How to transfer photos from LG G5 to a computer with linux using a usb cable
andrea70 5313 12
How can I transfer photos from an LG G5 to a Linux computer via USB when the phone does not show a mass storage option and the computer only sees internal memory?
Select MTP mode on the phone’s USB notification; PTP shows only photos, while MTP should let Linux see both internal storage and the memory card [#16958282][#16959205] On the LG G5, the USB options are Charging, power supply, MTP (“transfer files, documents and multimedia files”), and PTP (“transfer photos and videos”); the penultimate option is MTP [#16958241][#16958282] If MTP does not work properly, the problem may be in the Linux file manager/desktop or distribution rather than the phone itself [#16958524] In that case, check your distro’s forums/wiki for MTP support issues [#16958524] As alternatives, you can transfer over Wi‑Fi with AirDroid, an FTP server on the phone, or SMB/CIFS/NFS-compatible file managers [#16958282][#16958524]
  • #1 16957047
    andrea70
    Rate: 16
    I wanted to send photos from LG 5 to a computer with linux software (Ubuntu 16, Sparky-Mate) via USB, but unfortunately I can't find the "mass storage" option on my smartphone which allows other photos to be sent quickly by connecting the phone to a computer via USB other files. Now I am sending photos as attachments to emails.
    Please give me a hint if there is another way or option to solve this problem?
  • #2 16957049
    yogi009
    Help: 848
    Rate: 2654
    And when connected, Linux doesn't detect anything for you?
  • #3 16957256
    andrea70
    Rate: 16
    It detects my smartphone like LGE Android Phone and after opening it shows me 3 catalogs:
    DCMI, Pictures and .thumbnails.
    There are all thumbnails in .thumbnails, but that's not the point.
    There are several catalogs in Pictures but only in PhotosEditor catalogs there are 3 photos in Screenshots 1. Other catalogs are empty.
    It is so interesting that on your smartphone as the main catalog for photos is "Gallery" in which there are several Albums-catalogs.
    Unfortunately, the Gallery catalog is not visible and from the catalogs contained in it only the ones I mentioned, i.e. PhotosEdior, are visible
    and Screenshots. If I move or copy photos from other LG G5 catalogs to the listed computers, I can see them!
    But it is difficult to keep pics in one of these two albums or even both, or for the computer to see them and to be able to send (copy), move or copy them to these albums.
    Hence the question I have, why does the computer not see the root of the smartphone or the Gallery and also does not see all the albums in it, only the two listed?
    Can it be changed?
  • #4 16957834
    blahfff
    Help: 1036
    Rate: 1301
    You don't have PTP mode instead of MTP on your phone? That would explain why it only shows you photos. The "mass storage" option will not be found and it has not been used in telephones for years.
  • LG G5 USB transfer only sees internal storage
    #5 16958040
    andrea70
    Rate: 16
    I was looking and I do not know where in this phone the modes are set I have not seen anywhere either PTP or MTP mode. Where does it fit and change in LG G5?
    I only came to the fact that the computer can only see the pics stored in the internal memory and does not see those saved on the memory card (does not see the memory card) and each time when I want to save pics or other files from the memory card to the disk, I will not remove it from the phone and he didn't put it in the laptop slot.
  • #6 16958050
    yogi009
    Help: 848
    Rate: 2654
    Take out this card and connect through the reader directly to the USB port of the computer, it will be easier.
  • Prefers copying photos via internal memory
    #7 16958167
    andrea70
    Rate: 16
    Of course it will be easier. It will be even easier to insert this card into the laptop's memory card slot. Only that it requires each time removing the memory card and after copying, reinserting it into the phone, which in any case can damage the memory card or even the plugs on the phone.
    Thank you, but if it cannot be resolved otherwise, I prefer to copy the photos to the directory in the phone's internal memory and copy the photos that have already been copied to it.
    Best regards and thank you for your good will.
  • #8 16958191
    blahfff
    Help: 1036
    Rate: 1301
    Usually, when connected to a computer, a notification appears on the screen of the phone with information in what mode the phone is connected. After clicking on it you can select the mode.
  • Clarifying LG G5 USB transfer options on Linux
    #9 16958241
    andrea70
    Rate: 16
    Of course, something like this is shown, but there are such options to choose from:
    Charging this phone.
    Power supply - recharge the connected device,
    It transfers files, documents and multimedia files to the connected device,
    It transfers photos and videos of the connected device.
    Whether I choose the last or the last but one option does not change anything. The laptop only sees what is stored in the phone's internal memory.
    I wonder if there is a LG G5 user on the forum who managed this problem?
  • MTP mode and Wi‑Fi transfer workaround
    #10 16958282
    blahfff
    Help: 1036
    Rate: 1301
    The next to last option should be selected. This is MTP. Lately it's PTP and then you can see only photos and can skip the memory card. It is possible that the problem lies in the implementation of the MTP protocol in the file manager. It would be worth checking how another phone will behave, but I bet that you should look for solutions to the Linux distribution forum you are using because it will rather be a problem on this side.
    Finally, you can manage using applications like AirDroid (or an FTP server installed on your phone and running only for the purpose of transferring files) that allow you to transfer data via WiFi, within the same network where the computer and phone are, without connecting anything.
  • #11 16958363
    andrea70
    Rate: 16
    Thanks for the clarification.
    I will try what will happen after using the penultimate option - MTP. If that doesn't change anything, I will have fun with moving
    for the time of copying photos to the phone's memory. I do not think that the fault was on the Linux side because Android is nothing but Linux (or its smartphone-adapted version).
    Recommend FTP or SMB instead of MTP
    #12 16958524
    blahfff
    Help: 1036
    Rate: 1301
    It doesn't matter. The implementation of MTP depends on the file manager. In Linux, this depends on the "desktop" used. In KDE it can work, in XFCE it can work differently, in Mate it may not work at all or it does not work properly under a given distribution, therefore also a suggestion to search for a problem on the page / forum / wiki of the given distribution. Maybe it's a little thing and maybe it just won't work.
    Either way, if you have both a computer and a phone connected to the same network, I would recommend either to install an FTP server and then connect to the phone using any FTP client, or some file manager that can connect to the computer via the SMB / CIFS protocol be NFS. Ultimately, fewer combinations, less chance of some mistake, etc.
  • MTP mode exposes internal storage and SD card
    #13 16959205
    andrea70
    Rate: 16
    blahfff thank you.
    Indeed, it turned out that on the penultimate option, MTP, the computer saw both the internal memory and the memory card and photos stored on it.
    Until now, I was not interested in smartphone software, which, moreover, changed with the passage of the period for which I had a contract with the operator.
    It turned out that it is worth to go deeper into this and the help of more advanced users of "cells" is invaluable here.
    I hope that my questions and help that was given to me will help other less advanced users in this matter.
    So I'm closing the topic.
The discussion revolves around transferring photos from an LG G5 smartphone to a Linux computer (Ubuntu 16, Sparky-Mate) via USB. The user initially struggles with the absence of a "mass storage" option, leading to difficulties in accessing photos stored in the phone's internal memory and on the memory card. Responses suggest that the phone likely operates in MTP (Media Transfer Protocol) mode, which is necessary for file transfer. The user learns to select the MTP option, which ultimately allows access to both internal and external storage. Alternative methods for file transfer, such as using an FTP server or file manager protocols like SMB/CIFS, are also recommended for users facing similar issues.
TL;DR: On an LG G5, pick USB “Transfer files” (MTP); 2 storage locations appear and you can move photos reliably. “On the penultimate option, MTP, the computer saw both the internal memory and the memory card.” [Elektroda, andrea70, post #16959205]
Why it matters: This fixes the “Linux only shows some folders/photos” issue without removing the microSD card, saving time and wear.
How do I make Linux see all LG G5 photos over USB?
Unlock the phone, connect USB, pull down the notification shade, and select “Transfer files” (MTP). Linux will then show both internal storage and the microSD card, not just partial folders. This resolved the thread’s visibility problem immediately. [Elektroda, andrea70, post #16959205]
Where do I change USB mode on the LG G5?
After plugging into the computer, check the phone’s notification panel. Tap the USB connection alert to choose the mode (e.g., Transfer files). That menu controls how the G5 presents storage to the computer. [Elektroda, blahfff, post #16958191]
What’s the difference between MTP and PTP on Android?
MTP (Media Transfer Protocol) exposes device storage for files, including microSD. PTP (Picture Transfer Protocol) limits access to photos/videos and may hide the SD card. Use MTP for full folder visibility and file operations. [Elektroda, blahfff, post #16958282]
Why can’t I find “USB mass storage” on my LG G5?
Modern Android phones retired classic mass‑storage mode. You won’t see it on the G5. Use MTP for general file transfers or PTP for camera‑only workflows. As one expert noted, it “has not been used in telephones for years.” [Elektroda, blahfff, post #16957834]
Linux only shows DCIM, Pictures, and .thumbnails—how do I fix that?
You’re likely in a restrictive mode or browsing a limited mount. Switch to MTP from the USB notification. Then re-open the device in your file manager to view full directories beyond DCIM/Pictures. [Elektroda, andrea70, post #16957256]
I selected “Transfer photos” but can’t see the microSD card—normal?
Yes. That option corresponds to PTP, which focuses on media and often skips the SD card. Choose “Transfer files” (MTP) to reveal both internal and SD storage locations. [Elektroda, blahfff, post #16958282]
My Linux file manager still won’t show the SD card with MTP—what next?
Some desktops handle MTP imperfectly. Try another file manager/desktop, check your distro forum, or bypass MTP with Wi‑Fi methods like FTP/SMB from the phone. This avoids desktop‑specific MTP bugs. [Elektroda, blahfff, post #16958524]
What exact options should I expect when I connect the LG G5?
Typically four: Charge this phone; Power supply; Transfer files; Transfer photos. Select “Transfer files” for MTP access. If you pick “Transfer photos,” you’ll see fewer folders. [Elektroda, andrea70, post #16958241]
Can I just remove the microSD card and use a reader instead?
Yes, a USB reader is simple and fast. However, repeated removal can wear the card or phone slots. If you prefer not to remove it, use MTP or Wi‑Fi transfer instead. [Elektroda, yogi009, post #16958050]
Quick how-to: copy LG G5 photos to Linux via MTP
  1. Connect USB and unlock the phone.
  2. Pull down notifications and select “Transfer files” (MTP).
  3. Open the LG device in your Linux file manager and drag photos to your computer. [Elektroda, blahfff, post #16958191]
Why does Gallery show albums I can’t see on Linux?
Gallery aggregates multiple sources. If you’re not in MTP, Linux may show only limited folders (like Screenshots or PhotosEditor). Switch to MTP to browse full storage and album folders. [Elektroda, andrea70, post #16957256]
Is there a confirmed success pattern from this exact LG G5 case?
Yes. Switching to the penultimate option (MTP) made both internal memory and the microSD card visible, enabling complete photo transfers. “It turned out that on the penultimate option, MTP...” solved it. [Elektroda, andrea70, post #16959205]
What’s an easy Wi‑Fi alternative if USB keeps failing?
Run an FTP server app on the G5 or use a file manager supporting SMB/CIFS. Then connect from your Linux PC over the same network to transfer photos without cables. [Elektroda, blahfff, post #16958524]
What are SMB/CIFS and FTP in simple terms?
SMB/CIFS is Windows-style file sharing over a network. FTP is a simple file transfer protocol. Both let your Linux PC access the phone’s storage via Wi‑Fi, avoiding USB mode issues. [Elektroda, blahfff, post #16958524]
Edge case: Why do I only see Screenshots and PhotosEditor folders?
Your file manager is surfacing limited paths, not the Gallery’s underlying storage. Move to MTP mode and reopen the device. Then copy from the actual DCIM/Pictures subfolders you need. [Elektroda, andrea70, post #16957256]
How many storage locations should appear when it works?
Two. In this case, both internal memory and the microSD card appeared after selecting MTP, enabling full photo access and transfer. [Elektroda, andrea70, post #16959205]
