BMW E46 318i M43 1.9 Petrol - The water cooler fan does not work
leszeklk2 27588 13
Why does the radiator fan on a BMW E46 318i M43 1.9 petrol not work, and how can I test whether the fan or its control circuit is faulty?
The fan is controlled by a digital signal through the fan module, so the 4.2 V you see on the control wire does not mean the fan should run and a multimeter will not properly verify that signal [#16523081] Check the fan with INPA or another diagnostic tool, or activate it by computer; the fan should also start when the engine is running and the air conditioning is switched on [#16523081][#16527606] To separate a wiring/control issue from a bad motor, test the fan directly from the battery for a moment; you can also check whether the sensor itself is open or shorted [#16522675] In this thread, the final fault was the fan itself: it had oil inside, while the fan module was functional [#16919640]
  • 4.2V control wire suggests fan control fault
    #1 16522637
    leszeklk2
    Rate: 12
    I have a problem that the radiator fan does not work for me.
    I tried to close the contacts from the temperature sensor and ignition but it does not turn on.
    I hooked up the second fan which is supposedly working and does not work.
    There are 3 pins on the radiator plug. On one of the thicker ones is 12V on the second mass and on the third it is 4.2V.
    When shorting the temperature sensor on this third cable, 4.2V voltage does not change, and probably should be because it is this wire that controls the fan speed.
    I have already replaced the climate control panel because it is said he is responsible for controlling the fan. But without changes, the fan still does not turn.
    Anyone have any ideas what it can be?
    If it was a fuse, would it not be any tension?
    Is the voltage on the 4.2V control cable and the fan should turn?
  • Testing both fans directly from battery or 9V supply
    #2 16522675
    paszczakq
    Help: 48
    Rate: 204
    Radiator plug? Do you mean this on the passenger side? There is more control module (regulating the speed) of the fan there. Mass supply and 4.5V power supply is control. The sensor will be on the engine and short circuit will not give much. More measurement whether alone as a sensor did not get a short circuit or quite a break.
    I will add that you can have both fans broken. Connect both to the power supply either from the battery or even (more safely) the 9V battery for a moment literally and will be known.
  • Question about BMW fan connector control voltage
    #3 16523040
    leszeklk2
    Rate: 12
    I mean this plug on the passenger side of the windmill.
    I have read that if you plug the connector from the temperature sensor at the bottom of the radiator, also on the passenger side, the fan should work. (Because this sensor turns on the fan)
    This plug from sensor No. 11 - coolant temperature sensor BMW E46 318i M43 1.9 Petrol - The water cooler fan does not work
    The fan connect 12V to what is 12V, mass to ground
    and 12V or 9V on the control to give?
    Because he has to go through the module to check the operation of the module. I've read that the control is somehow differently implemented but I do not understand how.
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Your ideas are sucking, the only thing that can be controlled from the computer, digital control so in the barn you can not take this cable.
    Where are you from where you are from?
  • #5 16523070
    leszeklk2
    Rate: 12
    I'm from Zielona Góra.
    Well, I read something that some other control is. I have a computer cable only I need to install INPEA and there is some option of firing a windmill.
    Will the voltage on the control cable change as the fan turns on? Will this meter not work and will be 4.2V all the time
    Help: 1405
    Rate: 6430
    There is a digital signal there, not measurable by a multimeter.
    Added after 40 [seconds]:
    The easiest way is to replace the windmill or diagnose inpa or other crap.
    Secondly, after switching on the air conditioning, the fan should start.
  • #7 16523118
    leszeklk2
    Rate: 12
    When the engine is switched off and the ignition key is turned on after turning on the fan, the fan does not work.
  • #8 16523453
    Help: 1405
    Rate: 6430
    leszeklk2 wrote:
    With the engine switched off
    Then why do not you turn on the engine for the air-conditioning to work?
  • #9 16523649
    paszczakq
    Help: 48
    Rate: 204
    Inpa will say something is wrong with the sensor. The fact that now it will be a souvenir after unbuttoning it but you can then see if the reading from it is close to the truth.
    It does not hurt, however, to check the fan itself, and the fact that someone gave a good fit is also nothing reliable.
  • #10 16523823
    leszeklk2
    Rate: 12
    Only how to check the fan itself, how the control signal is digital and I do not have anyone with such a car?
    I will not start the car for now because I have a slightly undressed engine, I replace the timing cover seals. But should the fan not walk on the engine off, the ignition and air conditioning on?
  • #11 16523830
    Help: 1405
    Rate: 6430
    If you finish the engine, you will take care of the fan.
  • #12 16526606
    leszeklk2
    Rate: 12
    Only that it can be checked without a fired engine, does the fan work on the key in the ignition position or a completely exclusive car? Can anyone confirm this? Because I would like to have eliminated this problem faster because it should probably take less time.
    And the fan I bought from the auction where they wrote that before the shipment they check the windmills on a special table. I wrote to them later if they definitely checked and they said yes.
    And is it possible that if there is little air conditioning factor, then the fan does not work? Because I've had strange air conditioning noise before. But it would probably be a bit senseless?
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    Start with a computer diagnostics, even INPA can be. If you fan the fan error and you can delete it or return it right away, you have it damaged. Check only by activating with a computer or turn on the engine on the engine, otherwise it does not make sense.
    90% of cases of fan failure, and such good ones, I have almost every one used at a good price. Let's not kid ourselves but it's already old cars and the same parts of them will be
  • #14 16919640
    leszeklk2
    Rate: 12
    Problem solved. The fan himself was found guilty and it was filled with oil. The fan module was functional.
The discussion revolves around a BMW E46 318i M43 1.9 Petrol experiencing issues with the radiator fan not functioning. The user attempted to diagnose the problem by shorting the temperature sensor and checking the voltage at the radiator plug, which showed 12V, ground, and 4.2V on the control wire. Despite replacing the climate control panel, the fan remained inactive. Responses suggested checking the fan control module and using a diagnostic tool like INPA to identify potential sensor issues. It was noted that the fan should activate when the air conditioning is turned on, and ultimately, the problem was resolved by replacing the fan itself, which was found to be faulty.
