Replacing the heater in the ATLANTIC 50l boiler with a stronger one
kacperrro1998 7146 4
  • 2000 W heater may overload the boiler thermostat
    #1 16512122
    kacperrro1998
    Hello!
    I need an advice. The heater in the Atlantic 50l boiler burned out (1600w heater). I found one that was used with the same mounting and the same thermostat, but with a power of 2000w, which was installed in a 10l boiler. And here arises my doubt as to whether this heater is a good choice. Will it burn out after a while. Will the assumption of a more powerful heater be more beneficial from the economic point of view? Since the heater will be stronger, the water will heat up faster, will I pay less for electricity or vice versa, the electricity consumption will be greater?
    Photos of the heater that has burnt out and the rating plate on the boiler:
    Pictures of the heater I am going to buy and the rating plate of the boiler from which the heater comes from.
    stanislaw1954
    Help: 2013
    Rate: 4675
    Higher power of the heater = higher current, but the same amount of water heated faster. It will be similar for payment.
  • #3 16512146
    kacperrro1998
    So I can easily set up this heater despite the fact that it previously operated on a smaller tank?
    karolark
    Help: 702
    Rate: 2517
    No problem if it physically fits :D
  • #5 16512159
    kacperrro1998
    Thank you for your help. I am closing the thread.
