LG Monitor Resolution Issue: Accidentally Changed to 1920x1080 and Out of Range Error
Lukardelli 3534 2
  • #1 15980557
    Lukardelli
    Hello. I have a resolution problem. I accidentally changed it to the highest one my monitor is not accepting. The highest is 1920x1080. I entered safe mode, uninstalled the drivers and entered normally and had an image. I have installed the drivers. I couldn't change the resolution as I was on a standard VGA card. So I did "restart". Restarted again, it says "out of range". Will you help? I do not hide that I care about time, because a computer is very necessary.
  • #2 15980969
    sosarek
    Help: 9320
    Rate: 15532
    In safe mode, go to START - RUN - type msconfig, boot tab and tick - "basic video mode", apply and ok, restart, the computer will start in basic resolution, set it as it should be + screen refresh, untype this option you marked and restart.
    Z
    Pka, Poznań, 60-850
  • #3 15983626
    Lukardelli
    Thank you very much :)
