Renualt Megane Scenic 1.6E - Checking the oil level in the gearbox
sebfire 10443 5
  • #1 16514870
    sebfire
    Help: 20
    Rate: 21
    Where to check the oil level in the gearbox on Renualt Megane Scenic 1.6E.
    sanfran
    Help: 963
    Rate: 3004
    Scenic is not a >> Big Fiat
  • #3 16514918
    sebfire
    Help: 20
    Rate: 21
    Manual gearbox. 1997 car.
    Maybe the vehicle identification number will help?
  • #4 16514943
    sanfran
    Help: 963
    Rate: 3004
    No VIN needed.
    Check if the filler cap is in this place: Renualt Megane Scenic 1.6E - Checking the oil level in the gearbox Renualt Megane Scenic 1.6E - Checking the oil level in the gearbox
    Constant oil dripping when the car is standing on level ground indicates the correct level.
  • #5 16514961
    sebfire
    Help: 20
    Rate: 21
    And what oil do you recommend for the gearbox?
  • #6 16514985
    sanfran
    Help: 963
    Rate: 3004
    Gearbox with a viscosity grade of 75W-90 will be OK.
