How to connect any detector to the alarm control panel - guide
suworow 45759 10
  • How to connect any detector to the alarm control panel - guide
    I meet many times on the forum with a request to draw a diagram of connecting a given detector to a given control panel, because the manual does not contain how to do it.
    Yes, in the Satela control panel manual we will not find information on how to connect a DSC detector, but there is information on how to connect a Satela detector. And that's enough. This can be done by analogy.
    It is enough to know that each detector, let's call it "universal", has the same and the same functioning basic contacts which, depending on the manufacturer, may be marked in different ways and placed in a different order.
    Contacts that interest us
    o two power contacts Here we indicate the power supply from the control panel in the appropriate polarity (plus to plus, minus to minus)
    o two NC tamper contacts Closed when the detector housing is closed and reacting by opening to open it.
    o two NC alarm contacts. Closed when the detector is powered and detects no motion, reacting by opening it to motion detection or removing the power supply.
    Now let's look at some popular models:
    Aqua Satel
    NC, NC alarm contacts
    TMP, TMP tamper contacts
    COM 12V power supply
    How do other manufacturers describe it?
    DSC (e.g. LC 104 or PIR LC 100 dulana detector)
    NC alarm contacts, C
    T1, T2 tamper contacts
    power supply -12+
    As can be seen in relation to the Aqua detector, the alarm and tamper contacts have been swapped. There is also another NO / EOL contact, which should not be of interest to us with the standard connection of the detector to the control panel.
    Vidicon Bingo
    RELAY alarm contacts
    TAMPER tamper contacts
    power contacts -12+
    Again, different order, different descriptions, this time for a pair of terminals, not single terminals, and this time two terminals (EOL), which are beyond the scope of our interests.
    Pyronix KX15DD
    ALARM alarm contacts
    power contacts - and +
    Bosch
    T, T tamper contacts
    power supply - and +
    Which way to connect the detector to the control panel and how to do it
    As you will see for yourself, the instructions contain several different examples of how to connect the detectors. If your control panel supports this type of parameterization (DEOL), forget about NO, NC, EOL. (below is a diagram from the Satel CA 5 control panel installer manual)
    Advantages of DEOL (2EOL)
    o The control panel, with such a detector connection and such configuration, detects three states on one line: normal state, violations and tamper.
    o The status of the line on which the detector is connected is monitored all the time, regardless of whether the system is armed or not. It is necessary to know that the control panel will detect and report as tamper not only the opening of the detector, but also damage (interruption or short circuit) of the cable to which the detector is connected to the control panel.
    o We save the control panel lines by implementing alarm and tamper signaling on one line.
    At first, connecting a detector in DEOL (or 2EOL) configuration to the control panel may seem complicated. Nothing could be more wrong. It should only be remembered that one resistor connects one of the tamper contacts with the alarm contact, and the second one is parallel to the alarm contacts. You will find out about the benefits of such a system very quickly by diagnosing faults during the installation and operation of the system. To make it easier, more and more often manufacturers build resistors in the detectors and it is enough to put appropriate jumpers only during installation, remembering not to use both methods at the same time, i.e. not to put jumpers in DEOL and not to provide external resistors at the same time.
    Examples. In both cases, pay attention to the position of the parameterization jumpers (circled in red)
    Connecting the Satel Graphite detector in DEOL using built-in resistors. The jumpers are set to DEOL
    Connecting the Satel Graphite detector in DEOL using external resistors
    Preparation of resistors
    What we set on the control panel side:
    o Input type. (its parameterization) The same as set by the detector resistors. In our case, it will be DEOL NC (in the case of control panels that provide DEOL NC and DEOL NO configuration) or simply DEOL in the case of other control panels.
    o The appropriate type of reaction.
    o If the detector is connected not directly to the control panel board, but to the zone expansion module, make sure that it has been properly added to the control panel. What range of input numbers does it support.
    These are, of course, the basic zone settings, sufficient to test whether the detector has been properly connected. However, it is not always sufficient for the control panel to work as intended. But here I refer to the instructions.
    Notes / FAQ
    o DEOL = 2EOL. It's exactly the same.
    o In the attached photos you can see jammed wires in the detectors. It does not look very elegant, but this way I wanted to draw your attention not to cut the free wires and leave some spare wire in the detector.
    o The DEOL parameterization can also be used when connecting detectors without tamper contacts (eg most reed sensors). This makes sense because, as I wrote earlier, sabotage is not only opening the device, but also damage (short circuit, break) on the wires.
    o DEOL parameterization is not supported only by very old control panels. But there are exceptions. Among those designed in this century that do not support this parameterization, one should first of all mention Satel Micra. It is not without reason that the installers prefer to stick to the name: "Communication module with the control panel option" We will rather not use DEOL parameterization by connecting the detectors directly to the communication module. But here too there are exceptions that make this possible, such as the Genevo GSM-8.
    o In the detectors, we use resistors (with the same values) as imposed by the control panel. It is true that in most popular control panels from manufacturers such as Satel, Genevo, Ropam, 1.1k resistors are used for DEOL parameterization, but there are also control panels based on 2.2k (Risco) or 5.6k (DSC) resistors. In practice, this means that when connecting a Satellite detector, eg Graphite, to the DSC control panel, we will not use the resistors built into it, and we will have to use the ones attached to the control panel. Of course, the method of their assembly will be the same. However, we will use the built-in resistors in the Satellite detector, eg Graphite, by connecting it to the Genevo or Ropam control panel.
    o When selecting a given parameterization of the detector (eg DEOL), remember to select the same parameterization in the settings of a given control panel input.
    o If the detector reports tamper during violation (motion detection), it most often means that incorrect resistors have been used, resistors have been inserted into these terminals, and the resistor legs have not been properly seated in the detector connectors.
    o If the detector is continuously violated, we first of all check if it has been properly powered.
    o In more advanced exchanges, such as, for example, all "+" integrateds, you will also encounter something like TEOL (3EOL). This is nothing more than parameterization with the use of 3 resistors, where the control panel detects another state. This is used, for example, when connecting detectors with anti-masking (by the way, I suggest you take an interest in detectors with this function). The control panel zone operating in this mode detects, apart from tamper, violation, normal status, and also masking of the detector. In control panels that do not support TEOL parameterization, the detector anti-masking output is simply connected to a separate control panel input.
    Good luck!
    Advertisement
    Also read:
    How to connect two alarm detectors on one cable. How to connect two detectors to one zone of the control panel and what are the consequences? Collection of topics
    We invite you to read the other guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
    suworow
    suworow wrote 8802 posts with rating 1278, helped 650 times. Live in city Wołomin. Been with us since 2006 year.
    Zbych034
    Help: 550
    Rate: 1417
    A small note for beginners.
    Please, when laying cables in the detector, pay attention not to lead to incorrect arrangement (short circuit) of the resistors. The detectors or alarm will not damage the detectors, but the detectors work incorrectly.
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    With 1 / 4W resistors there are no major problems, but with 1 / 8W I wrap the U-shaped wire ends of resistors because after connecting to a terminal with a thicker YTDY or UTP cable there is no reliable connection. I do the same with the tip of the insulated wire, which avoids the lack of contact with which I had a few cases after the introduction of 1 / 8W in Satellite.
    Rysiek2
    CCTV and Stationary Alarms specialist
    Help: 447
    Rate: 659
    I will allow myself to propose such a DEOL modification:
  • #5 18085712
    suworow
    Help: 650
    Rate: 1278
    In the title I wrote that it is about any detector, and I gave examples only of motion detectors.
    Well, let's look at the inertial detector VD-1 from Satel
    Has the same, same contacts as the motion detector:
    o two power contacts (COM + 12V)
    o two tamper contacts (TMP TMP)
    o two line contacts (NC NC), which simply indicate vibration detection for a change
    What's more, even the descriptions for these connectors are the same as for satellite motion detectors.
    If we want to connect it to the control panel in 2EOL (DEOL) parameterization, then we will do it in the way we know at the beginning of the guide.
    dariusz.bembenek
    Help: 455
    Rate: 615
    As everyone is also a brick from myself (I hope I will not repeat anyone, although I have read the thread (?))
    Where does the name "EOL" come from?
    EOL or - End Of Line ("End of the Line"). It is very important that the end-of-line resistors are ... at the end of the line. So they are supposed to be in the detector, not the control panel (see: popular error of beginners, who install resistors for the EOL configuration at the control panel inputs instead of the detectors).
    What does the current PN-EN50131 standard say about such creations as "DEOL, EOL, etc."?
    Nothing. The standard does not define such concepts, but only indicates that the detector should have, for example, anti-sabotage protection. It does not impose a technical solution, i.e. the standard does not say to insert resistors into the detector. The point is that the installer is to connect elements of the alarm system so that, for example, when the detector senses movement, the control panel knew that it was a move, while the detector knew that the control panel was open (sabotage) when the detector was opened. If the installer feels like it, he can connect the detector in the NC configuration and take several detector inputs. However ... alarm system manufacturers have come up with such "optimizations" as EOL, 2EOL, 3EOL, among others so that you can save the entry of the control panel. Of course, such configurations bring with them other improvements, such as the simple way to bypass the alarm line (by just using the "parameter" on the line, i.e. the resistors). For a person once in the life of the detector, it is not necessary to penetrate the details, but it is worth remembering that ... resistors to detectors are really worth inserting (that is, it's worth parameterizing the alarm lines).
    Nomenclature (various documentation from different manufacturers may state this differently). Generally:
    SEOL (Single EOL) = EOL
    DEOL (Double EOL) = 2EOL
    TEOL (Triple EOL) = 3EOL
    For example, the previously mentioned Integra Plus series (ie Integra, which meets the requirements for stage 3 according to PN-EN50131-1), has 3EOL not because the standard forces (see above). It has 3EOL, because it is more convenient to connect detectors with anti-masking function (it is enough to use one input for such a detector, and it will still be able to control all key signals from this detector).
    From level 3 of the said standard, detectors with an anti-mask function are required.
    But this "anti-masking" is a bit "embarrassing" thing. I can be wrong (standards are more extensive than it seems, especially when it comes to the interpretation of many entries), but the standard indicates that as a part of one of the tests you should use a black card (...). The microfile flips such a card without blinking and the conclusion is that the only "real" antimasking is the one that is based on infrared (of course not on the PIR track, only on the IR transmitter -> IR receiver). This is important, because a large number of detectors with anti-mask function is based on microwave (in dual detectors).
    See: Satel OPAL Plus and OPAL Pro. The PRO version has an infrared antimasking (and has a grade of 3), while OPAL Plus has antimasking implemented in the microwave (and has the degree 2). Opel's Satel is just an example, because what I wrote is not based on the degrees assigned to these detectors, but based on the standard.
  • #7 18102181
    suworow
    Help: 650
    Rate: 1278
    Examples of topics related to connecting alarm detectors to control panels:
    Connecting the Optex BXS ST detector to Satel Integra 32 in DEOL. So, as you know, basically every DEOL operating panel
    https://www.elektroda.pl/rtvforum/topic3603837.html#18102989
    Connecting the Satel TSD 1 smoke detector to the Ropam Neo control panel (the same principle applies when connecting to other control panels)
    https://www.elektroda.pl/rtvforum/topic3417434.html#16946119
    Two detectors on a 6-wire cable
    https://www.elektroda.pl/rtvforum/topic3417179.html
    Connecting the detector to the alarm control panel on the example of Satel Perfecta + Pyronix DD
    https://www.elektroda.pl/rtvforum/topic3423421.html
    Connecting two motion detectors to one control panel input without resistors (in NC)
    https://www.elektroda.pl/rtvforum/topic3399578.html
    Connecting two or more detectors to one control panel input in DEOL NC (here on the example of reed switches, but the same principle applies also to other devices)
    https://www.elektroda.pl/rtvforum/topic3518404.htm
    Connection of two motion detectors to one control panel input in DEOL NC
    https://www.elektroda.pl/rtvforum/topic339751.html#1720493
    And about why you should avoid connecting several detectors under one control panel line
    https://www.elektroda.pl/rtvforum/topic3526545.html#17609203
  • #9 18110493
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    (And for supplementation) it will additionally detect the opening of the reed switch (A or B), because the VD-1 detector has such a possibility.
  • Separate shock and reed outputs on Risco detector
    #10 18112095
    suworow
    Help: 650
    Rate: 1278
    Exactly, because this detector signals on the same contacts both violation of the inertial and reed switch sensors. Which, of course, boils down to the fact that we do not know which of these sensors an alarm was created.
    It is different in a Risco inertial detector with a built-in reed switch. There we have separate signal contacts for the shock detector and separate for the opening detector.
    So we can connect these two outputs to two independent control panel lines.
    However, if we want to connect this detector to one zone, we can use the diagrams contained in these topics:
    Ropam, three reed switches Satel S-4 in series
    SATEL CA-6 - two detectors per zone
The discussion focuses on connecting various types of detectors to alarm control panels, particularly emphasizing the compatibility of different brands and models. It highlights that while specific manuals may not provide detailed instructions for connecting third-party detectors, a general understanding of the basic contacts (power, tamper, and alarm) allows for successful integration. Key points include the importance of proper resistor placement in EOL (End Of Line) configurations, the similarities in contact types across different detectors, and practical examples of connecting specific models like the Satel VD-1 inertial detector and Optex BXS ST detector to various control panels. The conversation also addresses common installation errors and provides links to additional resources for further guidance.
