application - VERSA Control. The application is free, available among others for Android and iOS. To use the application belongs to connect the ETHM-1 Plus module to the VERSA control panel . This must be taken into account when calculating the system. The exceptions are the two control panels of the VERSA family: VERSA Plus and VERSA IP . Both of these control panels already have a built-in Ethernet module.
    For INTEGRA control panels also the manufacturer designed a mobile application - INTEGRA Control . Similarly as above, each INTEGRA control panel belongs to connect the ETHM-1 / ETHM-1 Plus module so that you can control the system remotely.
    PERFECTA control panels have their own application - PERFECTA Control . In this solution the ETHM-1 module will not be needed.
    Perfecta control panels do not even support it. So the question is, how is the PERFECTA Control mobile application supported? The answer is simple: thanks to the built-in GSM / GPRS module. Each PERFECTA control panelhas a GSM / GPRS module, so each control panel can be controlled by a smartphone using the PERFECTA Control application. It would be good if the SIM card had a data package (internet) purchased.
    And if you need to include wireless detectors and sirens?
    Today, many universal solutions are available, which can be fitted to virtually any control panel detectors and wireless sirens . Such universal controllers are usually connected to the control panel I / O, but we will not write about them. We will focus on dedicated solutions for individual exchanges.
    I'll start with a series CA . There is no dedicated radio controller here. Therefore, CA5, CA6, CA10 control panels cannot be extended with wireless components. Earlier the ACU-100 (ABAX) controller was available and it could be connected to CA-10. Currently it is not on offer, because it has been replaced by a newer one - ACU-120.
    IN VERSA exchanges we have a lot to show off. They support, among others ABAX system. Therefore, one of two controllers should be connected: ACU-120 or ACU-270 . From now on, ABAX wireless detectors, wireless sirens, and wireless keypad (two-way communication) can be logged into the system.
    Conclusion: based on the VERSA control panels it is possible to build a fully wireless one alarm system .
    There is also a possibility implementation of the wireless system in an economical edition . By using the controller VERSA-MCU connected to VERSA, we gain the possibility of using the same detectors as for the system based on the MICRA module . However, the VERSA-MCU controller does not support wireless keypads or sirens.
    Conclusion: this system will no longer be completely wireless.
    INTEGRA family control panels can also be extended with wireless components. By attaching an ABAX controller: ACU-120 or ACU-270, we gain the option of logging in wireless detectors and sirens. In the case of the INTEGRA 128-WRL control panel, there is no need to connect an external ACU controller (although you can). The "WRL" version has, in addition to the GSM module, an additional built-in module for ABAX wireless devices.
    For PERFECTA control panels the situation is clear. In the case of Perfecta control panels with the note "WRL", the control panel has a permanently built-in antenna and support for detectors, sirens and wireless keypads. These devices partly come from the MICRA system, so they work in the 433 MHz band. The PRF-LCD-WRL keypad has been designed especially for the needs of Perfecta control panel. It communicates in two directions and allows the control panel to be fully operated - just like in the case of the wired keypad.
    It follows that PERFECTA can be a completely wireless system.
    Necessarily One thing to keep in mind: only PERFECTA 16-WRL and PERFECTA 32-WRL versions support wireless devices. If the customer at the stage of system selection shows interest in a wireless solution (or is considering the possibility of expansion with such elements) should opt for the "WRL" version. If he buys a version without "WRL", he will not be able to add any dedicated radio controller, because PERFECTA does not work with ABAX modules and the VERSA-MCU module.
    LCD and LED keypads - to choose the color or not necessarily?
    Alarm systems can be operated from manipulators , zone keypads, remote controls, card readers and smartphones. Still, the most popular and safest variant is having at least one manipulator that will be mounted in the protected facility. Each control panel supports a certain set of keypads and one should choose the right one for the planned installation.
    In case of CA series , each control panel has a set of several own keypads. They are not compatible with each other, e.g. the CA-5 keypad does not work with the CA-10 control panel and vice versa.
    VERSA control panels they also have their own keypads, but also support touchscreen keypads, namely the INT-TSG and INT-TSH models. These keypads were originally designed only for INTEGRA control panels.
    Since we are at INTEGRA, here the choice of manipulators is the largest. Classic LCD manipulators, manipulators with a sensory keyboard (no mechanical keys), graphic manipulators with a touch panel, including a flagship position, which can also display camera images - INT-TSI. In addition, INTEGRA supports the so-called partition keypads, i.e. simple devices that control only one partition.
    PERFECTA series supports its own PRF-LCD wired and wireless PRF-LCD-WRL keypads.
    Safety according to PN-EN 50131
    CA series control panels were not classified by PN-EN 50131-1 standards . Therefore, there is no protection here according to this standard.
    VERSA control panels , possess grade 2. This means that such a system is dedicated to objects with low to medium risk of burglary.
    Control panels of the PERFECTA family also received grade 2, so the situation is similar to VERSA.
    INTEGRA control panels are divided into two series: INTEGRA and INTEGRA Plus. In the case of the first stage, there is stage 2. However, if the investor requires greater security, the installer can use the INTEGRA Plus control panel, which already has grade 3 according to PN-EN 50131-1 . Grade 3 means that the risk of breaking into the site is medium to high risk
    It is worth remembering that the PN-EN 50131 series standards replaced the previous PN-E-08390-14: 1993 standard, which classified systems according to classes from SA1 to SA4. Rustic classes and today's grades do not have a clear translation and cannot be used interchangeably.
    Advertisement
    Also read:
    Connecting any detector to any control panel - guide
    We invite you to familiarize yourself with other guides, featured topics, articles on security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Guides on security systems
    If the above topics do not find the answer to your question, please visit the forum:
    Security Systems
    We also encourage you to visit the General Guides section, where you will find materials from other sections of the forum, including those starting their adventure with electronics:
    General Guides
    gulson
    System Administrator
    gulson wrote 29525 posts with rating 6122, helped 150 times. Live in city Kielce. Been with us since 2001 year.
  • #2 16502724
    Barry83
    Help: 6
    Rate: 18
    A great summary. I would add that MTX-300 can be connected to CA and others as a universal wireless module.
  • #3 16508029
    suworow
    Help: 650
    Rate: 1278
    Barry83 wrote:
    A great summary
    I see it that way.
    And at the same time advertising. It turns out that you can. Bravo author. It seems to me that I see one of my colleagues from the "Monters" working on our forum.
    gulson wrote:
    PERFECTA does not work with ABAX modules and with the VERSA-MCU module.
    Perfecta is quite short on the market and I did not realize that it has such limitations. So thank you for the warning.
  • #4 16516230
    marek216
    Help: 1077
    Rate: 932
    For a long time you can - these are so-called sponsored articles.
    You can see Satel wants to erase the bad impression that creates here a few topics about the failure and functioning of their site.
  • #5 16516536
    suworow
    Help: 650
    Rate: 1278
    Marek, I mean, you can write an advertising article that is also a source of information, not just a marketing slurry.
  • #6 16529038
    montersi.pl
    Help: 26
    Rate: 26
    We have been intensively testing the PERFECTA series central units in recent days. We noticed interesting relationships that we want to share here. This will also partially supplement the article.
    No manipulator and the PERFECTA Control mobile application
    As you know, PERFECTA control panels can "live" without a manipulator. However, there is a certain limitation in the functioning of the PERFECTA Control mobile application. This application then allows only zone control and failure preview. Functions such as viewing the status of inputs, the ability to block them, controlling outputs or viewing event logs are not available.
    These capabilities in the mobile application will only be available if there is at least one keypad in the system (wired or wireless).
    Controlling the control panel via SMS messages that contain several commands
    The second thing worth noting is the ability to control the control panel using SMS messages. The manual does not specify how these SMSes should be entered. We checked it.
    For example, if we have two control texts, e.g. "Lamp" and "Gate", then you can send them not only individually, but also in combinations:
    "Lamp Gate", "Lamp Brama", "Lamp, Gate". You can see here that spaces, no spaces, commas are acceptable. There can be many control commands in one message. It's important to keep the case, because this one is checked here.
    It is true. We deliberately did not describe universal solutions like MTX-300 (this is indicated in the article), because we wanted to focus on dedicated radio controllers that are connected to communication buses. It does not change the fact that today virtually every exchange can be expanded with a wireless system - to a greater or lesser extent.
    E-SYSTEM Sp. z o.o.
    Czarnoleska 10, Zabagnie k. Wolbromia, 32-340 | Tel.: 32 XXX XX XX (Show) | Company Website: https://www.montersi.pl
  • #7 16715486
    Mar_rcin
    Help: 7
    Rate: 8
    Barry83 wrote:
    Even mentioned in the article perfecta 16 and 32, although it seems pointless from a financial and technical point of view.
    Well, unless the customer wakes up with his hand in the potty and changes his mind after finishing the installation.
    Alarmy Krakow
    os. Krakowiaków 45A, Kraków, 31-964 | Tel.: 607XXXXXX (Show) | Company Website: https://alarmy.krakow.pl
  • #8 17311451
    pnadworski
    I warmly welcome! What can be wrong in that case, if I have a wired keypad and in the application, the only thing I can do is look at the zone's zone status and that's all. Do you need to incorporate any additional functionality in the control panel application?
    Additionally, whether day / night / full mode is configured from the application or can it be done from the level of the wired keypad?
    I am a user of the switchboard, but the installer does not have experience in these Headquarters, so I ask :)
  • #9 17311971
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Can anyone know if there will ever be some touch manipulators to Perfecta?
    Something like INT-TSI?
    Because these current ones are quite ugly. Customers do not want Perfecta because of them.
  • #10 17312079
The discussion focuses on the SATEL PERFECTA alarm control panels, highlighting their capabilities regarding zones and detectors. The PERFECTA series allows for a maximum of 16 zones, while the VERSA family supports up to 30 zones with the use of INT-E expanders. Users express concerns about the limitations of the PERFECTA system, particularly regarding the functionality of the PERFECTA Control mobile application, which requires at least one keypad for full features. Additionally, there are inquiries about the availability of touch manipulators for the PERFECTA series, as current options are considered unattractive. The conversation also touches on the marketing strategies of SATEL and the perception of their products in the market.
