Renault Megane Scenic '98 - Oil Pan Gasket Replacement on 1.6 Engine, 66.00kW, No Lift
ppp47676 6324 4
  • #1 16332097
    ppp47676
    Rate: 22
    Hello, can the oil pan gasket be replaced without lifting the engine on Megane Scenic?
    Capacity - 66.00kw
    Yearbook - 98
    Engine - 1.6
  • #2 16332383
    jenusz11
    Help: 33
    Rate: 196
    you can, but you must lower the cradle
  • #3 16332422
    vemo
    Rate: 23
    In sII and SIII you can
  • #4 16332864
    kamiloskop
    Help: 42
    Rate: 279
    There is no need to leave the sledge when it comes to SC ii
  • #5 16333007
    vemo
    Rate: 23
    kamiloskop wrote:
    for SC 1
    when and where can I drive you to do it ?????
