Connecting Bluetooth to Old Radio-CD: Eliminate Buzzing Sound from 1702 Connector Conversion
IwoR 13551 5
  • #1 16529310
    IwoR
    Dear Forum Members,
    Welcome to the forum as a writer :)
    what life forced me to do :) Because as the Bluetooth whistle works well in the car through the AUX input, I decided to convert the old boombox into a bluetooth speaker with a radio for holiday trips. As the radio does not have an AUX output, I connected the blutooth to the 1702 connector (I attach the diagrams), i.e. instead of playing discs that no one is wearing anyway ... I plan how everything will play nicely inserting the switch, but after folding the system, I hear a buzzing sound from a modem , sometimes the music will drown out but I like to listen to something quite quietly sometimes ...
    Could one of the forum members bend over the schemes and say how to eliminate it?
    Thanks in advance
    Iwo
    • philips_az-8340_sch.pdf (1.91 MB) You must be logged in to download this attachment.
  • #2 16529378
    leonov
    Help: 1039
    Rate: 2248
    On this page you have the description of connecting the AUX input to the signal instead of the CD drive, there are capacitors in the line in there, read maybe it will help ;-)
  • #3 16529421
    E8600
    Help: 529
    Rate: 2520
    Finally, someone who thinks soberly and doesn't want to build a 2x30W Bluetooth speaker from scratch (a lot of such topics lately). An idea worth praising because I myself advised several such solutions on the forum. I would wonder if it would not be better. It is easier to use the cassette input to plug into the pins of the head and use a jack with a switch, which will be responsible for turning on the reading from the cassette head after inserting the jack 3.5 plug into the socket. I gather myself for such a solution. Can I ask you what you want to fund it for?
  • #4 16529556
    398216 Usunięty
    Help: 3925
    Rate: 9448
    E8600 wrote:
    use the cassette input to plug into the head's pins
    What about the pre-amp correction of the tape recorder?
  • #5 16529578
    E8600
    Help: 529
    Rate: 2520
    I understand that it's about noise reduction etc? I didn't think about it but when the cassette adapter works, this should be the solution. I am not very advanced so if I'm wrong please correct it. The reading in the CD drive is not a digital case and the bluetooth adapter gives an analog signal.
  • #6 16529665
    398216 Usunięty
    Help: 3925
    Rate: 9448
    No. The point is that the signal from the cassette head is not a signal with a linear characteristic of the frequency. To compensate, the head is connected to the input of a correction amplifier, which reduces this unevenness. So if you connect the line signal (from BT) directly to the input of the cassette preamplifier once: You would have much too high sensitivity (because the signal from the head is millivolts, and the output from BT / and other line sources / is hundreds of millivolts), and two: heavily conquered (at the expense of the lack of high frequencies) the bass.
    https://www.infomusic.pl/poradnik/38765,rejes...asmy-i-magnetofonow-wielosladowych-cz-i#Link5
