How can I remove a bad unsigned driver that stops Windows 7 from booting, without reinstalling Windows?
Delete the offending driver file from Windows rather than trying to bypass signature checks: use `sigverif.exe` to find unsigned drivers, identify `cfadisk.sys` in `C:\Windows\System32\drivers`, and remove it [#16882355][#16882435] The thread author reported that this file was the only boot-time driver marked `R0` (running at boot), which explained why Windows would only start with driver signature enforcement disabled [#16882355] If needed, boot from recovery media to run repair tools like `bootrec`, but `bootrec` must be run from the recovery environment, not normal CMD [#16882355] A rootkit scanner such as TDSSKiller was also suggested, but in the end deleting `cfadisk.sys` fixed the boot problem and Windows started normally again [#16882435] After that, the original ASUS card-reader drivers in the `AmIcoSingLun` folder still worked, so the reader function was restored without keeping the bad driver [#16882435]
Hello everyone. I needed to see two SD card partitions (FAT and ext2) in Windows and was looking for a solution. I installed two things. It seems to me that one of them is causing Windows 7 to not turn on (after installing the drivers, a message probably popped up that the drivers are not digitally signed). It is possible to turn on Windows only when I select F8 and the option "Disable driver signature enforcement." I have already removed one program and reinstalled the driver for the SD card reader on the computer, but it did not solve the problem. Is there any way to get rid of unwanted drivers without reinstalling Windows?
Error which appears during boot when Windows is in the "Windows is starting" message stage: 0xc000000e The boot selection failed because a required device is inaccessible.
A program was installed Ext2Fsd-0.69 and the driver for the SD card reader found on the network - Hitachi Microdrive - a file called cfadisk-x64-1.zip from this post ).
Start your computer in Safe Mode. Uninstall the disk controller drivers (both IDE channels). Restart the system.
Safe mode does not work - there is the same error as if I turned on Windows normally. In the "Disable enforcement of driver signatures" mode. I can see one IDE channel, uninstalling it didn't help.
"The name 'bootrec' is not recognized as an internal or external command, executable program or batch file. "- Am I doing something wrong? (CMD as administrator)
Files from FRST attached. I also did additional scans (BCD and MD5 driver list) if what.
I would like to add that I also tried to repair the computer with Windows 7 Repair Disca from a USB flash drive (no CD), but he found nothing and could not fix it (and it helped me even after I cloned the HDD to a new SSD).
Addition.txt(34.23 KB)
You must be logged in to download this attachment.
FRST.txt(97.18 KB)
Well, you would have to boot from the Recovery CD (in your case from the pen).
I ran bootrec from this recovery. The information appeared: "Total identified Windows Installations: 0".
Move this folder to another location: C: \ Program Files (x86) \ AmIcoSingLun \
It was the factory driver from the SD card reader (along with Windows). As the computer stopped turning on, I saved myself by reinstalling the drivers from Asus. Nevertheless, I moved and to no avail.
Damn it. You have some "cuckoo" here. All of them probably the drivers stopped having signatures:
Spoiler:
S3 1394ohci; C: \ Windows \ system32 \ DRIVERS \ 1394ohci.sys [227840 2009-07-14] (Microsoft Corporation) [No digital signature] S3 AcpiPmi; C: \ Windows \ system32 \ DRIVERS \ acpipmi.sys [12288 2009-07-14] (Microsoft Corporation) [No digital signature] R1 AFD; C: \ Windows \ system32 \ drivers \ afd.sys [500224 2009-07-14] (Microsoft Corporation) [No digital signature] S3 AmdK8; C: \ Windows \ system32 \ DRIVERS \ amdk8.sys [64512 2009-07-14] (Microsoft Corporation) [No digital signature] S3 AmdPPM; C: \ Windows \ system32 \ DRIVERS \ amdppm.sys [60928 2009-07-14] (Microsoft Corporation) [No digital signature] S3 AmUStor; C: \ Windows \ System32 \ drivers \ AmUStor.SYS [44032 2009-08-21] (Alcor Micro, Corp.) [No digital signature] S3 AppID; C: \ Windows \ system32 \ drivers \ appid.sys [61440 2009-07-14] (Microsoft Corporation) [No digital signature] R2 ASMMAP64; C: \ Program Files \ ATKGFNEX \ ASMMAP64.sys [14904 2007-07-24] () R3 AsyncMac; C: \ Windows \ System32 \ DRIVERS \ asyncmac.sys [23040 2009-07-14] (Microsoft Corporation) [No digital signature] R3 athr; C: \ Windows \ System32 \ DRIVERS \ athrx.sys [1542656 10/5/2009] (Atheros Communications, Inc.) [No digital signature] S3 b06bdrv; C: \ Windows \ system32 \ DRIVERS \ bxvbda.sys [468480 2009-06-10] (Broadcom Corporation) [No digital signature] S3 b57nd60a; C: \ Windows \ System32 \ DRIVERS \ b57nd60a.sys [270848 2009-06-10] (Broadcom Corporation) [No digital signature] R1 Beep; C: \ Windows \ System32 \ Drivers \ Beep.sys [6656 2009-07-14] (Microsoft Corporation) [No digital signature] R1 blbdrive; C: \ Windows \ System32 \ DRIVERS \ blbdrive.sys [45056 2009-07-14] (Microsoft Corporation) [No digital signature] R3 bowser; C: \ Windows \ System32 \ DRIVERS \ bowser.sys [90624 2009-07-14] (Microsoft Corporation) [No digital signature] S3 BrFiltLo; C: \ Windows \ system32 \ DRIVERS \ BrFiltLo.sys [18432 6/10/2009] (Brother Industries, Ltd.) [No digital signature] S3 BrFiltUp; C: \ Windows \ system32 \ DRIVERS \ BrFiltUp.sys [8704 6/10/2009] (Brother Industries, Ltd.) [No digital signature] S3 Brserid; C: \ Windows \ System32 \ Drivers \ Brserid.sys [286720 2009-07-14] (Brother Industries Ltd.) [No digital signature] S3 BrSerWdm; C: \ Windows \ System32 \ Drivers \ BrSerWdm.sys [47104 6/10/2009] (Brother Industries Ltd.) [No digital signature] S3 BrUsbMdm; C: \ Windows \ System32 \ Drivers \ BrUsbMdm.sys [14976 6/10/2009] (Brother Industries Ltd.) [No digital signature] S3 BrUsbSer; C: \ Windows \ System32 \ Drivers \ BrUsbSer.sys [14720 Jun 10, 2009] (Brother Industries Ltd.) [No digital signature] S3 BthEnum; C: \ Windows \ System32 \ DRIVERS \ BthEnum.sys [41984 2009-07-14] (Microsoft Corporation) [No digital signature] S3 BTHMODEM; C: \ Windows \ system32 \ DRIVERS \ bthmodem.sys [72192 2009-07-14] (Microsoft Corporation) [No digital signature] S3 BthPan; C: \ Windows \ System32 \ DRIVERS \ bthpan.sys [118784 2009-07-14] (Microsoft Corporation) [No digital signature] S3 BTHPORT; C: \ Windows \ System32 \ Drivers \ BTHport.sys [551936 2009-07-14] (Microsoft Corporation) [No digital signature] S3 BTHUSB; C: \ Windows \ System32 \ Drivers \ BTHUSB.sys [79360 2009-07-14] (Microsoft Corporation) [No digital signature] S4 cdfs; C: \ Windows \ System32 \ DRIVERS \ cdfs.sys [92160 2009-07-14] (Microsoft Corporation) [No digital signature] S1 cdrom; C: \ Windows \ System32 \ DRIVERS \ cdrom.sys [147456 2009-07-14] (Microsoft Corporation) [No digital signature] R0 cfadisk; C: \ Windows \ System32 \ DRIVERS \ cfadisk.sys [7168 2011-03-27] (Hitachi Global Storage Technologies) [No digital signature] S3 circlass; C: \ Windows \ system32 \ DRIVERS \ circlass.sys [45568 2009-07-14] (Microsoft Corporation) [No digital signature] R3 CmBatt; C: \ Windows \ System32 \ DRIVERS \ CmBatt.sys [17664 2009-07-14] (Microsoft Corporation) [No digital signature] R3 CompositeBus; C: \ Windows \ System32 \ DRIVERS \ CompositeBus.sys [38912 2009-07-14] (Microsoft Corporation) [No digital signature] R1 DfsC; C: \ Windows \ System32 \ Drivers \ dfsc.sys [102400 2009-07-14] (Microsoft Corporation) [No digital signature] R1 discache; C: \ Windows \ System32 \ drivers \ discache.sys [40448 2009-07-14] (Microsoft Corporation) [No digital signature] S3 drmkaud; C: \ Windows \ System32 \ drivers \ drmkaud.sys [5632 2009-07-14] (Microsoft Corporation) [No digital signature] R1 eamonm; C: \ Windows \ System32 \ DRIVERS \ eamonm.sys [262792 2017-11-28] (ESET) S3 ebdrv; C: \ Windows \ system32 \ DRIVERS \ evbda.sys [3286016 Jun 10, 2009] (Broadcom Corporation) [No digital signature] R1 ehdrv; C: \ Windows \ System32 \ DRIVERS \ ehdrv.sys [197248 2017-11-28] (ESET) R2 epfwwfpr; C: \ Windows \ system32 \ DRIVERS \ epfwwfpr.sys [181384 2017-11-28] (ESET) S3 epmntdrv; C: \ Windows \ system32 \ epmntdrv.sys [24056 2016-01-14] () [No digital signature] S3 epmntdrv; C: \ Windows \ SysWOW64 \ epmntdrv.sys [21496 2016-01-14] () [No digital signature] S3 ErrDev; C: \ Windows \ system32 \ DRIVERS \ errdev.sys [9728 2009-07-14] (Microsoft Corporation) [No digital signature] R3 ETD; C: \ Windows \ System32 \ DRIVERS \ ETD.sys [117760 2009-10-15] (ELAN Microelectronic Corp.) [No digital signature] S3 EuGdiDrv; C: \ Windows \ system32 \ EuGdiDrv.sys [10848 2016-07-11] () [No digital signature] S3 EuGdiDrv; C: \ Windows \ SysWOW64 \ EuGdiDrv.sys [10208 2016-07-11] () [No digital signature] S3 exfat; C: \ Windows \ System32 \ Drivers \ exfat.sys [195072 2009-07-14] (Microsoft Corporation) [No digital signature] S3 fastfat; C: \ Windows \ System32 \ Drivers \ fastfat.sys [204800 2009-07-14] (Microsoft Corporation) [No digital signature] S3 fdc; C: \ Windows \ system32 \ DRIVERS \ fdc.sys [29696 2009-07-14] (Microsoft Corporation) [No digital signature] S3 Filetrace; C: \ Windows \ System32 \ drivers \ filetrace.sys [34304 2009-07-14] (Microsoft Corporation) [No digital signature] S3 flpydisk; C: \ Windows \ system32 \ DRIVERS \ flpydisk.sys [24576 2009-07-14] (Microsoft Corporation) [No digital signature] S3 hcw85cir; C: \ Windows \ system32 \ drivers \ hcw85cir.sys [31232 2009-06-10] (Hauppauge Computer Works, Inc.) [No digital signature] S3 HdAudAddService; C: \ Windows \ System32 \ drivers \ HdAudio.sys [350208 2009-07-14] (Microsoft Corporation) [No digital signature] R3 HDAudBus; C: \ Windows \ System32 \ DRIVERS \ HDAudBus.sys [122368 2009-07-14] (Microsoft Corporation) [No digital signature] S3 HidBatt; C: \ Windows \ system32 \ DRIVERS \ HidBatt.sys [26624 2009-07-14] (Microsoft Corporation) [No digital signature] S3 HidBth; C: \ Windows \ system32 \ DRIVERS \ hidbth.sys [100864 2009-07-14] (Microsoft Corporation) [No digital signature] S3 HidIr; C: \ Windows \ system32 \ DRIVERS \ hidir.sys [46592 2009-07-14] (Microsoft Corporation) [No digital signature] R3 HidUsb; C: \ Windows \ System32 \ DRIVERS \ hidusb.sys [30208 2009-07-14] (Microsoft Corporation) [No digital signature] S3 HPEWSFXBULK; C: \ Windows \ System32 \ drivers \ hpfx64bulk.sys [27544 2017-09-21] (Hewlett Packard) R3 HTTP; C: \ Windows \ System32 \ drivers \ HTTP.sys [751616 2009-07-14] (Microsoft Corporation) [No digital signature] R3 i8042prt; C: \ Windows \ System32 \ DRIVERS \ i8042prt.sys [105472 2009-07-14] (Microsoft Corporation) [No digital signature] S3 igfx; C: \ Windows \ System32 \ DRIVERS \ igdkmd64.sys [7345632 2009-07-28] (Intel Corporation) [No digital signature] R3 intelppm; C: \ Windows \ System32 \ DRIVERS \ intelppm.sys [62464 2009-07-14] (Microsoft Corporation) [No digital signature] S3 IpFilterDriver; C: \ Windows \ System32 \ DRIVERS \ ipfltdrv.sys [82944 2009-07-14] (Microsoft Corporation) [No digital signature] S3 IPMIDRV; C: \ Windows \ system32 \ DRIVERS \ IPMIDrv.sys [78848 2009-07-14] (Microsoft Corporation) [No digital signature] S3 IPNAT; C: \ Windows \ System32 \ drivers \ ipnat.sys [116224 2009-07-14] (Microsoft Corporation) [No digital signature] S3 IRENUM; C: \ Windows \ System32 \ drivers \ irenum.sys [17920 2009-07-14] (Microsoft Corporation) [No digital signature] R3 kbdhid; C: \ Windows \ System32 \ DRIVERS \ kbdhid.sys [33280 2009-07-14] (Microsoft Corporation) [No digital signature] R3 kbfilter; C: \ Windows \ System32 \ DRIVERS \ kbfiltr.sys [15416 2009-07-20] () R3 ksthunk; C: \ Windows \ system32 \ drivers \ ksthunk.sys [20992 2009-07-14] (Microsoft Corporation) [No digital signature] R3 L1C; C: \ Windows \ System32 \ DRIVERS \ L1C62x64.sys [62464 2009-09-04] (Atheros Communications, Inc.) [No digital signature] R2 ltdio; C: \ Windows \ System32 \ DRIVERS \ lltdio.sys [60928 2009-07-14] (Microsoft Corporation) [No digital signature] R2 luafv; C: \ Windows \ system32 \ drivers \ luafv.sys [113152 2009-07-14] (Microsoft Corporation) [No digital signature] S3 Modem; C: \ Windows \ System32 \ drivers \ modem.sys [40448 2009-07-14] (Microsoft Corporation) [No digital signature] R3 monitor; C: \ Windows \ System32 \ DRIVERS \ monitor.sys [30208 2009-07-14] (Microsoft Corporation) [No digital signature] R3 mouhid; C: \ Windows \ System32 \ DRIVERS \ mouhid.sys [31232 2009-07-14] (Microsoft Corporation) [No digital signature] R3 mpsdrv; C: \ Windows \ System32 \ drivers \ mpsdrv.sys [77312 2009-07-14] (Microsoft Corporation) [No digital signature] S3 MRxDAV; C: \ Windows \ system32 \ drivers \ mrxdav.sys [140800 2009-07-14] (Microsoft Corporation) [No digital signature] R3 mrxsmb; C: \ Windows \ System32 \ DRIVERS \ mrxsmb.sys [157696 2010-04-12] (Microsoft Corporation) [No digital signature] R3 mrxsmb10; C: \ Windows \ System32 \ DRIVERS \ mrxsmb10.sys [285696 2010-04-12] (Microsoft Corporation) [No digital signature] R3 mrxsmb20; C: \ Windows \ System32 \ DRIVERS \ mrxsmb20.sys [125952 2009-07-14] (Microsoft Corporation) [No digital signature] S3 mshidkmdf; C: \ Windows \ System32 \ drivers \ mshidkmdf.sys [8192 2009-07-14] (Microsoft Corporation) [No digital signature] S3 MSKSSRV; C: \ Windows \ System32 \ drivers \ MSKSSRV.sys [11136 2009-07-14] (Microsoft Corporation) [No digital signature] S3 MSPCLOCK; C: \ Windows \ System32 \ drivers \ MSPCLOCK.sys [7168 2009-07-14] (Microsoft Corporation) [No digital signature] S3 MSPQM; C: \ Windows \ System32 \ drivers \ MSPQM.sys [6784 2009-07-14] (Microsoft Corporation) [No digital signature] S3 MSTEE; C: \ Windows \ System32 \ drivers \ MSTEE.sys [8064 2009-07-14] (Microsoft Corporation) [No digital signature] S3 MTConfig; C: \ Windows \ system32 \ DRIVERS \ MTConfig.sys [15360 2009-07-14] (Microsoft Corporation) [No digital signature] R3 NativeWifiP; C: \ Windows \ System32 \ DRIVERS \ nwifi.sys [318976 2009-07-14] (Microsoft Corporation) [No digital signature] S3 NdisCap; C: \ Windows \ System32 \ DRIVERS \ ndiscap.sys [35328 2009-07-14] (Microsoft Corporation) [No digital signature] R3 NdisTapi; C: \ Windows \ System32 \ DRIVERS \ ndistapi.sys [24064 2009-07-14] (Microsoft Corporation) [No digital signature] R3 Ndisuio; C: \ Windows \ System32 \ DRIVERS \ ndisuio.sys [56320 2009-07-14] (Microsoft Corporation) [No digital signature] R3 NdisWan; C: \ Windows \ System32 \ DRIVERS \ ndiswan.sys [164352 2009-07-14] (Microsoft Corporation) [No digital signature] R3 NDProxy; C: \ Windows \ System32 \ Drivers \ NDProxy.sys [57856 2009-07-14] (Microsoft Corporation) [No digital signature] R1 NetBIOS; C: \ Windows \ System32 \ DRIVERS \ netbios.sys [44544 2009-07-14] (Microsoft Corporation) [No digital signature] R1 NetBT; C: \ Windows \ System32 \ DRIVERS \ netbt.sys [259072 2009-07-14] (Microsoft Corporation) [No digital signature] R1 Npfs; C: \ Windows \ System32 \ Drivers \ Npfs.sys [44032 2009-07-14] (Microsoft Corporation) [No digital signature] R1 nsiproxy; C: \ Windows \ System32 \ drivers \ nsiproxy.sys [24576 2009-07-14] (Microsoft Corporation) [No digital signature] R1 Null; C: \ Windows \ System32 \ Drivers \ Null.sys [6144 2009-07-14] (Microsoft Corporation) [No digital signature] S3 ohci1394; C: \ Windows \ system32 \ DRIVERS \ ohci1394.sys [72832 2009-07-14] (Microsoft Corporation) [No digital signature] S3 Parport; C: \ Windows \ system32 \ DRIVERS \ parport.sys [97280 2009-07-14] (Microsoft Corporation) [No digital signature] R2 PEAUTH; C: \ Windows \ System32 \ drivers \ peauth.sys [651264 2009-07-14] (Microsoft Corporation) [No digital signature] R3 PptpMiniport; C: \ Windows \ System32 \ DRIVERS \ raspptp.sys [111616 2009-07-14] (Microsoft Corporation) [No digital signature] S3 Processor; C: \ Windows \ system32 \ DRIVERS \ processr.sys [60416 2009-07-14] (Microsoft Corporation) [No digital signature] R1 Psched; C: \ Windows \ System32 \ DRIVERS \ pacer.sys [131584 2009-07-14] (Microsoft Corporation) [No digital signature] R0 pwdrvio; C: \ Windows \ System32 \ pwdrvio.sys [19152 2013-09-30] () S3 pwdspio; C: \ Windows \ system32 \ pwdspio.sys [12504 2013-09-30] () S3 QWAVEdrv; C: \ Windows \ system32 \ drivers \ qwavedrv.sys [46592 2009-07-14] (Microsoft Corporation) [No digital signature] S3 RasAcd; C: \ Windows \ System32 \ DRIVERS \ rasacd.sys [14848 2009-07-14] (Microsoft Corporation) [No digital signature] R3 RasAgileVpn; C: \ Windows \ System32 \ DRIVERS \ AgileVpn.sys [60416 2009-07-14] (Microsoft Corporation) [No digital signature] R3 Rasl2tp; C: \ Windows \ System32 \ DRIVERS \ rasl2tp.sys [130048 2009-07-14] (Microsoft Corporation) [No digital signature] R3 RasPppoe; C: \ Windows \ System32 \ DRIVERS \ raspppoe.sys [92672 2009-07-14] (Microsoft Corporation) [No digital signature] R3 RasSstp; C: \ Windows \ System32 \ DRIVERS \ rassstp.sys [83968 2009-07-14] (Microsoft Corporation) [No digital signature] R1 rdbss; C: \ Windows \ System32 \ DRIVERS \ rdbss.sys [309248 2009-07-14] (Microsoft Corporation) [No digital signature] S3 rdpbus; C: \ Windows \ system32 \ DRIVERS \ rdpbus.sys [24064 2009-07-14] (Microsoft Corporation) [No digital signature] R1 RDPCDD; C: \ Windows \ System32 \ DRIVERS \ RDPCDD.sys [7680 2009-07-14] (Microsoft Corporation) [No digital signature] R1 RDPENCDD; C: \ Windows \ System32 \ drivers \ rdpencdd.sys [7680 2009-07-14] (Microsoft Corporation) [No digital signature] R1 RDPREFMP; C: \ Windows \ System32 \ drivers \ rdprefmp.sys [8192 2009-07-14] (Microsoft Corporation) [No digital signature] S3 RDPWD; C: \ Windows \ System32 \ Drivers \ RDPWD.sys [204800 2009-07-14] (Microsoft Corporation) [No digital signature] S3 RFCOMM; C: \ Windows \ System32 \ DRIVERS \ rfcomm.sys [158720 2009-07-14] (Microsoft Corporation) [No digital signature] R2 rspndr; C: \ Windows \ System32 \ DRIVERS \ rspndr.sys [76800 2009-07-14] (Microsoft Corporation) [No digital signature] S3 scfilter; C: \ Windows \ System32 \ DRIVERS \ scfilter.sys [29696 2009-07-14] (Microsoft Corporation) [No digital signature] R2 secdrv; C: \ Windows \ System32 \ Drivers \ secdrv.sys [23040 Jun 10, 2009] (Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia KK) [No digital signature] S3 Serenum; C: \ Windows \ system32 \ DRIVERS \ serenum.sys [23552 2009-07-14] (Microsoft Corporation) [No digital signature] S3 Serial; C: \ Windows \ system32 \ DRIVERS \ serial.sys [94208 2009-07-14] (Microsoft Corporation) [No digital signature] S3 sermouse; C: \ Windows \ system32 \ DRIVERS \ sermouse.sys [26624 2009-07-14] (Microsoft Corporation) [No digital signature] S3 sffdisk; C: \ Windows \ system32 \ DRIVERS \ sffdisk.sys [14336 2009-07-14] (Microsoft Corporation) [No digital signature] S3 sffp_mmc; C: \ Windows \ system32 \ DRIVERS \ sffp_mmc.sys [13824 2009-07-14] (Microsoft Corporation) [No digital signature] S3 sffp_sd; C: \ Windows \ system32 \ DRIVERS \ sffp_sd.sys [14336 2009-07-14] (Microsoft Corporation) [No digital signature] S3 sfloppy; C: \ Windows \ system32 \ DRIVERS \ sfloppy.sys [16896 2009-07-14] (Microsoft Corporation) [No digital signature] S3 SiSGbeLH; C: \ Windows \ System32 \ DRIVERS \ SiSG664.sys [56832 6/10/2009] (Silicon Integrated Systems Corp.) [No digital signature] S3 Smb; C: \ Windows \ System32 \ DRIVERS \ smb.sys [93184 2009-07-14] (Microsoft Corporation) [No digital signature] S3 SNP2UVC; C: \ Windows \ System32 \ DRIVERS \ snp2uvc.sys [1799680 2009-07-17] () [No digital signature] R3 srv; C: \ Windows \ System32 \ DRIVERS \ srv.sys [464896 2010-04-12] (Microsoft Corporation) [No digital signature] R3 srv2; C: \ Windows \ System32 \ DRIVERS \ srv2.sys [407040 2009-07-14] (Microsoft Corporation) [No digital signature] R3 srvnet; C: \ Windows \ System32 \ DRIVERS \ srvnet.sys [162304 2010-04-12] (Microsoft Corporation) [No digital signature] R2 tcpipreg; C: \ Windows \ System32 \ drivers \ tcpipreg.sys [44544 2009-07-14] (Microsoft Corporation) [No digital signature] S3 TDPIPE; C: \ Windows \ System32 \ drivers \ tdpipe.sys [15872 2009-07-14] (Microsoft Corporation) [No digital signature] S3 TDTCP; C: \ Windows \ System32 \ drivers \ tdtcp.sys [23552 2009-07-14] (Microsoft Corporation) [No digital signature] R1 tdx; C: \ Windows \ System32 \ DRIVERS \ tdx.sys [99840 2009-07-14] (Microsoft Corporation) [No digital signature] S3 tssecsrv; C: \ Windows \ System32 \ DRIVERS \ tssecsrv.sys [38400 2009-07-14] (Microsoft Corporation) [No digital signature] R3 tunnel; C: \ Windows \ System32 \ DRIVERS \ tunnel.sys [125440 2009-07-14] (Microsoft Corporation) [No digital signature] S4 udfs; C: \ Windows \ System32 \ DRIVERS \ udfs.sys [327168 2009-07-14] (Microsoft Corporation) [No digital signature] R3 umbus; C: \ Windows \ System32 \ DRIVERS \ umbus.sys [48640 2009-07-14] (Microsoft Corporation) [No digital signature] S3 UmPass; C: \ Windows \ system32 \ DRIVERS \ umpass.sys [9728 2009-07-14] (Microsoft Corporation) [No digital signature] R3 usbccgp; C: \ Windows \ System32 \ DRIVERS \ usbccgp.sys [98816 2009-07-14] (Microsoft Corporation) [No digital signature] S3 usbcir; C: \ Windows \ system32 \ DRIVERS \ usbcir.sys [100352 2009-07-14] (Microsoft Corporation) [No digital signature] R3 usbehci; C: \ Windows \ System32 \ DRIVERS \ usbehci.sys [51200 2009-07-14] (Microsoft Corporation) [No digital signature] R3 usbhub; C: \ Windows \ System32 \ DRIVERS \ usbhub.sys [343040 2009-07-14] (Microsoft Corporation) [No digital signature] S3 usbohs; C: \ Windows \ system32 \ DRIVERS \ usbohci.sys [25600 2009-07-14] (Microsoft Corporation) [No digital signature] S3 usbprint; C: \ Windows \ System32 \ DRIVERS \ usbprint.sys [25088 2009-07-14] (Microsoft Corporation) [No digital signature] S3 USBSTOR; C: \ Windows \ System32 \ DRIVERS \ USBSTOR.SYS [89600 2009-07-14] (Microsoft Corporation) [No digital signature] R3 usbuhci; C: \ Windows \ System32 \ DRIVERS \ usbuhci.sys [30720 2009-07-14] (Microsoft Corporation) [No digital signature] R3 usbvideo; C: \ Windows \ System32 \ Drivers \ usbvideo.sys [184576 7/14/2009] (Microsoft Corporation) [No digital signature] S3 VClone; C: \ Windows \ System32 \ DRIVERS \ VClone.sys [36864 2013-07-24] (Elaborate Bytes AG) [No digital signature] S3 vga; C: \ Windows \ System32 \ DRIVERS \ vgapnp.sys [29184 2009-07-14] (Microsoft Corporation) [No digital signature] R1 VgaSave; C: \ Windows \ System32 \ drivers \ vga.sys [29184 2009-07-14] (Microsoft Corporation) [No digital signature] R3 vwifibus; C: \ Windows \ System32 \ DRIVERS \ vwifibus.sys [24576 2009-07-14] (Microsoft Corporation) [No digital signature] R1 vwififlt; C: \ Windows \ System32 \ DRIVERS \ vwififlt.sys [59904 2009-07-14] (Microsoft Corporation) [No digital signature] S3 WacomPen; C: \ Windows \ system32 \ DRIVERS \ wacompen.sys [27776 2009-07-14] (Microsoft Corporation) [No digital signature] S3 WANARP; C: \ Windows \ System32 \ DRIVERS \ wanarp.sys [88576 2009-07-14] (Microsoft Corporation) [No digital signature] R1 Wanarpv6; C: \ Windows \ System32 \ DRIVERS \ wanarp.sys [88576 2009-07-14] (Microsoft Corporation) [No digital signature] R1 WfpLwf; C: \ Windows \ System32 \ DRIVERS \ wfplwf.sys [12800 2009-07-14] (Microsoft Corporation) [No digital signature] R3 WmiAcpi; C: \ Windows \ System32 \ DRIVERS \ wmiacpi.sys [14336 2009-07-14] (Microsoft Corporation) [No digital signature] S4 ws2ifsl; C: \ Windows \ system32 \ drivers \ ws2ifsl.sys [21504 2009-07-14] (Microsoft Corporation) [No digital signature] R3 WudfPf; C: \ Windows \ System32 \ drivers \ WudfPf.sys [112128 2009-07-14] (Microsoft Corporation) [No digital signature] S3 WUDFRd; C: \ Windows \ System32 \ DRIVERS \ WUDFRd.sys [172544 2009-07-14] (Microsoft Corporation) [No digital signature] U3 tmlwf; ImagePath is missing U3 tmwfp; ImagePath is missing
Was it an infection?
NOD has not detected anything so far. Was it something else? To be saved with some programs?
### SOLUTION ### Added after 54 [minutes]:
NOD found nothing on C while scanning, so I kept looking. I googled the topic and managed to find a solution on English-language websites.
1. Basing on first this Microsoft website I used the app sigverif.exe to find drivers that are not signed. For information purposes, the program showed that 69 out of 251 files are unsigned. However, on the list I found a familiar driver that I was installing - cfadisk.sys. I found its place in system32 / drivers and simply deleted it. 2. From this topic on bleepingcomputer I caught that the TDSSKiller application had removed a rootkit that was causing similar symptoms to me. I fired it up but found nothing - I suspect the rootkit file is the cfadisk.sys I deleted earlier. 3. I started my computer and everything works. Still sigverif.exe it shouts that 68 files are unsigned, but essential that the computer is working fine. :)
Nevertheless, thank you for contributing to the topic.
As a comment, after the correspondence with the user of safbot1st (outside the topic):
safbot1st wrote:
The only one on the list marked with R0 - i.e. running, boot. That would explain a lot.
safbot1st wrote:
Cool, but now the reader is not working, right? ? ? You had some nice infection there. Let's hope she's gone.
lucasville wrote:
The reader works. I reinstalled the ASUS drivers (C: \ Program Files (x86) \ AmIcoSingLun folder) and everything is ok. It has detected the card nicely and I have full functionality.
There was an infection, but I think the name is "non-aggressive", because simply deleting the driver file that was uploaded to see two partitions on the SD card solved the problem. Perhaps his assumption was to cancel the digital signature so that Windows would allow it to load.
Summarizing: there is no trace of the problem. Everything, including the card reader, works.
Since the reader is working, I'm sorry for bothering you. Interestingly, by the way, it works without cfadisk.sys. Additionally, it is worth "signing" the rest of the drivers for the future. Maybe there is such a function in windows ....
That would explain a lot. I just read PW.
I connected the old original disk with a clean system (before cloning to the current one). Out of 256 drivers, only 6 are unsigned, so this cfadisk broke more drivers. Fortunately, this is not a pressing problem. I will try to look for a solution in my free time, how to sign the remaining drivers, and if I fail, it will probably slow down in some time and I will put it up again.
Edition 17 December 2017 The problem with digital signing of these dozen files comes from disk cloning. The drivers lose their digital signature immediately after cloning. It was not the fault of mixing in the drivers.
Worst of all, I figured it out because Windows Update is completely down for me. Everything is OK on the original disk. After cloning to an SSD, it stops working immediately. I am cloning because I have a hidden partition on the factory disk and I installed pure Windows from it. It is probably a matter of the disk driver. I refer to Microsoft's website: No. 1 (in English) and No. 2 (in Polish)
These are 2 serious problems. Once properly cloned, there should be no differences. What program are you cloning? A damaged WU can have unpleasant consequences. Here my friend fought, I don't know, for six months ?: https://www.elektroda.pl/rtvforum/topic3392337-30.html#16890722
Why do you need a hidden partition and why hide the WIN installation? Maybe that's the problem?
The program is EasyUS Todo Backup. From my previous post, where I pasted two links to Microsoft's website, it appears as if the problem (with WU not working) was caused by bad drivers for the disk (HDD to SSD replacement). My computer is now over 7 years old, so I wouldn't be surprised if it was SSD incompatibility. But ... I downloaded and reinstalled the Intel drivers from the ASUS website (for my laptop). Thread. I downloaded some from Intel (Intel Rapid Technology probably), but when trying to install another error popped up (something with kernel32.dll or something like that).
Anyway slightly disheartened, found the Windows 7 OEM CD. I installed a clean system on an SSD, used my ASUS Windows key and ... I don't have any unsigned driver. So everything works, including Windows Update. I am at the stage of installing drivers, e.g. for graphics (I have a hybrid graphics system with GeForc 210).
I expressed myself badly and unfortunately. I have a factory recovery partition with Windows there, which is hidden for obvious reasons. And from it I recovered the original OEM Windows from ASUS.
Edition 2017-12-20 17:19 I can confirm that the Intel drivers were responsible for the problems with signing digital files and the non-working Windows Update service. I installed them once from the ASUS website and I immediately "fell" WU. I have reinstalled Windows and now I am avoiding Intel drivers. I have graphics, sound, screen brightness, volume controls etc. And all signed drivers and WU working.
The discussion revolves around a Windows 7 boot issue caused by digitally unsigned drivers after installing software for viewing SD card partitions. The user experiences a boot failure with error code 0xc000000e, only able to access Windows in "Disable driver signature enforcement" mode. Various troubleshooting steps are suggested, including using CMD commands to disable integrity checks, uninstalling disk controller drivers in Safe Mode, and utilizing recovery tools like bootrec and sigverif.exe to identify unsigned drivers. Ultimately, the user resolves the issue by reinstalling drivers from the ASUS website and performing a clean installation of Windows on a new SSD, eliminating the problem with unsigned drivers and restoring Windows Update functionality. AI summary based on the discussion. May contain errors.
TL;DR: Windows 7 booted only with F8 because 69 of 251 driver files were unsigned; “I started my computer and everything works” after removing cfadisk.sys. [Elektroda, lucasville, post #16882435]
Why it matters: This FAQ helps you quickly fix Win7 boots blocked by unsigned or bad storage drivers without a full reinstall, especially after SD-reader tweaks or disk cloning.
Who this is for: Windows 7 users seeing 0xc000000e or needing to disable driver signature enforcement to boot.
Root cause variant: Cloning or Intel storage drivers later broke signatures/WU; clean install avoiding those drivers fixed it. [Elektroda, lucasville, post #16897796]
How do I fix Windows 7 booting only with “Disable driver signature enforcement”?
Run sigverif.exe, review results, and delete the unsigned storage filter cfadisk.sys if present (System32\Drivers). Reboot normally. Then reinstall your OEM SD-reader drivers to retain functionality. “I started my computer and everything works.” [Elektroda, lucasville, post #16882435]
What does error 0xc000000e mean in this context?
It appears during “Windows is starting,” indicating the boot selection failed because a required device is inaccessible. It coincided with unsigned driver loading after installing Ext2Fsd/cfadisk for SD partitions. F8 with signature enforcement disabled allowed boot. [Elektroda, lucasville, post #16881853]
Safe Mode won’t start either—what now?
In this case, Safe Mode threw the same 0xc000000e error as normal boot. Use F8 to disable signature enforcement temporarily, remove the offending driver (cfadisk.sys), then reboot and reinstall OEM storage/card‑reader drivers. [Elektroda, lucasville, post #16882093]
How do I properly run bootrec /rebuildbcd?
Boot from Windows 7 Recovery media (USB/DVD). Only there will bootrec be available. Then run bootrec /rebuildbcd to rebuild the boot configuration. If Windows still fails, proceed with driver cleanup steps. [Elektroda, safbot1st, post #16882355]
What is cfadisk.sys and why can it break boot?
cfadisk.sys is a Hitachi Microdrive storage filter often used to present removable media as fixed disks. Here it loaded as an R0 (boot‑start) driver, causing signature enforcement failure and blocking boot. Removing it restored startup. [Elektroda, safbot1st, post #16882355]
Can I keep the SD card reader working after removing cfadisk.sys?
Yes. Reinstall the vendor’s driver package (e.g., ASUS AmIcoSingLun). The reader worked normally without cfadisk.sys after reinstall. “It has detected the card nicely and I have full functionality.” [Elektroda, lucasville, post #16886032]
Is this a malware issue or just drivers?
Security scans (ESET, TDSSKiller) found nothing relevant. Removing cfadisk.sys resolved the boot problem. Later, unsigned‑driver counts related to cloning and storage drivers, not malware. [Elektroda, lucasville, post #16882435]
Why did so many drivers suddenly show as unsigned?
After comparing disks, only 6 of 256 were unsigned on the original drive. The spike occurred after cloning; drivers lost signatures post‑clone, impacting Windows Update too. [Elektroda, lucasville, post #16887861]
Windows Update broke after cloning—what fixed it?
A clean install on the SSD, then avoiding Intel storage drivers restored Windows Update and proper signatures. Installing those drivers immediately broke WU again. [Elektroda, lucasville, post #16897796]
How can I disable signature checks from Windows (and why it may not help)?
bcdedit /set nointegritychecks ON runs from an elevated CMD. It succeeded here but did not fix the boot error, confirming a deeper driver issue that needed removal. [Elektroda, safbot1st, post #16881888]
Bootrec says “Total identified Windows installations: 0.” What should I try?
That output occurred when running repairs from recovery media. If it finds zero, focus on removing the unsigned boot‑start driver (cfadisk.sys) and then reboot. [Elektroda, lucasville, post #16882435]
What is Ext2Fsd and could it contribute?
Ext2Fsd 0.69 lets Windows read Linux ext2/3/4 partitions. It was installed alongside cfadisk during the incident. Removing cfadisk, not Ext2Fsd, restored boot in this case. [Elektroda, lucasville, post #16881853]
What tool can I use to inventory unsigned drivers fast?
Use sigverif.exe built into Windows 7 to scan and list unsigned drivers. It flagged 69/251 unsigned files in this case, surfacing the culprit quickly. [Elektroda, lucasville, post #16882435]
Any diagnostic tools worth running if the BCD is corrupted?
From recovery, use bootrec /rebuildbcd. From Windows, gather FRST logs (FRST.txt) to inspect services and drivers if startup still fails. [Elektroda, safbot1st, post #16881967]
Quick how-to: remove a bad boot driver (cfadisk.sys) safely
Boot with F8 → Disable driver signature enforcement.
Run sigverif.exe, locate cfadisk.sys in System32\Drivers, delete it.
