VW GOLF IV 98r 1.9 TDI AHF - Problem with the Vgate iCar 2 interface
Raasq 8115 4
  • #1 16528738
    Raasq
    Yesterday I bought the VGATE iCar2 interface, after connecting, no program can connect to the car.
    The interface supports such protocols:
    - J1850 PWM (41.6 kbaud)
    - J1850 VPW (10.4 kbaud)
    - ISO 9141-2 (5 baud init, 10.4 kbaud)
    - ISO KWP (5 baud init, 10.4 kbaud)
    - ISO KWP (fast init, 10.4 kbaud)
    - ISO CAN (11 bit ID, 500 kbaud)
    - ISO CAN (29 bit ID, 500 kbaud)
    - ISO CAN (11 bit ID, 250 kbaud)
    - ISO CAN (29 bit ID, 250 kbaud)
    From what I noticed in the car plug, I only have pins: 4,5,7,16
    I read and found out that the protocol is suitable for these pins: ISO9141 / ISO14230
    I was looking for interfaces for this protocol but I can't find anything.
    I will probably resell iCar 2 if nothing can be done.
    PS * Bluetooth interface
  • #2 16528765
    sk700
    Help: 173
    Rate: 420
    So you want to tell us that you bought an interface for a hundred to use it for a car in which you can do everything you need with a VAG KKL cable costing less than PLN 25 with the shipment, and now you have a doctorate in protocols instead of typing in google before buying "golf 4 what interface "? :) :)
  • #3 16528814
    iron64
    Help: 648
    Rate: 313
    A colleague probably wanted to get things done wirelessly.
    For starters, start with whether the bluetooth on the computer is communicating, you can also check the phone, in the sense that the phone is able to detect this contraption. Usually the problem lies with the computer, and basically because of the strange operation of the blues on the windows.
  • #4 16528871
    sk700
    Help: 173
    Rate: 420
    This whole facebook is about breaking, he will get tired of configuring it, and even if he succeeds, he will eventually check the lambda errors. It's just ELM in another housing, let him send it back to where he bought and buy a regular KKL and download VCDSlite and he will be delighted because he will do more than necessary :)
    Connecting the Elm with anything more than an engine to add keys, for example, is like winning against cancer :)
  • #5 16528933
    Raasq
    I have already ordered a normal int. on the cable (VAG KKL) and I left the iCar 2 because it turned out that the password in Peugeot 307 2002 :)
    All in all, the topic is rather close, thanks for making me aware of what you are buying for :D
