How to connect the DSC detector to the Satel Perfecta control panel?
piciuk 2874 5
  • Clarifying DSC PIR wiring to Satel Perfecta
    #1 20456634
    piciuk
    I have a SATEL Perfecta control panel and a DSC PIR detector. There are terminals in the detector: T1, T2, 12V, GND, COM, NC. As for T1, T2, I do not plan to connect. As for the rest, I don't know :( NC (DSC) -> Z1 (SATEL) 12V (DSC) -> AUX or KPD (SATEL)? COM (DSC) -> COM (SATEL)??? GND (DSC) - > ??? Can anyone help? Close-up of a DSC PIR sensor board with visible terminals T1, T2, 12V, GND, COM, NC. Close-up of a sensor board with visible terminals T1, T2, 12V, GND, COM, NC. Close-up of a DSC PIR sensor circuit board with labeled terminals: T1, T2, 12V, GND, COM, NC.
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 642
    Purely theoretically, it should be like this - with 1.1kOhm resistors:
    Connection diagram with 1.1 kOhm resistors on a PCB.
    2EOL/NC line
  • #3 20456687
    bhtom
    Help: 446
    Rate: 604
    Can you know why?
  • #4 20457443
    Zbych034
    Help: 550
    Rate: 1417
    If you do not connect T1 and T2, then do not say that you are mounting an alarm.
  • #5 20457562
    piciuk
    My declaration related to not connecting T1, T2 resulted from ignorance of the subject. I thought these were the terminals responsible for the tamper alarm. I did as the colleague above advised and the detector came to life :)
    Now I'm "fighting" with the configuration. I set: 2EOL/NC. It looks OK.
    Thank you Colleagues.
  • #6 20457626
    juan cabrillo
    Help: 127
    Rate: 242
    Surprise you, these are the terminals responsible for the tamper alarm. Did you expect something else?
