Satel Perfecta Alarm: Understanding No Function Issue During Arming Process
damian.kot1 19782 11
Why does a Satel Perfecta panel show “No Function” when I try to arm it?
“No Function” usually means the panel has nothing configured to execute: the keypad must be identified from the keypad itself, because the Perfecta app does not offer keypad identification [#16604705][#16605120] Also make sure the system actually has at least one defined zone/line and that it is assigned to the arming mode you are using [#16604741][#16605120] Day and night arming only work if the installer has defined which zones are active in those standby modes [#16604741] For night arming, the detectors that should stay active must be marked with the “N” mode; otherwise arming can fail with the same message [#16605120]
  • Clarifying the meaning of “No Function” during arming
    #1 16604436
    damian.kot1
    Rate: 29
    Hello!
    What does "No Function" mean when I want to arm an alarm based on Satel Perfecta?
    Advertisement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues A collection of topics
    Outputs (programmable and not only) for control panels
    How the control panel alarm outputs work
    Connecting any detector to any control panel - guide
    How to connect the siren to the control panel - guide
    We invite you to familiarize yourself with other guides, featured topics, articles on security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Guides on security systems
    If the above topics do not find the answer to your question, please visit the forum:
    Security Systems
    We also encourage you to visit the General Guides section, where you will find materials from other sections of the forum, including those starting their adventure with electronics:
    General Guides
  • #2 16604439
    Rysiek2
    CCTV and Stationary Alarms specialist
    Help: 447
    Rate: 659
    And how do you implement this armament?
  • #3 16604550
    damian.kot1
    Rate: 29
    I tried all the options:
    code + arming night
    utilities day
    1 (zone number) arming + code
    long holding the type of weapons
    I tried everything (programming the panel from scratch, resetting the settings, changing parameters) and always "no function"
    I have screenshots from Perfecta soft but I do not know if this will help
  • #4 16604577
    suworow
    Help: 650
    Rate: 1278
    And just code and arming everything?
    Give these screenshots.
    ps. Am I to understand that this is a configuration with two zones what was in this topic: https://www.elektroda.pl/rtvforum/topic3350438.html
    What kind of colleague does he arm and does he have access to the zones concerned?
  • #5 16604705
    niepotrafie
    Help: 17
    Rate: 37
    You have to perform identification of keypads, unfortunately the application does not have such an option.
  • Arming requires at least one defined zone
    #6 16604741
  • No function caused by missing zone definition and keypad identification
    #7 16605095
    damian.kot1
    Rate: 29
    It's probably the problem ... my friend dazzled me ....
    I wanted to do everything from the program but actually now I just associated that there is no option to identify detectors (the keypad can no longer be used).
    I have one zone so it should not be a problem.
    I will check and write
    Added after 5 [minutes]:
    norbert.s. wrote:
    The same, as I remember, pops up at identified keypads, but in the absence of defined alarm lines. There must be at least one system in the system.
    damian.kot1 wrote:
    ... I tried everything (programming the panel from the beginning, resetting the settings, changing parameters) and always "no function"
    Then maybe try to read the manual? First the installer and then the user.
    Here is a small tip for lazy and ignorant (we start with the installer's instructions):
    6.9.6 First steps after starting the control panel
    Control panel with wired keypads
    If the wired keypads are connected to the control panel, after starting the control panel
    with factory settings:
    1. Program correct, individual addresses in wired keypads.
    2. Run the device identification function connected to the communication bus
    headquarters.
    Next note for lazyness and ignorant (go to user's guide):
    6.3 Arming
    You can arm the daytime and night time detections if the installer has defined which zones are to be active in this standby mode. - the text specially marked in the instructions with the thick letter "i".
    Can be found? You can.
    Why is a colleague writing such a sarcastic language right away ????
    The second time I ask a question in the alarm department and once again I meet with hostility ......
    Is it not possible to suggest a solution as a colleague, give a clue and do not immediately make a philosophical argument about lack of skills or laziness ...
  • No detector identification in Perfecta software
    #8 16605120
    dariusz.bembenek
    Help: 455
    Rate: 615
    Let the colleague look at the program and the manipulator again. In Satel, there is no such idea as the identification of detectors. Identification can only apply to keypads and expanders. In the case of Perfecta, as of today, the identification of keypads and expanders can only be carried out from the level of the keypad. There are no such options in the program at all.
    Apart from the fact that problems with arming result from the lack of identification, it is also worth taking into account that this type of information "No function" can also occur when a colleague armed in night mode and no detector has night mode selected "N" (which is the default).
  • #9 16605135
    damian.kot1
    Rate: 29
    The detectors are already marked in the night mode - so that's not it (I tested in all modes). I focus on identification and I will test it right away.
    Thanks for the suggestions
  • Complaint about hostile replies and manual-reading advice
    #10 16605546
  • #11 16605714
    damian.kot1
    Rate: 29
    It's hard to assimilate all the instructions how to assemble the first alarm in my life .....
    However, some forum users are very emotional.
  • #12 16799689
    mag7777
    I have a question I will say immediately that it was my first time I looked at the instructions I connected the perfecta 16 wired keyboard I entered with the service mode I gave her no 0 and one detector 2eol / nc input - output. Only I have a strange behavior or something wrong I do not know in any case when a power board connected to I can run an alarm and disarm it, but the next time I have it, the missing function message enters the password and confirms #. The second thing when in the perfecta application I will enter the prf-lcd keyboard 0 version of the keyboard I can read but with the type of keypad I have (not) the same I have at INT-E versions I can read but the type of input module is missing can some hint.
    Okay, I know, but I'll leave it for posterity, see the understanding above ;)
    6.11.1 Launching the function
    Moderated By suworow:
    I think they are unconscious ;)
    We're closing.
The discussion revolves around the "No Function" error encountered when attempting to arm the Satel Perfecta alarm system. Users explore various troubleshooting steps, including programming the control panel, resetting settings, and ensuring proper identification of keypads and detectors. It is noted that the error may arise from a lack of defined alarm lines or incorrect configurations, particularly in relation to night mode settings for detectors. Participants emphasize the importance of consulting the installation and user manuals for guidance on proper setup and arming procedures. The conversation highlights the challenges faced by first-time users in understanding the system's documentation and configuration requirements.
