New 2din Car Radio (7025) Issues: Problems Connecting to VW Golf 4 - Reverse Mode & Cables
Szramasek 6234 3
  • #1 17408493
    Szramasek
    Hello. For Golfik 4 I bought a new 2din - chinol radio from bluethcar model 7025. The old radio was an original from a Volkswagen so I thought that there would be no problems with connecting the new radio. I unplugged the old radio and was scared by the amount of converted cables, additional cables, original cables, from the original radio I unplugged everything that was unnecessary and I only had a power cube, a speaker cube and an antenna cable. I plugged in all the cables, the radio turned on and after a while it switched to the 'reverse' mode, which, as I guess, is an option for the rear view camera, although the car was at ease and the non-touch buttons, i.e. the knob, the radio (menu) button did not work. I connected the radio to my brother's car and, surprisingly, everything works as it should, the difference is that he has about 10 times less cables. I fumbled a bit in the cables, cut off what I thought was unnecessary and insulated it and the radio started working, the buttons started working - a fairy tale. I started the car and the reverse popped out again, I drove a few meters and while driving, the radio was working normally, after stopping the car, reverse again. I decided to take a ride to see what it would look like and it was the same, while driving, the radio works fine, just stop somewhere at the traffic lights and the reverse turns on. I would ask for any suggestions as to what could be the reason for such radio freaking out.
  • #2 17408779
    jakubek56
    Level 32  
    Help: 202
    Rate: 454
    Take a picture of these wires.
  • #3 17472579
    Pierun26
    Hi. I have the same problem with the exact same radio. I connected to my lagoon 2 and it is exactly what you described. Did you handle it? I have no idea what to do to stop the radio from freaking out.
  • #4 17473371
    Jarek1104
    Rate: 15
    Hi, I did it in my VW Sharan in the radio supply cube, leave only PIN 4,6,7,8 because the radio has at least in my Chinese on pin 2 a camera signal and in VW it is to mute the radio during messages, etc.
