AEG S83920CMXF refrigerator - Does not cool, the display does not work
G0liat 6144 4
  • #1 16522480
    G0liat
    I warmly welcome,
    AEG refrigerator (model as in the topic of the thread) suddenly stopped cooling, neither the light inside nor the display works. The display turns on only after opening the door for about 3/4 and it looks like it is resetting (it shows only eighth notes and lights up all possible symbols), then it works normally, but the refrigerator does not respond to commands. The light turned on once for a moment, but when the door was opened, it was almost at its maximum.
    It's new (a little over a year), but they don't open the warranty service until Monday morning, maybe it's some kind of error that can be checked, and 2 days in such weather is a bit of a bad news for food ...
  • #2 16667181
    kumbot
    Rate: 9
    I have the same ?? fridge from March this year how did you solve the problem?
  • #3 16667290
    G0liat
    The cable in the door needed to be replaced. It rubbed in one place and the plug has been loosely connected since installation. From what I noticed, it will happen quite regularly, the same service technician said.
  • #4 16678924
    kumbot
    Rate: 9
    Thanks, mate, this is a factory defect of the refrigerator hinges. Unfortunately, a dud, and the service is a massacre, half a month of waiting for repair.
  • #5 21164799
    wiśnia
    Good afternoon, I have the same problem. How do I replace this cable myself?
