Disabling Digital Signature Control on Asus R556L-W8.1/64 for VCDS Car Diagnostic Program
MM2X 6687 5
  • #1 16517401
    MM2X
    Rate: 618
    I uploaded on the laptop (Asus R556L-W8.1 / 64) the car diagnostic program VCDS, which previously went on W7 / 64. I can't install the drivers because they are probably not digitally signed. I read on the net that in this case you should turn off digital signature control.
    1 /. How to do it?
    2 /. Will you need to enable this check after installing the drivers again.
    3 /. Does disabling / enabling this control affect previously installed programs?
    oun
    Help: 39
    Rate: 96
    1. link
    2. For security you should but do not have to.
    3. It has no effect as long as every installed driver (without signature) does not affect it.
  • #3 16517470
    MM2X
    Rate: 618
    I found this instruction earlier and came to the screen where the F7 key should be "disable enforcement" and unfortunately I can't select it. As if the function key (s) did not work through the fn button as well as through the control panel, nothing can be initialized / changed, control panel -> hardware and sound -> mobility center ... and I don't have the option "adjust frequently used settings" :(
    I have options such as turning the speaker on / off via fn + F10 fn + F12 but the F7 itself does not work :( , I read on the net that you need to change something in the bios.
    oun
    Help: 39
    Rate: 96
    Menu start / Run / cmd and enter.
    In the console:
    bcdedit / set nointegritychecks ON
    and to enable the installation of signed drivers:
    bcdedit / set nointegritychecks OFF
    After changing the computer restart
  • #6 16517713
    MM2X
    Rate: 618
    Thanks very much to my colleagues, I managed according to the first instruction, I connected an external keyboard and got the F7 option, installed the drivers and program, it just came back from the garage and everything "reads" the car :) .
    The only thing left is whether to turn digital signature control back on, probably according to the same instructions.
    Thanks again for your time.
