Connection diagram for detectors to Satel Perfecta 16 to be checked
spectrall 37710 1
  • #1 17728196
    spectrall
    Hello, can any of you check if I drew the detector and siren connection to the SATEL Perfecta 16 control unit correctly?
    1x Satel Perfecta 16 alarm control panel
    1x LCD keypad for Satel PRF-LCD system operation
    4x Paradox PRO Plus indoor motion detector
    1x acoustic-optical siren SL-550
    1x 40VA transformer
    1x 7.2Ah / 12V backup battery
    1x ANT-GSM-I dual-band antenna
    I will be grateful for the amendment, best regards
    Announcement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues Collection of topics
    Outputs (programmable and not only) of control panels
    How the control panel alarm outputs work
    Connecting any detector to any alarm control panel - guide
    How to connect the siren to the alarm control panel - guide
    We invite you to read the other guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
  • #2 17728364
    skyguy
    Help: 19
    Rate: 185
    It seems to me that something with the siren is wrong - but I never had it in my hand, poor instruction :)
    From right:
    TMP - tamper from tamper should be connected to the control panel input, not the output, i.e. Z8 will be elegant because you take the ground to the siren tamper from the side.
    GND - OK
    BAT +/-
    12+ there should be a permanent 12V power supply, i.e. some AUX
    12- here should be solid mass or some COM
    TR- - it seems to me that it is enough when you connect the low-current output O3 or O4 - this is only a signal to trigger, it does not have to be high-current
    Personally, I lead one mass to the detectors and then a bridge to the temp - but I'm an amateur and professionals will scold me here :) .
    The rest seems OK.
