Citroen C3 XTR 1.4 HDi 16V: Fault Codes P1349 & P1351 - Preheater Relay Circuit Issues & Solutions
Pawel93 26784 3
  • #1 16519573
    Pawel93
    Help: 5
    Rate: 50
    Hello to all forum users. I would like to present the fault codes maybe someone had the same or similar problem. It is P1349 and p1351:
    P1349 - Permanent defect. Preheater relay circuit. Short to + or open
    P1351 - permanent defect. Preheat relay circuit. Relay activated. candles not powered.
    I will add that I connected another relay and there is the same error and the second ECU with the same numbers is also the same error.
    Thank you in advance.
    KMAuto-Klinika
    Rate: 18
    Check the power supply to the relay. And the candles themselves. Candle wire - relay.
  • #3 16524944
    Pawel93
    Help: 5
    Rate: 50
    The candles were changed a year ago and everything Ok the power supply goes to the relay but it doesn't heat the candles. Probably somewhere the harness is frayed or some wire is broken. If I can fix it, I will try to describe what was wrong.
    Pawel93
    Help: 5
    Rate: 50
    I consider the topic closed. On a walking engine I screwed on these two separate wires, the cube was plugged in and the error disappeared for so. Thank you for your help, sir.
    Moderated By T5:
    We appreciate that you have provided a solution to your problem, your topic may be helpful to others. We reward "Helped".
